Question about Sony DAV-BC150 System
Power light just blinks
Surround sound quit working. We were turning it up and it just quit. now all it does is to standby (power) light blinks. Please help!
We did fix the problem our selves. We unplugged the unit and waited a few minutes and plugged it back in and it started working again.
Posted on Oct 30, 2007
Did you ever get this problem fixed??? Mine does the same thing.
Posted on Sep 18, 2007
I have this same problem, it is so frustrating, some movies it will play, and sum movies it will shut of in the middle of it and just blink. You have to un-plug it and plug it back in for it to work.
Posted on Aug 20, 2007
All of a sudden stopped working and won't turn back on. been 12hrs. when power is pressed, it turns on for 2 seconds and then standby lights blink again and it turns off
This could be caused by a direct short circuit on the speaker outputs. Try disconnecting all the speaker connections at the back of the receiver and then power back on. You can also try a factory reset by holding the surround mode + clear button for 3 seconds.
Feb 14, 2016 | Marantz SR7005 Receiver
My pioneer surround sound system has stopped working cannot turn it on and the hdmi light just flashes
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Dec 15, 2015 | Pioneer Audio Players & Recorders
My Denon AVR-75 seems to stay in standby (red standby light is on) and I don'd get surround sound through it. How do I get it out of standby?
if the receiver does not power on from standby there is a problem like bad power supply or even bad macroprocessor. You need to bring it to a service center for diagnosing. 10-years old receiver, maybe better to buy new one.
Nov 23, 2011 | Denon AVR-75
Why does my tv not come on but power light just
tv will not come on sound will for a little bit and then quit but the standby light blinks 10 times
Feb 03, 2010 | Philips Magnavox 9P6034C 60" Rear...
Marantz SR6001 AV Surround Receiver - Blinking Standy Light
I have exactly the same problem! Sometimes when I turn the input dial it comes back on but this time it is out for good. I have tried re-wiring and unplugging etc. nothing seems to work.
Jan 21, 2009 | Marantz SR6001
Sony KDF55WF655
TURN TIMER OFF OR, The STANDBY light is flashing on the television and there is no picture or sound. Solution
sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
Jan 21, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
50 inch 1999 TheatreView Television
#1 When I turn on the TV the power button comes on then blinks 6 times then goes off for a few seconds then repeats the cycle. I have sound over my surround system during this time but no picture.
#2 My sound would crackle and pop every once and a while until now it does nothing. I have to watch it with the surround sound on.
Nov 26, 2007 | RCA HD52W59 HDTV Projection Television
Blinking Standby
regarding the Pioneer VSX-912 blinking standby light. This is how you reset it; press the "advanced surround" and the " enter" at the same time for about 3 seconds. Make sure you press the ENTER on the reciever (its the one on top next to the small dial) If you press the "ON" instead of "ENTER" it will not work. If an error message comes on and shuts the unit down, just reset it again. This should save you some $$$$. To bad Pioneer did't put this info in the manual.
May 22, 2007 | Pioneer VSX-D912 Receiver
Receiver just blinks standby will not power on
I have been so bummed, days now I have tried to get my Pioneer receiver to power on from standby with no luck.  We now have our receiver back, the same solution worked for us. Be sure to push the buttons on the receiver unit not the remote.  Thank You! Thank You!
Jan 30, 2007 | Pioneer VSX-D812 Receiver
Sony DAV-BC150 System Logo
255 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
