The pins on the USB cord seems to be a bit twisted
I was using it frequently and then all of a sudden, the USB wouldn't go inside the port. I looked at the usb and the pins seem to be a little raised.
    Sergeant:
  • 206 Answers
Hi
you may need to replace the usb cord but be careful you dont damage your usb ports.
another option for you is to buy a hub which plugs into to your usb port and provided 2 or more usb ports for you to use.
this will help stop and damage to your laptop ports
cheers
Posted on Nov 28, 2012
  • 3 more comments
  • latha_nair
    latha_nair Nov 28, 2012
    We just travelled to India yesterday and will be here for a few months. I will go to a computer store tomorrow and see if they can replace my usb cord.
  • latha_nair
    latha_nair Nov 30, 2012
    I haven't had time to go get another cord. I will try and get another cord. Will let you know. Thanks for trying to help.
  • Aries Nov 30, 2012
    Hi i hope im talking about the right cord USB cord and not the Ethernet cord for the internet connection either way replacing them will help your situation cheers
  • latha_nair
    My husband was looking at the cord and thinks that it might be a usb3 and might need an adapter to go into a usb2 port. Could that be right? But, I've been using the same cord for the laptop before and there was no adapters for it.
    Hi all USB cords are the same, its the data transfer speed on the pc or laptop that has increased to accommodate USB speeds of 1 2 or 3, heres some pics to help pic 1, standard usb cord pic 2, small and standard USB cord pic 3, standard ethernet cord for internet pic 4, laptop power cord, pic 5, one design of a usb hub i hope this helps cheers
  • 52 Answers
SOURCE: after reinstalling windows xp on
you must install or update the USB drivers from the web
Posted on Oct 27, 2008
wayneard
  • 1901 Answers
SOURCE: replacing an ethernet port on my hp pavillion
Your ethernet port is probably integrated into the motherboard of your computer. Have you tried reinstalling the driver for the ethernet?
If the port is truly bad, my suggestion would be to purchase an ethernet card or NIC (Network Interface Card) and have it installed. You can get them for $15 to $25 at any big box computer store.
Posted on Nov 04, 2008
wayneard
  • 1901 Answers
SOURCE: Broken usb port, Acer desktop
May be hard to find.
If you have a spare PCI slot in your motherboard, I'd buy a cheap USB card and install it.
Here's some cheap ones online:
http://www.monoprice.com/products/subdepartment.asp?c_id=103&cp_id=10304
You may also be able to get one on eBay reasonable.
Posted on Nov 08, 2008
PaulRepair
  • 66 Answers
SOURCE: USB suddenly malfunctioning on Dell TOwer
It does sound like your ports on the front might be bad. They usually connect to a seperate port on the motherboard than the rear ones, and I have seen devices short out the front ports, such as a USB music player.
You can remove the ports on the device manager, and they should come back ok, without worry. However, I doubt that is going to help the front ones. I think you have a hardware problem.
If that is the case, the easiest solution is to get a USB hub, and run a USB cable from the rear, to the front of the computer.
Posted on Mar 28, 2009
rulds2008
  • 3866 Answers
SOURCE: Flashing Amber Light of Death DELL E510 -fixed-
You might have what they call a short back meaning the usb connector that was twisted inside those power 5v and ground could have cause a short thus giving you this death of the computer lights. I would R/O "rule out that this problem with the usb was not the cause of the death.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Jun 26, 2009
Usb port's pins are bent
Hi
usb sockets are normally pretty standard but without the make and model I could not be 100% certain.
https://www.beckettsmusic.co.uk/shop/scripts/prodView.asp?idproduct=18957
regards
Jul 29, 2017 | Akai Professional Akai LPK25 Laptop...
G 500 logitech freezes intemittently
I think i found the solution to the Logitech G500 mouse freezing problem: the 5-pin USB cable uses an embroidered thread of fine wire for the first pin on the left (black cable at the internal connector inside the mouse). These fine threads tend to break over time due to movement of the cord, it usually brakes by the point were the cord exits the mouse casing. what i did was actually very simple: I Opened the mouse (there's 5 screws you have to remove: 2 over the optical sensor, one underneath the sticker on the center, one on the right, and one at the bottom of the mouse), then remove the scroll wheel (and basically remove every screw you see on the inside of the mouse), there's also a pin holding the scroll wheel in place, remove that too. Now remove the circuit board and detach the USB 5-pin connector. Inspect the cable (you might have to remove some of the protective cover), if you find that the embroidered wire is broken, as i did, then proceed to twist the fine threads of wire on both ends, and then twist both ends of the broken cable togheter. Obviously the resulting cable is a bit shorter than the others 4... not a problem! simply align all cables and twist the excess wire forming a circle, and just tuck it in at the bottom casing of the mouse when you put it back together. This solution might not be the most clean and professional (perfect solution would be to replace the cord), but it only took me 15 minutes, and my G500 mouse is working perfectly since; hope it helps!
Dec 23, 2011 | Logitech G500 Mouse (910001259)
I have a Nikon Coolpix 7900 camera I purchased used. It came without the proper USB cord, so I purchased one separately. When I attached the camera to the USB port of my computer (and I've tried...
I'm afraid that USB port has been damaged and is drawing excessive current causing the error message. You are at least fortunate in that your computers' ports are protected since the camera could have otherwise caused damage. Using a basic multimeter one could probably measure across the pins 1 & 4 to determine if the camera's input is shorted; it should in no case measure less than 5-6 Ohms regardless of lead polarity. The current capability of a USB port varies by version but is between 500 & 900 Milliamperes.
Sep 23, 2011 | Nikon Coolpix 3200 Digital Camera
My external hard drive is not responding its making some type of sound I wouldn't call it a click more like a hump nosie, and it wont register on my computer, the light comes on but nothing is...
This few things can be the cause
  1. the usb port that the external is connect to is not 2.0
  2. the pc port is not supplying the required amount of power to the usb external
  3. you may be using a usb extension cord instead of connecting directly to the port
POSSIBLE SOLUTIONS
  1. Make sure that you are using the supplied usb cord or a very similar one
  2. change the usb port that the external is connected to (it could be a faulty low powered usb port)
  3. remove any usb extention card that is attached (leave on the supplied one)
  4. try connecting to a friends pc and see what happens
  5. during connection to the pc make sure no other usb device is connected
  6. maybe it is time to get a new external case. should not coat more that $15.
good luck
Aug 04, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
Usb device not working . can't get the scanner to work
see inside usb port & check all four pins are up or not. if pins down then put it up or replce usb connector.
Jul 10, 2011 | Canon CanoScan D1250U2F Flatbed Scanner
I have a PC 6500 watts generator. The 120 volt receptacle is already occupied. I have an appliance120volt/30 amps that has a 10/3 cord and is furnished with a standard 3 pin twist plug. How can I used...
How many amps is the 120/240 volt circuit? I can tell you how to split it into two 120 volt circuits. A twist loc cord end, a piece of four conductor cord, two electric boxes, two receptacles would be needed.
How many amps?
Nov 12, 2017 | Porter Cable 6,500 Watt Contractor...
I cannot connect to pcsuite its displays to be disconnected
Hi Piyush,
The problem seems to be with your USB port on either end. If you use your USB port (PC end) rarely then there's a chance of corrosion/oxidization that has formed on the contacts. Use a little bit of WD40. First take a small piece of good thick drawing paper (the ones used by kids in class to draw stuff on).
Fold it in such a way so as to fit it inside the PC's USB port. Now apply a few drops of WD40 oil on the paper's folded edge and insert the paper gently into the port and rub it (IN-OUT-IN-OUT) action. Now try connecting your cable & handset.
Assuming that you have a frint panel USB connector and if its still not working then there could be a loose contact problem with the 4 pin USB motherboard connectors. Switch OFF the PC, remove the side cover and see where the wires go on the motherboard from the front panel.
VERY IMPORTANT: CAUTION, BEFORE REMOVING THE 4 USB PINS FROM THE MOTHERBOARD, WRITE DOWN ON A PIECE OF PAPER THE SEQUENCE THEY ARE PRESENTLY CONNECTED AS YOU WILL HAVE TO RE-CONNECT THEM IN THE EXACT SAME MANNER. A WRONG CONNECTION WILL CERTAINLY DAMAGE YOUR MOTHERBOARD BEYOND REPAIR. THERE ARE 4 PINS: Refer Diagram Below:
Remove the pins one by one, apply a little WD40 in the sockets of the black, square cylindrical sockets and place them back and restart your PC.
It should work now.
Nov 06, 2010 | Computers & Internet
Registration Failed
Hello Risas,
This is a known issue with this product that requires a software upgrade to resolve. Please download "SoundStation2W Software Upgrade" from the Product Support page of our website and follow the included instructions. If you need any assistance please don't hesitate to call for assistance at 1-888-248-4143 Options 2, 4.
Regards,
James
Jun 04, 2008 | Polycom SoundStation 2W (2200-07800-001)...
Computers & Internet Logo
David Payne
David Payne
