Question about Kenmore Side by Side Refrigerator
How to replace relay switch on compressor
Need to know how old relay comes off compressor
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 28, 2012
1994 olds cutless ciera ac compressor won't come on 134 ok in order for the compressor to come on the a/c comp control relay has to have 12v on pink lead this is tied into fan relay, all not worki
According to several Oldsmobile discussion groups online, the inline fuse is behind the glove box taped to another inline fuse. The wire is actually pink and black.
Aug 04, 2012 | Oldsmobile Cutlass Ciera Cars & Trucks
My whirlpool refrigerator/freezer is not cooling. lights come on, fan comes on...don't hear compressor coming on, not sure. coils are clean (they are in front). Don't know what to do next.
Switch off the fridge for few hours then before you you switch on check the continuity of the main power cord to the compressor which comes thrrough the main relay. Now the relay is activated by the thermostat/pressure switch/defrost timer.
So you will be able to trace the path of the power to activate the compressor. however if the relay clicks and shuts off the the capacitor must be checked or replaced. However if there is a heavy drain of current- use a clamp tester meter- the compresssor can be a suspect.
Please check this link for a idea of the parts.
http://www.espares.co.uk/advice/fridges-and-freezers/a/2/278/identifying-fridge-freezer-parts.html
Sep 06, 2011 | Refrigerators
HOW DO YOU REPLACE A START RELAY SWITCH ON A FRIGIDAIRE SIDE BY SIDE MODLE FRU26SA
Power off i.e unplugged
Open the back
Remove retaining clip on wiring side of compressor plastic cover.
NOTE wiring connections to terminals on the OLD relay. 1, 2 4 4 ect... make a simple wite color to terminal number sketch.
PULL off PTC relay WITH terminals by pulling HORIZONTALLY (Usually to the left / 9 O'clock position)
NOTE the thermal overload comes off WITH the PTC relay.
Remove wire from Thermal overload terminal and transfer the thermal overload to the new PTC relay.
Slide NEW PTC relay onto compressor terminals
Transfer remaining wires from OLD PTC to the correct terminal on the new PTC relay.
TEST compressor start before installing cover... PLUG in unit
After the test unplug the unit... reinstall the plastic cover and wire clip.
Reinstall back panel
Return unit to service.
Thanks for choosing FixYa
Kelly
NOTE the thermal overload will s akl
Sep 19, 2010 | Frigidaire Side by Side 26.0 Cubic Foot...
My Matag Skybox compressor will not turn on. I can here it clicking and trying to come on.
HI. This is a strong indication of starter/overload relay failure. This clicking noise is coming directly fromm the relay device. it is damaged. this relay is the main starter of the compressor unit. It receives a signal from the main PCB. Once the power signal is received, the relay will regulate the starting, and stopping of the compressor, via control board and thermostat assembly. The failed relay will need to be replaced, asap. Once replaced, the unit will operate correctly. The relay is mounted on the side of the compressor. Once the bracket, and terminal wires are removed, you can gently pull it away form the compressor, to check the contacts and connections for corrosion. If any of the contacts or terminal connections are worn, replace them. Worn contacts, or corroded connections will not allow for proper current flow.
NOTE_ I would advise to locate the clicking. Make sure its coming form the compressor/relay location. There are some units of this nature out there that are fixed(compressor and relay intergraion). If this is the case, simply replace the entire compressor unit. If the clickiong is coming from the main control board(PCB), the PCB, will be the culprit.
Dec 01, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Fridge is no longer cold, makes a clicking sound about every two minutes. fridge is side by side Maytag 26.5 Cubic feet, about 10 years old. It is model # MSD2756AE. When talking to a dealer/repair...
Either a bad relay on the compressor. Or a scized or locked up compresor. My co. in NJ gets $95 to replace the relay, $450. to change compressor. $25.00 just to check it out. The Dealer is always more $$
Shop around, Smaller companies, smaller price.
If your unit has a Embraco compressor it may just need a new relay. The Tecumseh compressors all went bad and now are replaced by Embraco's
Nov 11, 2009 | Maytag MSD2756G Side by Side Refrigerator
Refrigerator compressor motor will not run.
Does the fan work? If yes then the compressor has a relay and overload that might be bad. Or it could be a compressor that is bad. If its a compressor then you will need to have a tech verify that it is the problem. If nothing is running then it could be a thermostat thats not switching it on. Let me know if you need any more help with it.
Aug 11, 2009 | U-Line 75R Refrigerator
I need a diagram of the fuse box for a 2002 Lexus ES300, I need to replace the AC Compressor Relay and I don't know where it goes.
Windshield washer solution won't come out. I"ve replaced the pump and the control arm attached to the steering wheel. Please advise runnig out of money and time.
Jun 13, 2009 | 2002 Lexus ES 300
Shut down once, some clicking noises. Now is runing fine.
Probably a bad compressor start relay.
Replace the relay before you condemn the fridge.
May 24, 2009 | Kenmore Refrigerators
Our refrigerator/freezer will stop working (not cool or freeze) then days later will begin to work again.
If you have already tried shutting off for 24 hrs. (reset), cleaning the under-bed condenser fins (vacuum and/or compressed air) and the issue still continues, you may be lucky enough to just need a relay/overload switch; the thingy connected to the compressor, which by the way takes patience and ease in removing. However, once the plastic cover is off, simply unplug the relay switch(s) and shake it, if you hear rattling (or) smell burn, the relay is toast and thus needs replacement. Simple enough, for replacement type in the model # of the compressor: (i.e.) [[ Embraco FGS 80 with relay/overload switch ]] cost around ($30-$50)... order, replace, re-plug, and if on target, the compressor will kick in. let run for 24 hours before adding foods, and all is good. Have a nice day. ee
Dec 07, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Replacement starter relay for skybox MBV1976A...
i lost track of the way the wires go on starter relay. can someone please let me know or send diagram, for the 3 wires. Any help would be appreciated.
Jul 04, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Kenmore Side by Side Refrigerator Logo
50 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
