Question about Electrical Supplies
Will a missing air filter on a coleman powermate 4200 watt generator cause it to pop and crack when it runs?
I have put a new carb on it and fresh gas. It is missing the air filter, but it pops and cracks when it runs
SOURCE: Need to know about this
To find a manual for this generator go to powermate.com and search your model and serial number. Good luck!
Posted on Mar 16, 2009
  • 7 Answers
SOURCE: coleman powermate 5000 watt generator leaking oil
CHECK OIL LEVEL. MAY HAVE TOO MUCH OIL IN CASE.
Posted on Oct 15, 2009
  • 5603 Answers
SOURCE: Coleman Generator starting problems
If you started it for just a minute, it never got warmed up and MAYBE the spark plug fouled. Check it first.
Sometimes one forgets where to set the choke for starting. And if engine is already warm from a short run they can be hard to start if too much choke is used and it floods... Again, when you check the plug, if it is wet this MAY be the problem.
To check fuel getting to the engine I have used an UNLIT propane torch into the carb to give an engine a mixture that it can run on without flooding. You usually have to remove the air cleaner to do this. That is a trick I have used for "cranky" engines.
Since you stired up the gas, the fuel filter may have got plugged.
Posted on Apr 17, 2010
  • 905 Answers
SOURCE: I have a Coleman Powermate 4000 watt generator.
Hello Pete,
Is fuel actually leaking from the bottom of the bowl, or is leaking out the air filter and running down to the bowl?
If the former, then your bowl bolt's gasket has likely deteriorated. This would allow fuel to run down the bolt itself. Note that some carburetors will have a fuel shutoff solenoid (to the engine, not to the carburetor) that holds the bowl on, rather than a bolt. There will still be a gasket though. Turn fuel off before trying to service.
If fuel is running out from inside the carburetor (through air cleaner, etc), then you have a float / needle that is stuck. This is quite common after a small engine has been in storage and fuel was left in the carburetor. The residue causes the float to stick to the bottom. Turn the fuel off, undo the bolt that holds the bowl on, and carefully remove the carburetor bowl. Use a can of carburetor and choke cleaner to spray out the "gunk" in the bowl, spray off the float, and then reassemble. If it still leaks, then your needle seat will need to be replaced as well.
Posted on Sep 15, 2010
  • 3 Answers
SOURCE: i have a coleman powermate premium plus 6250
if you are running the engine at full CHOKE, then it is flooding the engine, but if you meant off full choke, then the carb is still stopped up. Try soaking in carb cleaner overnight after removing jet & all rubber goods. HOPE THIS HELPS.
Posted on Jan 17, 2011
I have a coleman powermate pulse 1800ex generator. It stutters when put in the run position. when in the choke position it doesnt stutter.
your main jet is plugged shut off fuel, remove bowl from carb(bottom of bowl) clean out small holes on screw with stranded wire .2 holes on side on in middle. be sure to put fiber washer back between main jet and bowl and use fresh gas jor
Jan 11, 2011 | Coleman 1850 Watts Generator Each...
Hello, I'm trying to get an old Coleman Maxa 5000 ER Plus to work again. The interesting problem is that i can get it to start and run, IF i squirt gasoline into the carb throat with a squirt sprayer, but...
First make sure you have fresh gas in the tank, as old gas can cause a 'no run' condition. Once you have fresh gas in the tank, make sure the gas flows freely all the way to the carb by removing the fuel hose from the carb inlet & checking for good flow (bad shut-off valve or obstructed hose by debris could cause same problem). Once you are sure that good, fresh gas is going into the carb w/o obstruction, remove the lower bowl from the carb - carefully - do not lose ANY parts, starting with the washer on the bolt. With fuel flow 'ON', fuel should flow freely when this bowl is removed, so shut off fuel valve in the hose. Now, if you carefully remove the bolt / brass tube from the center of this bowl area (center of plastic float) - remove bolt downward, like you would a lightbulb from the ceiling - this bolt should have several holes in the side, they are probably clogged, so unclog them with a needle or wire, wipe clean, and reinstall. That probably just solved all your problem.... if not, you likely will want to replace the carb completely, as it is not very expensive, and will surely solve your problem. *** Be careful with gas fumes !!! ***
Dec 21, 2010 | Coleman Powermate Powermate 5000W...
I have a coleman powermate premium plus 6250 generator,put in new plug ,new filter ,changed oil,cleaned the carb,put in new gas. runs ok at half choke but when go full choke it starts backfiring and runs...
Dec 17, 2010 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate 5000 with 10 HP Tecumseh engine. It had a float problem and leaked gas out the air filter. I replaced the float and stopped the leak, but now it won't start. It will start if engine...
I have a Coleman Powermate 5000 with 10 HP Tecumseh engine. It is very hard to get started. once started runs great . But when you shut it off and try to restart it it will not start.
I have plenty of fire. I also replace the carb.
I still have problems getting it started. I tried to start it with out the filter also. What can i try next?
Thanks for any help
Jun 18, 2010 | Coleman Powermate Powermate 5000W...
Apr 16, 2010 | Coleman Powermate Powermate 5000W...
Coleman 10 hp generator, not in use for 3 yrs. put gas , wont start. thanks for help.
couple things you can do . drain carb and put new gas in , check air filter ( take it off and try to start with filter off ) , open petcock , and finally take shroud off and sand the rust off the flywheel where magnets are . let me know what you find , xrsrule2@juno.com
Apr 10, 2009 | Coleman Powermate Powermate 5000W...
Powermate 5000 leaks gas from the air filter..not sure how it's getting into the air filter?
My Coleman Generator 5000w with a Tecumseh 10hp story. Mine engine finally did die before I pulled the carburator off.
On mine the float was defective. It was full of fuel! I repaired the hole in it. I removed the air filter and saw fuel pouring out the side so much that I had a jar to catch it. I removed the carburator and took the nut off the bowl to examine the float. Then I removed the pin holding the hinged end of the float. Carefully pulled it out with the needle valve attached. When I removed the needle valve (just slides on mine) it was free to test. I tested by shaking it near my ear and I could hear the fuel inside the float. Mine was brass or copper. I wiped mine off with a napkin and finally found the hole. I drained the fuel by polking a needle sized hole and removed the fuel. I then soldered the hole shut with using just electronic 60/40 resin solder and a small soldering iron. Mine works like a champ now.
Mar 08, 2009 | Coleman Powermate Powermate 5000W...
Electrical Supplies Logo
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
