Question about Copystar Kyocera Taskalfa 520i Multifunctional Copier, Prin
Kyocera taskalfa 520i says offline when printing
It was printing before,then suddenly showing ofline,it can able to perform scan to smb
Kyocera Taskalfa 552ci will not copy single sided. 0800 Jam but will so may other functions...
the service manual says to replace the main pcb before you do this try to upgrade firmware even if it is current or try a different ADF the DIMM could be the problem if the board has 1 try cleaning the contacts with an eraser welcome to Kyocera repair
Mar 07, 2017 | Kyocera Office Equipment & Supplies
HOW TO FIX...PRINTER IS OFFLINE BUT IT IS ON...WE ARE UNABLE TO PRINT.
If you are getting a status message as the printer is offline on your pc,and afterward you can't ready to print the reports.
Steps to Resolve the Printer Offline Issue:
Step 1:
At first, you need to check your network through the HP Scan Doctor which encourages you to discover and fix the printing issues.
Steps To Run the HP Scan Doctor
    •Open the HP Scan Doctor tool by double tapping the symbol.
    •Start- - >Select your printer- - > Fix Printing
    •Then the list of issues displayed on the screen as result.
    •If the tool shows the white checkmarks at that point there is no issue.
    •If the tool shows the white wrench then the issues are found and repaired
    •If the tool shows the yellow shout point then the issues are found however that can't be solved or skipped.
    •If the device shows the red stamp then you have to take after the on-screen guidelines to determine the issues.
    Step 2:
      Set Your Printer as Default Printer
      •Search your gadget on your PC and select your printer and uncheck the Pause Printing and Use Printer Offline
    •If you can capable print implies your printer is online.
    Officejet 4650 keeps going offline then proceeds with following step Step 3:
    Check Whether You Connect With Correct Port
      •Go to printer- - > Printer Properties - >Port
      •For USB association utilize USB or DOT4
      •For Network Connection use WSD, organize, Standard TCP/IP Port Step 4:
      •Update the printer firmware which may resolve your issues
      Step 5:
      •Manually connect the wired or wireless connection
      Step 6:
        •For network connection just you have to add the second printer to your Windows.
        •Select your printer - > Properties - >Add Port - > Standard TCP/IP Port - > Next port
        •Now you can ready to print implies stop the troubleshooting. Still get the same issue mean you need to connect the printer customer support via +1-800-836-3987
Jan 08, 2016 | Office Equipment & Supplies
Kyocera 4050 copier scan to computer very slow.printing ok. connection ok.scaning take 2 or 3 minuts .how to solve ?
firmware upgrade for sure but what is the scanning protocol? scan to smb? scan to smtp? scan to ftp? usb twain? network twain?
Nov 11, 2015 | Kyocera Office Equipment & Supplies
Buying the Best Multifunction Heavy duty Printer
After looking at specs I would say the Kyocera TASkalfa TA-3051Ci but I never used nor worked on one
Jul 05, 2017 | Kyocera Office Equipment & Supplies
My kyocera taskalfa 180 do not print. operator can not find out any problem. he has checked major 3 unit.
All new copier/printer has safety pacageging SCREW /TAPES to prevent damage in traveling/shipping w/ it your Kyocera taskalfa 180 won't print, look for it and remove it all usually it is color orange 1 of them located at Optics unit .
Nov 21, 2014 | Kyocera Mita TASKalfa 180 Black Toner...
300ci will not copy 2 sided documents
from the copy screen touch the duplex button on the display and choose 2 sided > 2 sided. if it is not available in the menu the duplex unit may have failed repeatedly and shut itself down in which case you would need to go into simulation mode and perform a u906.
Sep 29, 2014 | Kyocera Taskalfa 300ci With Feed, Bank,...
Document scan to SMB for w8.1 pro for
That model does not support scan to smb
the only scanning it support is
TWAIN (scan-to-Pc and Scan-to-Email only via Software QLINK
Aug 19, 2014 | Kyocera Mita Olivetti D-Copia 163Mf...
My kyocera taskalfa 180 asking me to call service C6000. How can fix this error?
My kyocera taskalfa 180 shows an error.call service c6000.what should i do
Jun 30, 2012 | Kyocera TASKalfa 180 Copier
My kyocera taskalfa 180 showing c6400 error please help.
C6400 is a fixing unit error.
To reset -
Try this, enter "10871087" from keypad, You should now be in maintenance mode.
Enter "163"press "Start / Print" key.
You should see a screen that says "Execute".
Cursor / highlight "Execute".
Press "Start / Print key.
The machine will turn off and should come back to ready. If not then you need to replace the fixing unit.
I hope this is helpful,
Shawn
Feb 25, 2011 | Kyocera TASKalfa 180 Copier
Free service manual with code for kyocera TASKalfa 180
Pls. send Free service manual with code for kyocera TASKalfa 180.
My email itechf2@gmail.com
Especially interisuet off hibernation.
Aug 05, 2010 | Kyocera TASKalfa 180 Copier
Copystar Kyocera Taskalfa 520i Multifunctional Copier, Prin Logo
158 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Timothy Van Der...
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
