Question about Denon AVR-1706 Receiver
No sound I have no sound coming from the right channel on both my surround speakers and my surround back/zone 2. any suggestions
  • 75 Answers
Read the manual thoroughly, then check all your connections.
Posted on Oct 02, 2009
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
ONKYO TX-SR701 - Hi When using the speaker config I can get output from all speakers but the Surround back speaker R does not work. I do get sound from Surround back L. It's a bit confusing as the...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Onkyo-TX-SR701-Receivers-manual/id/365ag222/t/2/
7.1 would have Surround Back L and R.
6.1 would have just one back there (SB). It defaults to the Left output on the Pre-Outs if you ever go that route.
This being a 6.1 receiver it does not support two SB channels BUT you can configure those amp channels for a separate Zone supporting 2 speakers. Confused?
The manual shows a single SB speaker connected to the left side on Page 27. THAT would be consistent with a 6.1 configuration.
Jun 04, 2011 | Onkyo TX-SR701 Receiver
I have lost the settings for 7 channel, it has gone back to 5 channel
If you have no Surround Back speakers defined it won't allow 7.1 operation. Or you have a Surround Back/Zone 2 setting wrong. Check your speaker definitions.
Jan 19, 2010 | Denon AVR-3803 Receiver
Surround sound will not work sr805
Did the speaker cailibration work on the speakers in question?
If YES, then the program material or settings you're using don't require the rear speakers.
By "Back" do we mean Surround or Surround Back? Surround Back speakers are the 6th and 7th channels in the 7.1 matrix. Not all source material has programming for them. But when using any 7.1 digital surround mode you can get anything, even stereo recordings, to output something from every speaker.
If NO, check your connections...
http://63.148.251.135/redirect_service.cfm?type=QuickHookup&file=TXSR805_QSS_En_0330.pdf
Dec 21, 2008 | Onkyo TX-SR803 Receiver
Left surround channel don't work
the problem you have seems to be on programing the master effects to get to it go to main menu and see the distribution and effects you want to hear on you home theather.remember that home surround needs some decoders to send the sound where the images come and its right built in....
Nov 17, 2008 | Denon AVR-887
Zone 2 problem
I know this is old and im sure you have it solved by now, but it might be a good idea to check the amp setting of Zone 2. Is it switched to Internal or external? I remember something strange about this amp in that when you change from using the rear surrounds and go to use them in Zone 2, it resets the amp setting or something like that. Hope it helps if you still need it.
Sep 15, 2008 | Yamaha RX-V659 Receiver
Back speaker sound
Why would you only hook up one speaker for the rear channel? in 7 channel stereo, all speakers have 100% signal sent to them as "stereo" in Dolby digital, rear speakers are for "effects" not dialog. like a plane flying past you or a car driving by, that's when you hear a rear speaker. It also needs to be placed behind you, not next to you or in front of you. Unless you are using zone 2 & 3 the receiver's surround back will work. if you only have left,right,center,sub & rear; the rear speakers should go to surround speakers not surround back. If you still have questions, post a comment and I can explain further. Hope this helps
Feb 04, 2008 | Yamaha RX-V2600 Receiver
Surround sound from Sky +
To upmix 2-channel sound (such as that in a TV broadcast) into 5.1 sound, press AMP and then SUR. DECODE until "PL II Movie" is displayed. This will give you "cinema-like" surround sound from a 2-channel source.
You can also assign this to one of your "Scenes" by following the procedure for scene assignment on page 26 of your manual.
Dec 30, 2007 | Audio Players & Recorders
Problem: I am trying to Hook up my RX-Z9 and get sound out of MAIN.
Try pressing "Main A" or "Speakers A"-button on the remote-control (slide the shield at the bottom)
Nov 14, 2007 | Yamaha RX-Z9 Receiver
Denon AVR-1706 Receiver Logo
83 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
