Question about Spectra Hello Kitty Digital Alarm Clock & Night Light
Looking to buy replacement light bulb - Spectra Hello Kitty Digital Alarm Clock & Night Light
2011 Ford Escape driver side tail light not working correctly - lights are on but turn signal flash not working and neither is the brighter brake light
I would guess that you need a new bulb. Many of these tail lights actually have two filaments inside them, one that is used for a dimmer light (running light) and one that is used for a brighter light like (brake light, turn signal). The easiest thing to try (and probably the cheapest) would be to buy a replacement bulb and change it. Most places that sell automotive light bulbs will have a large catalog where you look up the make model and year of the car you need a light for and it will tell you which replacement bulb you will need. Then look in your cars manual to see how you access and replace the bulb.
Jan 30, 2015 | 2011 Ford Escape
2004 jeep grand Cherokee back brake and night lights not working reverse is fine
I had the same problem. Check bulbs in fact buy new ones. I had a bad bulb although it looked fine. Then it is how you twist them in and sometimes it is the contacts where they touch are cleaned ( or even pry'd up with a pocket screwdriver just a little). Oxidation was what I ran into and bad about to go out bulbs. If you overturn or overtwist they also will not work. They are not so cut and dry..,play with it a little more!
Jul 26, 2014 | 2004 Jeep Grand Cherokee
Trileaf distribution trifeuil
Check and replace the bulb. Make sure your charger has power coming out of it. Also, depending on how long you have owned this the battery could be shot. Just as cheap to buy a new light as it is to buy a new battery.
Jan 11, 2014 | Vector 2M Pwr Rch Spotlight
How to replace check engine light bulb on 1999 Chevrolet Blazer?
You must remove the entire instrument cluster to access the bulb.
Aug 29, 2012 | 1999 Chevrolet Blazer
How to change headlight 2003the x type Jaguar
look inside owners manual in glove compartment look up bulb replacement in the back index it will show and tell you how to replace headlight bulbs. be sure to wear clean gloves, because headlight bulbs or halogen type bulbs, if oil from hands or skin touch the halogen bulb it will cause halogen light bulb overheat and blow out.you can go by auto parts store when you buy new headlight bulb the salesperson will go out to vechicle and replace headlight bulb for you wont charge you any thing.just charge you for the headlight bulb.
Feb 12, 2012 | 2003 Jaguar X-Type
The light bulb keeps blowing out. Have the wires or socket gone bad and can that be replaced?
Remove the bulb and look closely inside the socket. If you see any evidence of burning or that it has been hot, replace the light socket. You can buy a replacement that will work at most any hardware store.
Feb 04, 2011 | Kenmore 51041 Kitchen Hood
No brake or rear turn signals Replaced flasher.still no go.bulbs O K
replace the relay or fuse for the rear tail lights if this doesn't cure it the replace the light switch,how did you check the bulbs they could still be bad even if the filaments look good,just for good measure I would buy new bulbs to be absolutely sure then the relay.
Hope this helps
Feb 13, 2010 | 2002 Ford Mustang
2005 Honda CRV dome light goes out, but not burned out
Filament gets fractured, possibly by vibration of the roof lining. I have replaced mine 4 times and while the bulb looks OK it is high resistance, buy a few bulbs and replace them when it occurs.
Mar 31, 2009 | 2004 Honda CR-V
Need part number for oven bulb
looked up the bulb part is no longer available, but it looked like a regular appliance light bulb, remove the old one no diffrent then any appliance bulb you can buy in the supermarket if need be
Feb 19, 2008 | Ovens
Spectra Hello Kitty Digital Alarm Clock & Night Light Logo
Top Spectra Toys Experts
ray gallant
Are you a Spectra Toy Expert? Answer questions, earn points and help others
