Question about Toyota Hilux
My toyota hilux d4d makes a noise from dashboard when i take off from stop, what should do to stop noise?
Pinging noise inside the dashboard
I had a noise dash and when I removed the sat nav I had loose connections knocking against the metal frame , secured them and no further noise. Hope this may help.
Posted on Mar 29, 2013
Tilting backseat
glove box book
Hilux D4d Manual - lux-roc.com
www.lux-roc.com/hilux/hilux-d4d-manual.pdfToyota hilux tiger d4d sport cruiser manual pdf ' pdf owner ... Dec 05, 2014 Download Link: Pdf Download Toyota Hilux 2005-2011 Auto Repair Service Manual, ...
Oct 10, 2016 | Cars & Trucks
I own toyota hilux 2kd d4d that has a morning cold hard start, after first start all is ok
Excellent answer... short & spot on...
(except YOU didn't mention "OIL CONSUMPTION")
toyota hilux 2kd d4d... Not getting a lot of domestic... (USA)
DIESEL information... here (sorry).
From Bill Boyd here in 1994"
Toyota hilux pick up D4D has hard start in the morning but ok after the...
Jul 24, 2016 | Toyota Cars & Trucks
Alternator not charging
If the light is out, then you have to find the main fuse in the under hood fuse panel. It will be around 150 to 175 amps. Also check for a smaller alternator fuse.
Dec 25, 2015 | 2007 Toyota Hilux 2.5
Dashboard and side lights not working on my 2010 Toyota hilux, can you advice
Dashboard and side lights both run through a fuse, usually the same fuse, so this is your first point of checking. Go through all the fuses, make sure you check the fuse box in the engine compartment as well as the one inside the car.
Mar 02, 2015 | 2010 Toyota Hilux 2.5
How much engine oil do I put in a toyota hilux 2.5 d4d?
HI,the 2,5l engines takes about 5l oil,but i would start to pour about 4l and then topping it up gradually while checking the oil level.Good luck.
Make sure you are using the oil recomended by the manufacturer,and dont forget to change the oil filter and the air filter as well,that sometimes can make a big difference.
Nov 01, 2014 | Toyota Hilux
Why does my toyota hilux d4d 2008 have a hard "clap" sound when chaning gears, releasing the clutch?
hard to be sure with out hearing the noise, two things I have come across in the work shop . Loose or broken engine mount. Or broken springs in the clutch driven plate. a worn throw out bearing can make a noise when the clutch is in use.
Sep 17, 2014 | Toyota Hilux
How to connect a toyota hilux d4d denso alternator with a 4 pin plug
how to connect a toyota hilux d4d denso alternaton with a 4 pin plug
Feb 22, 2013 | Dodge Grand Caravan Cars & Trucks
D4d smoking
try wynns/redexe to clean injectors/lines,they do seem to smoke a lot though....
May 02, 2010 | 2004 Toyota Tacoma
Toyota Hilux Logo
215 people viewed this question
Top Toyota Toys Experts
Thomas Perkins
Thomas Perkins
Rabbit Brains
Rabbit Brains
Stan Ford
Are you a Toyota Toy Expert? Answer questions, earn points and help others
