Question about Qwik Time QT5 Metronome
How do you switch it on and off - Qwik Time QT5 Metronome
If the nine volt battery is good, then you plug the cable from your speaker amp. into the connector on the bottom rear, it turns the instrument's pre-amp ON, indicated by a blue light. Do not turn the main amp on till both ends of the cable are plugged in......
Posted on Nov 28, 2012
  • Ayam Nov 28, 2012
    I am sorry, I am new on this site and I thought the question was re: A Stagg 3/4 upright electric base.
Not getting a 110 votts to transformer
Measured where? You're getting 110V on one side of the switch but not the other with the switch turned on?? - faulty switch. If you're measuring across two terminals of the switch, with the switch turned on, you should read 0 V. Switch off should read 120 V. Is there a fuse between the switch and the xfmr?
Jul 31, 2012 | Music
Wah wont always bypass when I let off.
The switch has probably failed or the pad that actuates it. These things take a beating. Verify that the switch is mechanically working, and then check with ohmmeter. The pad triggering the switch gets worn and fails to actuate the switch completely is common on pedals. The internal parts of the switches fail... NOTE: many of these switches have metric mounts and are hard to find exact repalcements.
Feb 12, 2011 | Behringer HB01 Hellbabe Wah Pedal
How to replace the light in the standby switch on a bugera 333 head ?
I don't believe the standby switch has a light, unlike the main power switch.
I can also understand why they don't include one due to electrical considerations. This switch switches hundreds of volts instead of the line power that the main power switch does.
I know the switches look similar, but these are available both as lighted and unlighted which the standby switch is the latter.
Jan 31, 2011 | Bugera 333 120-Watt 3-Channel Valve...
Some one broke off my power switch, I still have all the parts but the switch itself is missing the two plastic nipples on either side. Where/ how can I get a replacement/repair? -thanks
It is very hard to repair the internals of the switches and they are not too safe when you do so... best to replace the switch with a new one. Most of the switches are $10 or so max. Better hardware stores often have suitable ones or go to Digikey.com or Mouser.com and search for switch.
Jan 11, 2011 | Marshall MG100HDFX 100-Watt Amplifier Head
Red plastic cover over starter switch is broken. No power
If you can't get the power switch to work that is a good indication that it might be broken and the fuse has blown to protect you and the organ. At this point you have two choices. Get someone who knows what they are doing to have a look at it and replace the broken parts or if you feel comfortable with trying, do it yourself. You will have to unplug it from the wall and carefully take it apart until you can get at the switch. Before you do this though consider that you will at least need a new switch and fuse. The switch doesn't have to be an exact replacement it just has to be electronically equivalent. Make sure you have a place to buy the parts.Keep track of what you do and draw diagrams you can understand. Better yet if you have a digital camera take pictures. Once you have the switch out the info about the switch is usually stamped on the switch itself.Take the switch and fuse to the store and they should be able to sell you what you need. Replace the switch by reversing the steps you took to remove it. Do the fuse last and once the organ is assembled plug it back in and turn the switch on. I f you replaced the switch exactly the way it should be the organ will either work or the fuse will blow again. If the fuse blows you know there is something else wrong. At this point you will need help or if you are going further on your own you will need a schematic or a service manual. They are getting hard to obtain so you will probably be better off having a professional look at it. Please let me know if this helps.
Dec 02, 2009 | Boss Micro BR Digital Recorder
On/off switch not working anymore
Remover the switch and try to find a brand name on the switch. Search Digikey.com, Mouser.com, and allied electronics for replacement.
Nov 14, 2009 | Music
The distortion on my Boss DF-2 doesn't work. When I hit the switch it just comes on and then off
Sounds like a defective switch or bad solder joints connected to the switch. Boss uses momentary switches which turn on when the switch is pressed and turn back off when pressure is released. This engages a switching system. If the switch is engaging itself again while the button being depressed, it will cause it go off again. And a bad solder joint would do this too if the signal is not being jumped to the switching circuit properly.
Aug 13, 2009 | Boss Music
Need foot switch for this machine.
What you need is 2 unlatched switches 1 for the stop start function and one for the drum fill function.
I bought mine from my local music shop for £15 ea
Apr 21, 2009 | Alesis Sr 16 Stereo Drum Machine
Digitech RP 90 foot switch is not working
I removed the back cover, unscrewed the two (of 4) screws holding down the circuit board, replaced them again, and it worked fine.
Jan 11, 2009 | Music
Guitar amp channel switch repair
Replace the switch. You gave no make/model number for your amp but if it has a jack for foot pedal operation of clean/dist function then try that. (on most amps) it will switch in spite of a bad front panel switch.
Dec 21, 2008 | Music
Qwik Time QT5 Metronome Logo
80 people viewed this question
Top Qwik Time Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Qwik Time Music Expert? Answer questions, earn points and help others
