Question about Pride Sonic 3 Wheel Portable Scooter
Need an off-board charger harness pride sonic
Where can i buy an off-board charging harness new or second hand
  • Pride Master
  • 1,271 Answers
Hi please contact me as i will either have a secondhand one or be ablwe to make one up for you. regards
Posted on Dec 09, 2012
5 Suggested Answers
  • 103 Answers
SOURCE: pride sonic scooter won't turn on. the battery is
How do you know that the motor is functional? Have you load tested the batteries. If the batteries are bad usually they will still take a surface charge and appear to be fully charged.
Posted on Jul 23, 2009
  • 347 Answers
SOURCE: Hi. Our pride Ranger PMV
Hello Simon.Visit-www.alldatasheet.com its free.Download as a PDF File & save + if you choose print for future ref.To your Adobe Reader.Type in the correct boxes for a troubleshooter.Merry Xmas,any problem,please ask again,Colin.
Posted on Dec 16, 2010
  • 692 Answers
SOURCE: Pride JET 3 Ultra power wheelchair. Problem:
check the motor brushes if they are 1/4 inch or less replace them. Next, after driving the chair for a while check the motor casing near the brake assemblies on the rear of each motor if the casing is hot then you have a sticking brake pad or pads and this can cause the excess battery drain. If you have sticking brake or brakes unfortunately the whole motor assembly will have to be changed Hope this helps
Posted on Jun 10, 2011
SOURCE: instruction manual for pride mobility sonic & celebraity scooter
Here is the link to all pride manuals for power mobility.All files are .pdf and searchable.
http://www.pridemobility.com/resourcecenter/Downloads/Product_Owners_Manuals/product_owners_manuals.asp
Posted on Jan 04, 2012
Green ready light on Pride Sonic three wheel scooter wont turn on. What turns it on?
Hi if it is similar to pride x the circuit will shut down if key is left on for 20 minutes u will still have lights. Remove key for a short time then replace it & turn on ..goood luck
Jan 21, 2016 | Pride Sonic 3 Wheel Portable Scooter
I have a Pride Mobility Legend that will not charge, How do I fix it?
Legend have on board chargers, sound like you need a new charger.
Sep 24, 2014 | Pride Health & Beauty
Change on board charger to off board charger
Not an easy job. There are parts that need to be installed on the scooter and wiring changes that can't be given here step by step. Have a service center give you options to consider.
Mar 13, 2014 | Pride Sonic 3 Wheel Portable Scooter
Scooter won't take a charge
scooter battries must be charged on a regular basis.or else the on board charger wont charge them .Try useing a trickle charger to bring them back to life. if you dont have access to one bring them to a local service station they should charge them for a small fee.
Jun 26, 2012 | Pride Sonic 3 Wheel Portable Scooter
How long will batteries last if not used?
Get the batteries tested .As a motor mechanic your husband should know about battery care you could have removed them and charged them with a car battery charger or any of the trickle chargers used to keep batteries charged while not in use
May 09, 2017 | Pride Mobility Products Sonic Scooter By...
The onboard charger on my Jazzy 1113 does not work after replacing the gel batteries. Do I need to replace the onboard charger?
If you have checked the charger and are sure it isn't working. Then you have two options: You can buy a new on-board charger or try to locate a good used off-board charger from someone in your local area. Or maybe borrow one from a neighbor that has a power chair to see if it will charge your batteries. You just plug the off-board charger into the charger port located under the front of your joystick. Off-board chargers should be cheaper than an on-board from Pride. Hope this helps
Aug 27, 2010 | Pride Jazzy 1113 Power Chair
Where can I buy a battery charger for my Jet 3 model #2904-24. My batteries will not charge up anymore. Bateries about 2 years old. Email address is horton-cathy@hotmail.com\r\n Thank you James Horton
Hi. Try a google search for your nearest pride dealer.
You would be better advised to get your batteries tested first. It is more likely to be a battery fault.
If you do need a new charger, ask for one of the new pride chargers, as are sold with the Pathrider 130 XL mobility scooter. These chargers are a very good charger. Once the batteries have been fully charged, the charger drops its charge rate to 27.6 volts. This means that you can leave the charger on for days at a time, and not overcharge the batteries.
The older 4 amp chargers maintain the full rate of charge, and do not drop down to the lower charge rate. These chargers should only be used for overnight charging after each use.
Good luck. Neil.
Jun 22, 2010 | Jet 3 Ultra Power Chair
My batteries are all right but the scooter is not
Two things
1 - Have the batteries been tested with a load tester.
2 - If the batteries are good then you need a new charger.
Apr 08, 2009 | Pride Sonic 3 Wheel Portable Scooter
Battery charger wont switch over to charge on a sonic scooter
The Sonic has an off board charger. IF the scooter is not charging, you may need to replace it. If you a technically inclined, you can measure the voltage out of the charger, it should be more than 28 V. You may need to contact Pride for more help.
Nov 21, 2008 | Sonic 3 Wheel Scooter
Pride Sonic 3 Wheel Portable Scooter  Logo
116 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
