Question about Hoover Washing Machines
Nead to know the wire from elemant to the controwl
    Top Expert:
  • Hoover Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 28, 2012
Spinning but not getting hot
first you nead to use a meter to make sure you have 220 at the outlet.if you do than unplug the dryer and pull the dryer away from the wall so you can remove the back panal and the power cord cover.from the back of the dryer look to the right and you will see the heating tube.at the top of the tube you will see the high limit switch.remove the wires from the switch.use a metter to make sure the switch is closed. if it is open you nead to replace the switch.if it is closed than you nead to look down the tube and you will see the next high limit switch. remove the wires from the switch and check that it is closed.if it is open than replace it.if it is closed than under the switch you will see the heating element.remove the wires from the heating element and check the element .if it is open than you nead to replace the element part#3403585.
Jan 16, 2010 | Whirlpool LER4634J Electric Dryer
My REX4834KQ dryer will start, but doesn't get hot. It also will not turn off automatically anymore!
first make sure you have 220 going to your dryer.in alto cycles the timer will not work if the heating element is not working.next you nead to remove the back panal and the power cord cover.if you look to the right you will see the heater housing.at the bottom you will see two wires going to the heating element.remove the wires.with a meter check the element to see if it is open.if it is than the element is bad.part#3403585 if not than we nead to move up.check the next high limit switch to see if it is open.if it is than it is bad.next we nead to go higher to the hi-limit tgermostat at the top of the heater housing part#3977393. if it is open than you nead to replace it.
Dec 09, 2009 | Roper REX4634KQ Electric Dryer
I'd like to know how to change a heating element in my dryer (29' whirlpool) I'd like to know exactly how to take it apart and where to find the element. I'am not sure of the dryer #
first you nead to unplug the dryer,next you nead to remove the vent hose,next you nead to remove the back panal and the power cord cover,on the left side you will see the heater housing,at the bottom you will see the heating element,there are four wires,the two at the bottom are hooked to the element,you nead to pull them off,the other two wires are hooked to the high limit switch,you nead to pull them off,next there are two 1/4"screws,one on each side off the heating element,remove them,now pull out on the bottom of element,with element removed,remove the high limit switch from old element and put it on the new element,take new element and put it back in the heater housing and replace the two 1/4" screws,you will see that the two wires that go to the element are biger than the two going to the high limit switch,put the two wires to the element,now replace the two wires to the high limit switch,replace the back panal and the power cord cover,replace the vent hose,plug power cord in and check element out.
Nov 25, 2009 | Whirlpool LER5636P Electric Dryer
DRUM WILL NOT SPIN AND MAKES HUMMING NOISE AND TURNS OFF WITHIN 5 SECONDS
you will nead someone to help you to know if you have a bad moter.first you nead to open the door,with your right hand you nead to push in on the door switch and hold it in.next you nead to have someone puah in on the start switch,at the sam time ,you nead to take your left hand and turn the inner drum clockwise, if it starts than you have a bad moter.
Nov 18, 2009 | Roper REX4634KQ Electric Dryer
I have a Kenmore special edition model # 110.63912100 (S/N ML350387S) that will not heat. What do you suggest, heating element, thermostat, or ???
first make sure you have 240 going to the dryer.you will nead a meter check this.if you have 240 ,than you nead to unplug unit.pull unit out and take back panal off.on the right side you will see the heating colom.at the top is one of the high limit switch's.you will nead a continueaty meter to check this.at the bottom you will see the other high limit switch.make sure you unplug wire's before you check them.under thst you will see the heating element.remove wire's and check out element.also look for bad wiring.if all check good, you nead to call for service call.
Nov 16, 2009 | Kenmore 62802 Electric Dryer
My Roper dryer won't start?
first make sure you 220 going to you dryer.next you nead to unplug the dryer.next you nead to remove the vent hose.next you nead to remove the back panal and power cord cover.on tge lower left side you will see a white plastic switch with two blue wires going to it.this is the thermal switch.if you use a meter and the switch is open tha you nead to replace this switch.part#3392519
Nov 11, 2009 | Roper REX4634KQ Electric Dryer
The black wire burnt off on the line going into the heating elem
No, you do not need to remove the drum. But you will need to remove the cover from the blower assembly. Using a volt meter, check the elements continuity to determine if it is bad or good.
Apr 16, 2009 | Whirlpool LER5636P Electric Dryer
Washing Machines Logo
35 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
