Question about Nordic Track NordicTrack Apex 6000 Treadmill Rear Roller
Knocking noise when walking - Nordic Track NordicTrack Apex 6000 Treadmill Rear Roller
    Top Expert:
  • Nordic Track Master
  • 12,223 Answers
This a WORN deck belt problem, you must lube a excahnge the d.belt.
2) LUBe THE rollers bearing too v. important.
3) Test the drive belt motor, for worn or crack belt
4) Test the input voltage motor, if there are the motor need repair.
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Posted on Nov 28, 2012
Is this knocking noise normal? Treadmill is brand new, just delivered this morning. Thanks
Knocking is not normal, could be a roller bearing gone bad. They could have tightened the tread belt to tight causing the bearings to knock which will cause the walking belt to prematurely stretch and wear out. Could also be a drive motor bearing. On the flywheel side.
May 16, 2016 | Exercise & Fitness
Audi noise when starting only
Walk away from it. Unless your getting it dirt cheap. Tapping is top end, Head job. Not cheap. Knocking is bottom end. replace the engine.
Jan 16, 2015 | Audi Cars & Trucks
How can I get my treadmill to stop knocking? I know it's not the motor.
Check the motor belt, more than likely has a burnt spot in it and can cause a knocking
Jun 29, 2014 | Treadmill Doctor Sportcraft TX 400 Walking...
Nordictrack 3700 makes a knocking sound when I run on it
Hello.
Knocking noises more than likely come from the rear roller, there could be a small chance it's coming from the motor it's self though.
Have some walk on the machine and make the noise while you locate which end of the treadmills coming from.
If it is the rear roller the bearings will need to be replaced, this can be done by removing the rear roller and taking it down to any bearing shop and have them locate the bearing numbers. Ask them for advise on removing them as well.
If the noise is coming from the front of the treadmill then have a look at the fly wheel coming off the motor, locate grub screws and tighten.
GymWorld.net.au
Jan 11, 2014 | Nordic Track Nordictrack Track E 3700...
L200 series read knocking noise
Sounds like a loose or broken brake shoe or brake drum. As the car is slowly moving, pull up on the emergency brake. Does the noise get worse? Better? Can you feel the clunk in the handle of the E brake? This is what it sounds like, but my second choice would be the wheel bearing getting bad. These cars are known for this. If you jacked the car up a bit and wiggled , tugged , and pulled on the wheel, you may find movement there. If so, it is the bearing. . I changed my bearing 3 weeks ago. l series, $51 for the bearing, and $40 to press it in. I took it off the car myself. Very easy to do. If you decide to go that route, I can walk you through it. Hope this is helpful, cheers from Nova Scotia!!
Jan 17, 2013 | Saturn L-Series Cars & Trucks
Rough idle and noise and my jeep 01 grand cherokee is missing
Need more info... What kind of noise and when do you hear it?
If you haven't changed the plugs\wires, it may be time to do so.
Jun 09, 2011 | Jeep Grand Cherokee Cars & Trucks
Is there any problem that i should look for in buying one please
Hi, volvo's have pretty solid engines so unless you hear an load knocking noises coming from the engine or blue smoke coming out the exhaust you should be ok engine wise, but here is a list of things you should check
1, listen for knocking sounds from engine
2, look for blue color smoke coming out of exhaust, if you see blue smoke then walk away as it means engine needs rebuilding.
3, check the oil, check oil level and color if their is anything that looks like mayonaise then this means head gasket has gone and needs replacing this can be expensive, if the oil level is ok and looks ok then the engine should be fine.
4 have a good look around engine for oil or water leaks check on floor under engine for signs of oil or water dripping off engine,
5, check all wheel arches for signs of rust
6. go gor drive and test the brakes and check all the gears including revers as gear box work can be expensive.
7 check the car will turn left and right on full lock and listne for any knocking noise whilst turning round islands etc this could mean drive shaft or gearbox trouble
8 listen for knocking noises going over bumps if your hear any then this would mean ball joints need replacing, not that expensive to do but you could use this to lower the price f it does knock.
9 check all the lights and switches work inside the car.
that list should give you a good idea of what to look for if you have any concernes walk away their are plenty of other cars out their. have a look underneath at the floor to check for corrosion as it would be expensive to get the floor welded up and also ask about service history.
let me know if you need further assistance ok
May 29, 2010 | 1989 Volvo 240
New Breaks Knocking...
the knocking noise is caused by the pads walking. the shims that fell out go 1 ontop and 1 on bottom.you will have to take the caliper back off that is the 2 14mm. bolts one is longer than the other so pay close attention .once removed the spacers should half should slide on the knuckle assembly 1 up 1 down .then slide caliper back over. thanks!
Mar 12, 2009 | 1998 Ford Escort
2002 325i Knocking noise front suspension
This noise is likely caused by swaybar end-link joints. Newer cars use solid rods with ball and socket joints, to connect the ends of the swaybar to the frame. These ball and socket joints at the end of these rods, create an amazingly noticeable and annoying noise in the car when you go over the slightest bump. There is no way to test these things unless you disconnect one end and check to see how tight the ball is in the socket just by wigging the with your hands. If they move around at all without pressure, they are no good. Go to ebay and search "bmw endlinks " for a picture.
Mar 12, 2009 | 2001 BMW 325
94 buick p.a. knocking sound
Hello, the knocking noise you are hearing is rod bearings. There is going to be excessive clearance in the rod bearings on the crankshaft.You want to have this seen about as soon as possible or either she will put you walking. Thank you
Feb 28, 2009 | 1994 Buick Park Avenue
Nordic Track NordicTrack Apex 6000 Treadmill Rear Roller Logo
178 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
