Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Washer is not agitating but goes through cycle. agitator spins both ways freely and not one way as it should? How do you get the agitator out?
  • 640 Answers
Remove cap or dispencer,,,pull the plastic cover up with you hand,,,now you need a 1/2 inch wrectet,,,remove bolt holding auger (top agitator) then pull up agitator..onthejob
Posted on Jan 17, 2009
4 Suggested Answers
  • 219 Answers
SOURCE: Grinding noise during agitation on washing machine
check water pump
Posted on Apr 17, 2009
  • 84 Answers
SOURCE: Grinding sound during agitation cycle on my Maytag Performa
Its probably you stator plate and rotor. But you need special tools for this repair. There a spring that is under 200 pounds of pressure and if you take the screws off that hold the plate its going to fly into you face if your dont use the special tools to depress the spring. Is it more of a clanking kinda of noise? DOes it olnly happen with heavy loads? Try this out. Fill the washer with water only. and get it into a wash cycle with water only. If there is no noise then put in like a load of towels. A heavy load. Now if you hear the noise now then its for sure you stator plate and rotor..hope this helps, but like i said you need those special tools to do this repair or injury can result from the spring part.
Posted on Jul 27, 2009
  • 142 Answers
SOURCE: Amana Washer LW4303W. Tub
Yes, there is a brake that holds the tub while the machine is agitating. I don't have a manual handy for that model, but you probably have a plastic pulley in the center bottom of the machine. The brake is above that. There is a cam arrangement inside the pulley that will disengage the brake when in spin.
Posted on May 10, 2011
Washer will not spin or agitate
Can you move the agitator freely by hand?
Jun 26, 2013 | GE WJRR4170E Top Load Washer
Amana Washer LW4303W. Tub spins much to freely while the agitator agitates. Could be coincidental but this problem seems like this all started after I replaced the drive belt. Washer cycles like it...
May 10, 2011 | Washing Machines
Is the upper part of the agitator supposed to spin with the lower part? It spins freely when I turn it, but doesn't spin when spin cycle is activated during a cycle.
You have bad agitator dogs . Easily replaceable and inexpensive . Remove the center bolt holding the agitator on and seperate the 2 agitator pieces . You will see 4 teardrop looking pieces ( dogs ) . Replace and your done .
Jun 29, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
I just replaced the transmission on my Kenmore 80. No agitation
your motor turns one way for the spin cycle and the other way for agitate. remove the coupler and test it that way.
Feb 04, 2010 | Kenmore 24832 Top Load Washer
Frigidaire washer spins but won't agitate
when you try to spin the Agitator dose it spin freely both ways if so the DOG EARs are stripped and need replacing Take cap off top off agitator to access the bolt holding the n in place and the Agitator off
Oct 22, 2017 | Frigidaire Washing Machines
Agitator doesn't spin during wash cycle
If The washer won't agitate
Check to make sure no clothing got wrapped around the agitator. Check the lid switch, timer, and drive belt, other potential causes, such as a bad transmission or bad agitate/spin solenoid, but they are much more involved.
if the washer won't spin, the lid switch, timer, drive belt, transmission, or agitate/spin solenoid could be the cause here as well. Sometimes if the load is unbalanced or too heavy, the washer won't spin. Take some of the clothes out and try the spin cycle again with a lighter load.
Here are the steps to replace the agitator.
1: Take the fabric softener dispenser off and pry off the agitator lid.
2: Use a socket wrench with an extension bar to remove the stud and seal.
3: Remove the agitator top and bottom.
4: Check the agitator clutch assembly (located in the agitator top) for excessive wear.
5: To replace, just reverse the directions.
Jun 29, 2009 | Washing Machines
GE Washer Model WJSR2080V3WW Agitates, Pumps, but will not Spin
I solved the mystery of the non spinning washing machine by GE. I pulled the agitator off and to my horror was a broken " hub". This the part in the middle of the basket under the agitator. The transmission shaft comes up through the center of it. Any way, it was severely broken and wedged in so it would not spin. Not sure if this is the only problem but I am going to buy a new machine. I can not get it unbolted to replace the hub and don't want to **** around with it. THANKS.
Jan 25, 2009 | GE Washing Machines
Can't remove bolt to take off agitator
heres a procedurew to replace the agitator dawgs, preventing agitation, perhaps this will help
http://www.youtube.com/watch?v=f67gGXtK2I0
Apr 05, 2008 | Kenmore 22422 Top Load Washer
Washer fills and spins but does not agitate
Im sorry to say, it sounds like the transmission in the washer may have gone out, the unit it self sits at the bottem of the main agitator shaft under the the tub, you may be able to have this replaced, but shop around for the right price.
Jan 26, 2008 | Washing Machines
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
55 people viewed this question
Dan Webster
Dan Webster
Sal De
