Question about Electric Mobility Power Electric Scooter Power Wheel Chair Safety Flag
Loose connection Hello I have a GO GO elite. Battery is fully charged but sometimes it won't start. If I then push a little it starts again I was told it could be ignition barrel, do you think it could be that as its expensive to get it repaired. Scooter is 4yrs old. Many thanks.
  • Electric Mob... Master
  • 1,263 Answers
No problem i can order you one for about 5 pounds regards
Posted on Dec 09, 2012
  • 92 Answers
SOURCE: I have purchased new batteries for my mobility
The control seems to be the issue. I have rewired so many scooters. When you have power and it wont go, it is usually the control. If you cannot afford the part right away, you can rewire it or have it rewired direct
Posted on Apr 06, 2010
  • 23 Answers
SOURCE: electric mobility scooter says charge is full but won't run
This sounds she has tripped her circuit breaker. It works just like the one on your house, when you ask too much of it it suddenly goes 'pop' and seems to be dead.
Looks like you have the same scooter as mine, it should be a little white button on the back of the base. If you follow this link, it will give you a pdf version of the older model pride victory manual, (Mine is a three, they are up to about 10!) See fig. 8 on page 20 and 'Circuit Breaker' on page 21. Also, Page 33 has the troubleshooting info. Hope this helps.
http://www.rentascooter.com/downloads/_manuals/pridemobility/Pride%20Victory%20Owner's%20Manual.pdf
Posted on May 06, 2010
  • 177 Answers
SOURCE: I have a milan mobility scooter,turn the key & it sounds a low
Hi. This sounds difficult. I have had a few scooters move slowly forward or in reverse, but not both. Normally if the speed pot ( wig wag ) is not exactly in the central position, they can do this.
It is possible for a scooter to have your problem, if the speed lever is binding or rubbing on the housing. Normally the lever is returned to the middle by a spring around the speed pot shaft. If this spring is loose or broken, then this could also cause the problem. Sometimes a small spot of oil or grease will help.
To check the speed lever is in the middle, slowly move the lever for forward untill you hear the brake solenoid release. Now release the lever and slowly pull it for reverse untill you hear the brake solenoid release. Make sure that the speed lever moves the same amount for forward as it does for reverse. If not adjust it with the key off.
If you get the machine to drive properly, then change the controller to see if it is OK.
As for the beeping, a lot of machines will go into an error mode if the speed lever is not in the central position when you turn the key on. This is a safety precausion.
Good luck. Neil.
Posted on Jun 07, 2010
Testimonial: "hello,thanks for ur info.i came to be here by paying for it,then ended up answering questions for others,my scooter is still not working.its a long story but i have learned a lot & have lived my life helping others.i recently downloaded info from shoprider,not having my scooter has depressed me like you wouldnt believe,but i will eventually get it sorted,this is my email if you wish to exchange info,i was punched off my scooter last year & suffered concusion.hence i have a problem getting to grip with things at times.the CPS dropped the charges against the young male 150 people there i had it put in local paper for witnesses with no help lol.gotta laugh whats the point moaning colintaylor1957@hotmail.co.uk"
  • 177 Answers
SOURCE: Scooter stops intermittenly
Hi. Does the machine stop suddenly, or does it slowly stop as it normally would? Does this happen on hills or slopes?
A lot of scooters have a self-resetting circuit breaker connected to the battery leads. If the machine draws to much current ( amps ) then the circuit breaker trips out. After a few minutes the circuit breaker will reset and you can continue.
This could mean that the circuit breaker is faulty or that the motor is drawing to much current, or is burnt out.
Some machines have a very light duty circuit breaker, and these can trip out often. I have changed many of these circuit breakers for this reason.
Check all your battery leads are secure and tight.
If it is still a problem, get a serviceman to check the motor current is what it should be.
Good luck. Neil.
FixinFax
  • 3085 Answers
SOURCE: Electric 3 wheeled mobility scooter wont move
Look at the rear of the scooter, make sure the Free Wheel lever is engaged
Posted on Jun 27, 2010
Ok my 1983 camaro has a v6 in it and every time I want to start it I have to hook it up to a portable battery charger and start it up like that but now it won't even start up. Even when the battery is...
Sounds as though the battery is no good,
unless you know otherwise & also had it tested
Charging a battery doesn't address it's internal
condition
You have battery cables that corrode inside & can be
voltage drop tested
You have the starter & solenoid,ignition sw & such, to name
a few,lots of possible causes & things to check
Jul 24, 2013 | Cars & Trucks
1994 Toyota Tacoma PreRunner - won't start with new battery, lights won't come on
Check your battery connections on the battery and the other ends where they go the ground will go to the engine block and the positive to a solenoid make sure all of this is tight and has no corrosion. This is just a loose wiring problem
Aug 18, 2012 | 2000 Toyota Tacoma PreRunner
My 97 Pathfinder won't turnover. It clicks, it gives one push but then does nothing. It starts when I jump it and after it's charged for a while, but when it's been sitting it's like t
could be poor connection from battery to battery cable terminal. take off both pos. & neg. battery terminals, clean & reinstall, making sure there is a tight connection. if the cables are loose (even just one) or if the battery cable seems degraded with corrosion, they should be replaced. could also do a load-test on the battery... it should stay strong under load, and shouldn't drop to below 11 volts under load. if it does you have a bad battery, even though it may seem good otherwise.
Aug 10, 2012 | 1997 Nissan Pathfinder
Not starting up
hello there!
so you're phone won't charge up...you should buy a new battery...your old battery is not functioning well...
tip:
don't use the phone while charging. let it be fully charge before using it again. and don't let it to overcharge too. this will reduce the life span of the battery.
Thank you for choosing fixya and kindly rate this post.
Dec 30, 2011 | Sony Ericsson Cell Phones
Why won't my car start without getting a jump? Once I get it jumped it runs really good but when I turn it off and try to start it again, it won't start. I have a new battery and a new alternator...
Buy yourself a volt meter and check the batter voltage before and after it starts. You should read 12 volts before starting and around 14 volts once it starts and the alternator is charging the battery. Also check for loose connections between the alternator and battery. Check that the ground wire from the battery is secured to the vehicles frame. Good luck!
Oct 18, 2011 | 1987 Audi 5000 CS
Have a 1998 sunfire wont hold charge, belt seems loose how much play should there be?
if it won't hald a charge, a couple of things may be the cause, 1. make sure that the battery is fully charged, have a LOAD test done on it,, just because you get a reading of `12 volts doesn't mean its fully charged in the starting sense,, you need a required amount of amps to actually start a motor, doing a load check on the battery will tell you if you have one or more bad cells in the battery itself, which will make you think that its a charging problem, once you have a known GOOD battery with the correct amps to start the vehicle,, go ahead and start it up,, with a meter, check the battery posts,, ( make sure all connections to the battery are clean and tight ) with the meter in place and the car running you should get a reading of between 13.5-14.5 volts, if you do then the alternator is doing its job, and you should have no more problems, if its not, again, then you have an alternator issue, or as your asking, maybe a belt problem, to address your question, a belt should have just under 1/2 inch of play at the widest section of no contact,,by that I mean,, if the distance between the power steering pump and the alternator has the biggest gap of no pulley contact,, thats where you would check for the 1/2 inch of play , On most newer cars you have an idler arm and a idler pulley that takes up the tension, so if you find that the belt is extremely loose, your problem may be in the idler adjustment, or it could just have a weak or bad return spring
Sep 16, 2011 | 1998 Pontiac Sunfire
My alternator won'charge and it and the battery
batteries will show 12 v and still not have enough amps to start the vehicle, clean all the connection points on the battery , and charge it fully, start the vehicle and check again for voltage at the battery posts, you should have a reading of 13.5 to 14.5 volts, if not, yes you have a alternator malfunction,
Jul 23, 2011 | 1992 Lexus Ls 400
My battery was was not charged for 2 days over the weekend and now it won't run on batteries. I need to have it on AC power every time I use it.
Laptop batteries can become unchangeable if they are completely discharged, and left that way for too long. This happened to my Asus. IF you leave it charging over night and it still doesn't work you will need a new battery. If you contact the manufacture they will probably charge you over $100 for a new battery. If you use eBay, the average price is $32.
http://shop.ebay.com/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=IdeaPad+S10e+battery&_sacat=See-All-Categories
Regards, Chris
Jul 12, 2011 | Lenovo IdeaPad S10e Netbook
Hello. My 1997 Chevy Tahoe refuses to start. The problems began with a bad fuel pump. I changed. It worked. The fuel pump died again. I changed it again and it has been working. I parked it for two weeks....
Now you have a good battery & a starter that turns over the motor
Have you cycled the key on & off with a fuel pressure gauge on the
fuel rail?
Do you have a fuel filter that isn't over 3 or 4 years old?
Have you checked for spark while cranking ? Use an old plug on the wires,
if you have ignition wires,don't ground the wire without resistance
If you removed the ducting & MAF Sensor it won't start
Tell us what you checked & exactly how that was done.
Jun 09, 2011 | 1997 Chevrolet Tahoe
1988 Oldsmobile Delta 88 (Vin "C") won't start, won't turn over
the 12 amp is for a jump start and the 2 amp is for a trickle charge which doesn't degrade the battery. i believe you have a loose connection either a loose ground cable or the positive cable to the starter check these and tighten if neccessary
Apr 18, 2009 | 1988 Oldsmobile Delta 88
Electric Mobility Power Electric Scooter Power Wheel Chair Safety Flag Logo
62 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
