Question about Microsoft Windows XP Home Edition
No autorun on usb devices or cd rom
When i plug a usb stick in to my computer or put a cd in the drive they do not autostart, but i can access them through my computer
    Problem Solver:
  • 13 Answers
Run AutoFix.exe
download clik here Windows XP autorun repair wizard
Applies to:
Windows XP with Service Pack 2
Requirements
Windows XP with SP2
window.google_render
File Size
0.1MB
File Name
AutoFix.exe
Author/Supplier
Microsoft
Description
Windows XP was designed to make it simpler to identify content on CDs or DVDs, and assist in launching the correct program to open or view the files. For example, insert a movie DVD and Windows XP should show options for programs that can play a DVD. Unfortunately things can go wrong - settings get altered and the autorun no longer wants to be your friend. This free tool can help diagnose and repair autorun problems in XP. It is a tiny download and doesn't require installation. Simply double-click the exe file, click a few buttons (OK, some options are a little cryptic) and you can change or repair your Windows XP autorun options.
Posted on Jan 11, 2009
Put program disc in drive to reload program and its not running
may be autostart on drive is not on
open my computer, find cd, or dvd drive , open it and find some executable file..... or setup file....or autorun file.....
Feb 10, 2014 | Computers & Internet
How to use a USB memory stick and what happens if you don't unplug after use?
you can use your USB memory stick just like a normal hard drive, CD-ROM drive etc.
You can access the USB stick from Windows Explorer or the standard file, save as option in most applications.
No negative affects would occur from not unplugging the device. However make sure you click 'eject' in Windows Explorer if you want to remove the device when the computer is still switched on. If you switch the computer off you can remove the stick with no other considerations.
/javaftper
Jul 31, 2010 | Computers & Internet
How to install windows XP Pro without using cd drives
Find a computer with a CD-ROM drive.
Find a USB memory-stick that can hold 1 gigabyte.
Copy all the files from the CD-ROM onto the memory-stick.
Carry the memory-stick to the CD-lacking computer, and plug it in to a USB port, and install from there.
May 29, 2010 | Computers & Internet
Verbatim Disc shuts down computer when inserted
it seems some autorun program is causing this.
try disabling the autorun of cd rom drive ....setting is under device manager. then put the disc in the drive... you should be able to copy all the data from it.
Aug 06, 2009 | Verbatim DataLifePlus Ultra Speed CD-RW...
CD html presentation-hyperlinks don't work with other pc's
To create an Autorun-enabled CD-ROM, proceed as follows:
  • Create an Autorun.inf File
    Autorun.inf is a text file that is located in the root folder of your application CD-ROM. It provides to the computer the name and the location of the startup program for your application that is installed when the CD-ROM is inserted. The Autorun.inf file can also contain optional information including the following:
  • The name of a file that contains an icon that represents your application's CD-ROM drive. This icon appears in Windows Explorer instead of the standard drive icon.
  • Additional commands for the shortcut menu that appears when the user right-clicks the CD-ROM icon. You can also specify the default command that runs when the user double-clicks the icon. Autorun.inf files are similar to .ini files.
  • The [autorun] section contains the default Autorun commands. All Autorun.inf files must have an [autorun] section.
  • icon: Specifies the path and the file name of an application-specific icon for the CD-ROM drive.
  • open: Specifies the path and the file name of the startup application.
Autorun.infThe following is an example of a simple Autorun.inf file. It specifies Filename.exe as the startup application. The second icon represents the CD-ROM drive instead of the standard drive icon.
[autorun]
open=Filename.exe
icon=Filename.ico
May 07, 2009 | Dell Dimension 4600 PC Desktop
Storage devices won't autostart
I have the opposite problem - I can't stop them!
  1. Open Windows Explorer by pressing the Windows + "e" key.
  2. Right-click the desired CD-ROM and select Properties from the menu.
  3. Select the AutoPlay tab.
  4. Select each item from the pulldown list and for the Action to perform, select "Take no action" to disable autorun, or pick the apporpriate action to take if enabling autorun.
  5. Select OK.
Jan 10, 2009 | Computers & Internet
USB problem
u have stoped autorun option thats y its will happen
u have to do this plug your usb drive right click on usb removable drive go in properties>autorun option then click on promt me each time option then click ok then remove your usb drive reinsert it it will be autoply
Jan 10, 2009 | Intel Motherboard
Cd rom has stopped working. the light is flashing as if it is working but the cd is not spinning.
Check the disk for scratches, and try other disks to make sure the problem is not unique to that one disk. If all disks fail, then double-click on My Computer, then double click on the CD-Rom drive and see if a CD will run. The "autorun" option may have been disabled, which is very noticeable if you've been used to this feature working. To re-enable autorun, right click on the cd-rom drive in My Computer, and go to device properties - recheck the autorun or autoplay option.
If none of the above resolve, then turn off your computer. Open up your computer with screwdriver. Unplug and replug the cd-rom driver. Restart computer. Test cd-rom drive again.
If it still fails, Make sure you are connected to the internet (I am assuming Windows XP - Vista may vary): Go to Start --> Control Panel --> Printers & Other Hardware --> System --> Hardware --> Device Manager --> DVD/CD Rom Drives - se if the drive has a yellow exclamation by it - if it does, then right click on the yellow exclamation, and click install drivers - windows will most likely find a solution
If all of the above fails, write back with more details, including model/manufatcurer of cd-rom drive, and model/manufatcurer of computer.
Jun 11, 2008 | Computers & Internet
DVD/CD-ROM DRIVE DOES NOT SHOW
open control panel, system/device manager, and click on it to ensure it's no conflicts
Mar 02, 2008 | HP Compaq Presario V2000 Notebook
My computer opens Lite On 5236 (drive E:) yet sees nothing?
when you check the properties of the device does it recognise the drive
Nov 16, 2007 | Lite On (SOHC5236V) CD-RW/DVD-ROM Combo...
Microsoft Windows XP Home Edition Logo
253 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
