Question about Hotpoint WMA48 Front Load Washer
Door lock flashes and washer wont start - Hotpoint WMA48 Front Load Washer
    Top Expert:
  • Hotpoint Master
  • 9,472 Answers
You will need to replace the lock assembly.
Posted on Nov 28, 2012
4 Suggested Answers
gittos73
  • 244 Answers
SOURCE: door wont lock
to test if there is a fault on your interlock you can close the door now with your hand bang it on the front of the washer were the door hits the catch most cases if it faulty than the washer will start it will then need replacing only thing you can do if faulty m8
Posted on Sep 24, 2007
  • 139 Answers
SOURCE: wma 32
Hello mate if you undue the three screws behind the soap draw and remove the front contol panel complete with the pcb board.. just undue all the wiring pulgs and jotting down which wire goes back where. Once the complete panel is out unclip the pcb from the front panel and you can see if it is blown or not..
10 out of 10 the pcb board is blown.....
hope this helps.... Its either you carbons on your motor which do it or the door interlock.. 65 % of the time its the carbon brushes wearing out on the motor that blow the pcb
if you need any more help let us know....
cheers the doctor
Posted on Jan 08, 2008
beltronic205
  • 1474 Answers
SOURCE: The door locked light keeps flashing on my
Sounds like needs new door interlock swith Cost around 15 pounds.....Simple to fit
Posted on Sep 28, 2009
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
My washing machine wont start. The door lock
You will have to replace the door lock wax motor.
May 21, 2010 | Hotpoint Aquarius WF220 Front Load Washer
Flashes "DL" and "F"
A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Replace failed component.
Jun 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Indesit washer wont run
the door lock light flashing indicates that the door has not locked or not shut correctly,is the appliance is under 5 yrs old open the door and check the door catch,there are two gaps either side of the catch,if you look into the gaps you should see a metal pin,if the one at the bottom is not there then thats why the door wont catch,there are some screws around the door frame if you take them out and just pry apart the door frame by the catch you will see the pin at the top,push it down till you see it at the bottom gap,refit and test.
Jan 24, 2009 | Indesit W 123 Front Load Washer
My front loading washer wont start it flash E and DL i dont no what it means can you pls help me?
DL means door lock error. This happens when the door trys to lock 6 times but cant lock.
There a 2 things that create this problem. the door lock mechanism or the CCU ( central control unit )
Replace the door lock mech. first. if this does not fix the problem replace the ccu.
Nov 15, 2008 | Kenmore 46462 Front Load Washer
Door wont lock
Sep 22, 2007 | Hotpoint WMA64 Front Load Washer
Hotpoint WMA48 Front Load Washer Logo
43 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
