Question about Kenmore 62602 Electric Dryer
No air...drum not turning...Kenmore elec.dryer # 110.62822011
Push start and element heats up but nothing else...no turning of drum and no air blowing
    Sergeant:
    Champion:
  • 262 Answers
Does it make a humming sound if so you may have a bad motor os something stuck in the blower wheel
Posted on Jan 10, 2009
Older Kenmore dryer model 86568110 wont start, i can see the heat element glowing but after pushing start button nothing happens.
Sounds like a broken belt. Do not continue to turn the dryer on until belt is replaced. With no air blowing over them, could overheat and cause a fire or burn them out.
Mar 17, 2013 | Dryers
No heat in kenmore 600 series elec dryer
It could be the heating element, a safety limit, a control problem, or an electrical problem. A heating coil is used to warm the clothes as they get tossed gently inside the drum. A blower mounted on the motor pulls air through the heating element into the drum and out the exhaust. The element gets old and brittle with use and eventually needs replacement. That is what you check first. On gas dryers vibration and age will cause the igniter to crumble and fail. If it turns out the element is fine then one of the safety's might be blown. These safety's are set to a certain temperature
for the dryer to operate safely. The drum temp control for cotton is 160f. A limit on the heater housing is 250f. If it fails another smaller limit is mounted nearby that blows at 300f. If that temp exceeds 350f a duct fuse mounted on the blower housing opens and kills most dryers. On gas dryers the duct fuse will kill the gas assembly but the dryer will still run. If all of those safetys are good the timer could be the problem. The timer has a terminal on it that runs down to the heating element. If you suspect it is bad you can check it with a meter. That leg of the timer should have continuity with other terminals on the timer at different spots on the timer. Turning the timer and checking for continuity will give a clue. If you cannot get continuity with any other terminal on the timer at any position on the dial then you have a burned contact in the timer. If that turns out to be good, you would need to inspect the electrical outlet for proper power to the machine. On American models the motor runs on 120 volts but the heating element must have 240 volts. If you have more questions just post a comment. Good luck on repairing your machine. I have some repair photos: HERE
Aug 18, 2010 | Kenmore Dryers
Kenmore 62064 elec. drying is runing (all buttons
Hi Sam,
Make sure that you have checked the circuit breaker, to find out wither or not the breaker was tripped or not, before you take it apart. but there is a good chance that you are right on the money......
Dec 12, 2009 | Kenmore 62062 Electric Dryer
Drum turns, no heat
either the heating element or the thermal fuse very worst case would be the timer but i have all parts in stock whirlpoolpartssurplus.com
Jun 24, 2009 | Kenmore 63942 Dryer
Does not heat, air blows, drum tumbles.
then DIY we do not read minds as to MAKE
Sep 28, 2017 | Dryers
Kenmore Elec Dryer Won't Heat up
Sounds like either a faulty thermostat or heating element. Both are accessed from the lower right backside of the dryer behind a metal door. Be CAUTIOUS, the edges can be sharp and cut you very easily. Good luck.
Mar 23, 2008 | Kenmore 65924 Electric Dryer
Kenmore 62822 electric dryer
Check your heating element to see if it is shorted to ground.
The element has 110V to it all the time, so if the element shorts to ground it will heat all the time. This is a fairly common failure.
If the element is ok, you may have a stuck centrifigul switch inside the motor, this is very rare but does happen sometimes.
Post back to let me know what you find or if you have any questions.
Thanks/Mike
Dec 20, 2007 | Kenmore 62822 Electric Dryer
Kenmore 62602 Electric Dryer Logo
53 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
