Question about KitchenAid KSB5 Ultra Power Work Top Blender
I have a Kitchenaid blender model KSB5BU3 marked "Ultrapower" and "Electronic Control" on the side. Suddenly all the buttons started blinking together after we pressed the On button and then one of the speed buttons and the motor does not start. I assume the chip or other electronic part has failed. Is this correct and if so can the unit be fixed or must it be thrown out? Thanks for your advice. **** Hall
  • 145 Answers
When the lights are flashing, this does indicate that an electronic part has failed. This blender is no longer manufactured, so finding replacement parts for it may not come easily. Repair centers are available. I would recommend calling Kitchenaid Customer Service to see what they can recommend for you.
Their toll-free number is 1-800-541-6390.
Posted on Jul 07, 2009
Blender won't start
Test motor for continuity, if open circuit locate thermal fuse in windings and replace it. If not open circuit check cable for continuity, if that is ok you are likely looking at a new button control assembly.
Mar 12, 2014 | KitchenAid Kitchen Aid KSB560 5 Speed...
Need manual for model #ksm90P SWH
KitchenAid appliance manuals are available from their customer service site: http://www.kitchenaid.com/flash.cmd?/#/page/customer-service . On the right, see the link for Locate Manuals and Guides.
KitchenAid lists 3 models that start KSM90PSWH. The direct link to the manual for the KSM90PSWH0 is http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209707917.pdf . If this isn't your model, see the KitchenAid site. (The other models are KSM90PSWH1 and KSM90PSWH-1.)
I hope this helps.
Nov 09, 2011 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
When I turn my blender on, it runs for only a few seconds, then stops and all the lights on the panel flash on and off.
More often than not it will need the motor to be replaced, only Kitchen Aid parts will do, motors are usually unique to brands and models. Sometimes it can be the control/button panel but normally the motor.
Mar 21, 2011 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Ksb 560 mco 5 speed blender lights flicker a as soon as switched
My Blender Model number KSB560MCO does not run. When try to blend all of red lights come one and they blink and move around. Any suggestions what could be wrong? Appreciate any help.
Thanks
Jul 30, 2010 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
All lights blinking on my blender
This error was probably not caused by replacing the coupler, but merely coincidence.
You may find a Kitchenaid certified service location using the following link:
http://caservice.kitchenaid.com/
If this is not helpful, I would recommend calling Kitchenaid Customer Service to see what they can recommend for you.
Nov 28, 2008 | KitchenAid KSB5 Professional Stainless...
Kitchenaid help
Aug 21, 2008 | KitchenAid KSB5 Ultra Power Work Top...
Blender blinks
need to resolder the triac located on the Printed circuit board this part is on an aluminum heat sink, and the third leg is most of the times the one with a broken or poor soldering joint due to the vibration of blender
Dec 27, 2007 | KitchenAid KSB5 Professional Stainless...
Blender won't work
This indicates an internal problem with the blender itself as pertaining to the motor. I would suggest contacting Kitchenaid Customer Service to see about having the blender repaired or possibly replaced.
Their toll-free phone number is 1-800-541-6390.
Also, a listing of Kitchenaid certified repair facilities may be found at the following link:
Sep 06, 2007 | KitchenAid KSB5CR Chrome 5 Speed Blender
Blinking lights on KitchenAid blender
Alternating blinking lights on a Kitchenaid blender indicate a bad circuit board which is unable to run the motor properly. Unplug the blender, take the jar off, and turn the spindle by hand. Then plug it back in. If it does not work properly, try a different outlet (perhaps not in the kitchen). If nothing works, the blender needs to be repaired.
Aug 27, 2007 | KitchenAid KSB3 Classic Work Top Blender
KitchenAid KSB5 Ultra Power Work Top Blender Logo
789 people viewed this question
Top KitchenAid Blenders Experts
Appliance engineer
eyecam
Are you a KitchenAid Blender Expert? Answer questions, earn points and help others
