Question about HP Photosmart 8250 InkJet Printer
HP c7180 printer wants introductory cartridge
map9966
  • 2351 Answers
SOURCE: will not print cartridges out of date
I never heard of that for the C7180 all-in-one. Remove the ink cartridges. Dampen a rag with water. Slide the cartridges across the rag until you see ink. If yes, than good. Grab a couple of cotton swabs & drip a couple drops of alcohol onto a tip. Wipe the copper contacts off on the ink cartridges. Do the same to the contacts within the ink carriages. Replace the ink into the carriage.
From your computer, open Printer and Faxes. Make sure your HP C7180 all-in-one printer has a check mark next to it. If not, left click the C7180 once so its high-lighted. Than click "File" in the upper left corner of the window. Left click, "Set as Default printer". Than right click once on the C7180 & slide to & left click on Properties. In the next window click "Printing Preferences", Another window will open. Left click the "Services" tab. Click the "Service this device" button.
Than click, "Clean the Print Cartridges". When the printer finishes, click "Print a Test Page", button. (If you do not see ink on the test page than your ink cartridge are too clogged & you'll have no choice but to replace them).
Using the damp rag loosens possible clogged/dried up ink. Cleaning the contacts with alcohol removes oil from touching the copper contacts with your fingers, also removes dust. Always keep a cover over your printer when not in use. My current ink cartridges are at least 1+ year old. HP & other manufactures do use tracking software to monitor your ink cartridges in this fashion. If you remove an empty cartridge & re-fill it & replace the cartridge the software knows. Each cartridge has a tiny chip attached to it.
The internal software knows when you fill a ink cartridge & can shut down your ability to print. Forcing you to buy new ink cartridges. Below is the HP link for your C7180 printer.
http://search.hp.com/query.html?charset=iso-8859-1&lk=1&la=en&nh=10&rf=0&qs=&hpvc=sitewide&uf=1&st=1&qt=replacement+cmos+battery+for+HP+C7180+printer&submitsearch.x=2&submitsearch.y=4
Good luck timmer047!
Mike
Posted on Dec 17, 2008
patemi
  • 366 Answers
SOURCE: hp c7180 printer does not recognize new ink cartridge
be sure you removed tapes from cartridge.
Follow the instruction and reinstall new cart.
Posted on Feb 09, 2009
SOURCE: HP c6280 Won't load ink cartridges
Per HP:
Hold “print photos” button and “red-eye removal” buttons together, release
ø Then press the “red-eye removal” button, release
ø Then press the “print photos” button, release
ø Then press “red-eye removal, release
ø Scroll to “resets menu”, click ok to select
ø Scroll to “Options” semi-full reset, ok
The printer then powers off and wait a couple of minutes. I believe the printer turns back on (or maybe the user needs to power back on after a few minutes). The refills then work.
Posted on Jul 03, 2009
smwsolutions
  • 73 Answers
SOURCE: printing error oxc18a0101
Try resetting the printer:
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on.
Posted on Jul 19, 2009
JackHeath
  • 1049 Answers
SOURCE: hp c7820 printer 02 black catridge
Open the printer and remove the ink. Clean around the ink carriage and the under the ink with alcohol and a cotton swab. Pay special attention to areas with copper contacts. Keep in mind too that some printers will not print, even with full ink, if the exact type of ink it expected you to have installed is not right. Double check that the ink is correct against the manual or written instructions inside the printer using the number not the shape or color of the cartridge. Not every cartridge that fits the printer necessarily works.
Posted on Nov 13, 2009
I am getting this message: Wrong Cartridges: Use the introductory cartridges that were shipped with your printer.
probably the cartridges might be fake check on HP website using the serial number of the catridges to ascertain its authenticity
Jun 10, 2015 | HP Photosmart C7180 All-In-One InkJet...
Hp 7180 foutcode 0xc 18a0201
http://h30434.www3.hp.com/t5/Ink-Toner-Cartridge-Printhead-Issues/Printer-Ink-System-Failure-on-Photosmart-C7180-with-a-MAC/td-p/1220499
Feb 11, 2015 | HP Photosmart C7180 All-In-One InkJet...
Error: 0xc18a0106
replace the print head unit not the cartridge.
Jun 17, 2012 | HP Photosmart C7180 All-In-One InkJet...
How do you change the ink cartridges in an hp c7180 photosmart all in one
lift the hatch just below the scanner and the cartridges should automatically go to the right and side,the just unclip out
May 12, 2011 | HP Photosmart C7180 All-In-One InkJet...
Yup, these printers when they are new need to use the introductory or "primer" cartridges before you can use a set of "normal" cartridges in them. This is a one shot thing.
If the printer is new, call up HP. You may need to provide a receipt via fax, but they should send you a set of these if lets say you purchased a floor (demo) model and these cartridges didn't come with it.
1-800-hp-invent
You should have no problems having this done at no expense to you.
Feb 27, 2011 | HP Photosmart C6180 All-In-One InkJet...
THIS PRINTER COME TO ME WHIT OUT INK CARTIDGES BUT I GET NEW HP CARTIDGES , AND PUT IT IN THE PRINTER BUT IT SHOW IN THE DISPLAY USE THE INTRODUCTORY CARTIDGES THAT WERE SHIPPED WHIT YOUR PRINTER
yes right..u need the introductory cartridge in order to align the cartridges...so cal hp on 18004746836...
they will ship the cartdrige at free of cost...
Mar 24, 2010 | Office Equipment & Supplies
Had a problem with HP Photosmart C5180 All in One says cartridge cannot be used after initialization. Cannot find telephone number to ring HP in Ireland for support. This happens every time. I just had a...
Introductory cartridges come with the printer and carry special ink formulations intended for printer initialization. During initialization, inks in the introductory cartridges mix with inks in the printer to create a normal ink formulation. After initialization, introductory cartridges can be used in any compatible printer. However, if introductory cartridges that have not been through initialization are installed in a printer that has already been initialized, the printer cannot print
If the issue persists, perform these steps
try the cleaning steps advised in this link...
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00709715&cc=us&lc=en&dlc=en&product=1153481
Remvoe all Cartridges, disconnect the printer from the computer and connect it to the direct wall outlet and Reset your Printer to initial factory default settings:-
* Remove the power cord from the back of the product.
* Press and hold down the OK and Help buttons at the same time.
* While still holding the buttons down, plug the power cord into the back of the product.
If the issue persists, perform these steps.
1. With machine powered on, unplug power cord from back of printer and wait for 30 seconds.
2. While holding down the "ok" and "?" buttons, plug the power cord back into the printer.
3. Let the Printer power up again and give it time to go through all of its process.
Sep 22, 2009 | HP Photosmart C5180 All-In-One InkJet...
Per HP:
Mar 19, 2009 | HP Photosmart C6180 All-In-One InkJet...
Hp c7180 printer does not recognize new ink cartridge
Feb 09, 2009 | HP Photosmart C7180 All-In-One InkJet...
HP Photosmart 8250 InkJet Printer Logo
55 people viewed this question
Seeker5211
Seeker5211
