My Panasonic TX-26LXD60 TV is frozen on re-tune after attempting factory reset
The tv would not change channels so I tried factory reset but that resulted in the screen now frozen on re-tune
  • 4 Answers
SOURCE: Samsung LE26R Digital Frozen
Solution that worked for me:
Beware: Although the process should be safe, it technically voids your warranty.
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote select the Reset option. Using the right arrow button at this point will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
Posted on Jun 10, 2008
  • 189 Answers
SOURCE: how do I change my Panasonic TX-26LXD from UK to
HELLO
This all depends on whether you can change over the settings in your tuning menu. If you cannot change from PAL I to PAL B/G then you have a problem.
If you still intend to take your UK set to spain, then you will be able to use it with a satellite box or DTV (freeview) type box via the AV connections (scart).
Hope this is of help! (:-)
Posted on Dec 02, 2009
SOURCE: Panasonic TX P50V10B Plasma TV
In order to get any of the Freesat channels, you need to connect a Satellite dish to your TV. If you have a Sky dish, you simply need to run an extra Cable from the LNB from the dish and connect to your socket on the back of your TV.
In order to get Freeview channels and Analogue channels, you need to connect a aerial to the back of the TV.
There is a menu option for the TV to start straight to the AV input (your Sky HD box). It is Menu > Setup > Other Settings > Power on Preference. Select 'AV' for your TV to start on Sky HD.
Also even if you have your TV to start on TV, when you turn on your Sky HD box, it should automatically switch to the Sky box.
Posted on Feb 20, 2010
Grubhead
  • 5158 Answers
SOURCE: Cannot get ITV or Channel 4 on newly aquired DTV, why is that?
The only thing I can think is happening is for some reason it's ignoring these stations. I suggest you try going to the factory settings for it. Then retune, it might clear the tunner's memory.
Posted on Feb 26, 2010
thedayi
  • 95 Answers
SOURCE: Panasonic TH-L32S1OZ digital TV set. Message on
Make sure the cable is hooked up then press ok on your remote (or enter). If you have your tv hooked up a different way (like hdmi) just change the tv source to the correct one.
Posted on Mar 04, 2011
I have a 2006 panasonic TH-42PX60b and it's stuck on one channel
Do a reset to this TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sep 30, 2017 | Panasonic Televison & Video
My Panasonic 26" LCD TV TX26LXD60 is frozen on return after trying to do a factory reset
Sounds that the firmware have been corrupted. You might have to upgrade the firmware. If you are confident, you can do it by yourself. If not, seek help of any experienced service technician.
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there.
Nov 28, 2012 | Panasonic Televison & Video
I have a panasonic viera and it is stuck on the PC channle and wont change how do i change it or restart my tv entirely?
Are you using the remote's AV button or the AV button on the TV? Do the other buttons on the TV work? (If the control board has failed, then the remote won't work nor will the input button.)
Are the cables for other devices connected and were the devices connected and off when the TV was turrned on? Are they on when you try to change the input? Bad cables may limit the sources the TV will allow you to select. Some will not go to an input that isn't providing any signal.
You can try resetting the TV to the factory specifications (you'll lose the channel programming though). Press Menu > Setup > Shipping Conditions
The manual is available here: http://www.retrevo.com/support/Panasonic-TX-32LX70-TVs-manual/id/2920dj480/t/2/ if you need it.
I hope this helps.
Jan 01, 2011 | Panasonic Viera TX-32LX70 32 in. LCD TV
Sony KDL-32S2010-Chicago area..channel 50.1 (WPWR) is now showing up on 51.3.(found it by accident). 50.1 showing spanish shows. Reinitiated auto tune erased all channels without antenna, then auto tune...
Do a factory reset to this set, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Mar 27, 2017 | Sony BRAVIA KDL-32S2010 32 in. LCD...
Feb 26, 2010 | Televison & Video
How do i connect and use a Nintento 64 with a panasonic TX-26LXD60. I know it won't work with aerial connect as with my old tv. And HDMI cable is not correct size. I have a cable that connects to Nintento...
try the av cable with the 64 on another older tv... if the picture comes up, then you probably wont be able to use the n64 on your new tv... if the picture dosnt come up, then there is a problem with your cable...
Feb 18, 2010 | Nintendo 64 Console
SAMASUNG 32 INCH TV FROZEN ON DTV CHANNEL 1 CHANNEL WORK WHEN YOU CHANGE TO TV CHANNELS 1 - 5 BUT DOES NOT WORK ON DTV CANT CHANGE JUST FROZEN ON CHANNEL 1
These are the steps to reset the DTV features and unfreeze your TV:
  1. Ensure the tv is in analogue mode, not dtv and turn it off.
  2. With the remote: press info, then menu, then mute, then power. These buttons need to be pressed sequentially, not all at the same time, and in quick succession. A menu will appear on the tv.
  3. Navigate to the reset option and press the left arrow key on the remote (or press the enter/ok button). The tv will reset itself and turn off.
  4. Turn the tv back on & it'll re tune all its channels. DTV should be working again.
I hope that helps.
Dec 26, 2009 | Televison & Video
Panasonic tv child lock bypass
my viera tx-l37g20b tv locked me out of things id recorded on my harddrive i.e. eastenders of all things i managed to unlock it with 1111 after several attempts it seems you cant actually turn it off but you unset each channel but i never set it in first place and it had worked ok till then!
Dec 22, 2007 | Televison & Video
Televison & Video Logo
106 people viewed this question
Top Televison & Video Experts
Electro Med Services...
