Toshiba e-studio 211 how much reset fuser code
5 Suggested Answers
SOURCE: toshiba e-studio 211 copier .Toner sign not remove
sir how to remove the toner symbol in toshiba e-studio211. when i install a new toner of same model but still remains the same & unable to copy the document.
Posted on Oct 20, 2012
  • 43 Answers
SOURCE: toshiba 160 error code
c44 = fuser error
turn copier off
hold down 0 & 8 while turning it on
then wait one min, then press 4 0 0 start
then 0 and set
turn off wait one min then turn on if this does not work it might need parts
Posted on May 08, 2008
  • 653 Answers
SOURCE: my toshiba e-studio 550: service recommended for SPC appeared
Check the control status of the surface potential sensor (05-242).
<When “4” is displayed: sensor error>
The sensor detection value is abnormal or the sensor output value is not changed even though
the main charger bias value is changed.
Is the connector of the surface potential sensor connected properly?
Is the main charger grid/wire attached poorly?
Is the main charger attached poorly?
Are leaks and such occurring?
Posted on Mar 06, 2009
tyeatsx1x
  • 9 Answers
SOURCE: manual for Toshiba COPIERS - E-STUDIO 211C Copier
for a speedy solution try to contact and for further information regarding Toshiba Copy Centres go towww.toshibacopycentres.co.uk or contact us on 01932 580192 or copycentres@toshibatec.co.uk
if anything they should sort you out!
Posted on Sep 14, 2012
Toshiba Model e studio 2303 A.Trouble showing Error Toner.Need a solution.
Technology Time: Toshiba Error codes
www.mytechtime.com/2011/04/toshiba-errors.html
Toshiba E-Studio machines do not display service code automatically. ... All codes, except fuser errors are reset by turning the machine off and back on again. ... holding down "0" and 8" keys, enter 251 to set PM limit, and 252 to see the number of copies that have been run since the last PM. ...Toner transport motor problem.
Mar 21, 2017 | Toshiba Office Equipment & Supplies
Toshiba copier E-Studio 2006 showing Error code C452 what could be a problem
Have you tried to check well your fuser unit because its fusing related problem where by those thermistor there not communicating well the temperature is either low
Nov 29, 2016 | Toshiba Office Equipment & Supplies
What is error c440 of toshiba photocopier
Toshiba e-studio Error code c440 is just problem with Fuser Unit after warm up time . 200L/ 202L/ 230/ 232/ 280/ 282/ 283/ 233
PROBLEM:
Fuser unit problem,
SOLUTION:
Try to reset it:
1. Hold down "0" and "8" keys while turn on the power.
2. Enter 400 press Start.
3. Enter 0 press Set or Enter.
Hope this helps
you can find more info at this link
Apr 28, 2014 | Toshiba E-studio 352 Digital...
Toshiba e-studio 211 maintenance reset
How can I areas the maintenance light on the toshiba e studio 211
Apr 16, 2014 | Toshiba e-Studio163 Copier
C41 Error on Toshiba E-Studio 550
Get a decent piece of equipment. WHY would you throw money away on a bad copier?
Apr 15, 2014 | Toshiba E-studio 550 Copier - Fast,...
Error code 211
how to solve call service for my toshiba e-211 pls reply me . .:(
Jul 15, 2013 | Toshiba E-STUDIO 211C Copier
Error reseting h4 for toshiba
H4 is probably a fuser temperature code. Sadly the 161 is obsolete and parts are no longer being made. You'd be wasting money getting a new fuser for it. Time to upgrade.
Jan 04, 2013 | Toshiba E-Studio 161 Copier
Toshiba e-studio 211 toner chip reset code
Plz tell me the reset code
Aug 25, 2012 | Office Equipment & Supplies
Please help me, e-studio 211 code c21
its code not reset replace Scanning system OR
CIS unit initialization error Otherwise check connection of these
Aug 26, 2011 | Toshiba E-STUDIO 450 Copier
I have a Toshiba studio 45 with error code c44, what can I do ?
You should apply to service Toshiba.
The Possible faults in lamp of the heating, thermistor, contact of the elements of fuzer or in signal of the controller of the direct current.
C41 Fuser thermistor, or no heat C43 Fuser thermistor problem or other fuser problem, after machine goes into ready C44 Heater problem
Oct 07, 2009 | Office Equipment & Supplies
87 people viewed this question
k24674
jasbo
jasbo
