Question about Toshiba Satellite A200-0ET00X Notebook
Did a repair on toshiba laoptop a200 satlite
The power fan for cooling need to know the black red yellow wire have to go thanks
  • fwilkins_4 Jan 12, 2009
    thanks for the reply found a picture of how the wires run
Dear sir,
i have buy toshiba statellite pro in dubai 2008. but shope men not give me any other cd to driver and sfothwere. so pl sport me to this help.
Posted on Aug 29, 2009
Wire diagram for the a/c cooling fan.. 1991 Jeep Commache
I am sorry but fixya doesn't have any wiring diagrams. They are copyrighted and not free to share.
Jul 22, 2012 | Jeep Comanche Cars & Trucks
Need to know what the four wires are for, red black yellow and blue, I am wiring it to and ancient apple, no choice. just need to know how to set it up at hi speed constant operation. I am using a rf-120...
Usually the red is +12 volts DC, the black is ground, the yellow is the tach sensor, and the blue is speed control. The fan will run at full speed off the red and black. The yellow and blue are of no use unless the motherboard is designed to use them.
Mar 29, 2011 | Rocketfish Gaming 120mm Case Fan RF-120FAN...
I cut and stripped the fan wiring and it has 4 cables coming out of the fan. A blue cable. A yellow cable. A red cable. A black cable. Please help me find out how to wire this into a battery so that I...
The red is positve (+) 12 volts. The black is negative (-) ground. The yellow is sensor (RPM) and the blue is control (PWM). Don't use the yellow and blue. If it's going to run it will be off the black and red.
Jan 14, 2011 | Intel (8W501B1M3G) CPU Fan, CPU Cooling...
Need help wiring this theromostat. I ahve the following color wires.....Green Red Black Blue White Yellow and Orange. Need to match them to the following connections: G RC RH Y/O W/B Y1
G= Green Wire (Fan) RC= Red Wire (Power Cooling) Y1= Yellow Wire (Cooling Contactor) RH= Black Wire (Power Heating) WB= White Wire (Heating Control) YO= Orange Wire (Damper Control)
Blue Wire is usually to C= Common
Nov 28, 2010 | Heating & Cooling
I have a Goodman PHK036-1 unit outside and it had a Lennox Thermostat. I want to replace it with a Lux DMH110 Thermostat and I need to know the wiring for this. I had someone help me last night but the...
Disconnect all wires to start.
1)Go out to unit shut off power and remove electircal panel.
2) Locate the terminal board where thermostat wires are connected. Write down where each color goes to
each letter and then try to do this at the thermostat.
R= Red wire= Power
G= Green Wire= Fan Leg
W or W1= White Wire= Heat Leg
Y1 or Y2= Blue or Yellow Wire= Cool Leg
C=Brown or Black or Orange= Common if used
Jun 27, 2010 | Heating & Cooling
Honeywell RTH230B cooling problems...
I printed out the instructions for your thermostat. It looks like you should have the following.
There should be jumper wire between Rh & Rc
Red wire to Rh or Rc whichever is easier since there is a jumper. This is the hot wire and all the thermostat does is connect to route it to the components needed for heating or cooling.
Blue wire, tape it up and don't use it. There is no spot on this thermostat for it. It is only used on thermostats that are powered by the transformer.
White wire to W. Powers the heat relay
Yellow wire to Y. Powers the cooling contactor
Green wire to G. Powers the indoor fan relay
There is a black jumper on the back of the face plate. Look at section 2.4 Setting J2 Jumper in the installation instructions. Make sure you have it in the right position for what you have. If you don't have them just google them.
Hope this helps.
May 24, 2010 | Honeywell Electronic Programmable...
Exchange a cpu fan connector
You can connect it red to red; black to black; and yellow
to white. That's it. Hope this will help you.
Dec 12, 2009 | R.A.M. Computers 486 CPU COOLING FAN WITH...
Toshiba a200 flashing power light .. blue blue red red HELPPPPPPP
Remove battery and power
Remove memory in lower socket, the one on the system board and try reboot with just power cord. May have bad socket
Dec 11, 2009 | Toshiba Satellite A200-0ET00X Notebook
I have got a Toshiba Equium A200 series that won't bootup
if the fan is not running continuously then its the fan ans board problem.because the board is getting hot and fan is not running so the board is getting overheated and the machine is nor working.and if the power light is ON and fan is running but only the screen is black/blank then its the problem of inverterboard.the cost of new board is $25 get it replaced fromn near by laptop repair center. thanks.
Aug 30, 2009 | Computers & Internet
Replacing Old York TS to HoneyWell RTH230B
rh is hot for heating rc is hot for cooling looks to me like ya need a heat pump stat some thing to control the reversing valve.Tom
Jun 18, 2009 | Honeywell Electronic Programmable...
Toshiba Satellite A200-0ET00X Notebook Logo
183 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
