Question about Sewing Machines
My minghui sewing machine is not sewing stitches
When i used first time its not sewing ,but some times sew also.So,what can i do for sewing,i can't resolve my problem.
    Problem Solver:
  • 13 Answers
Have it serviced. they should be serviced on a regular (yearly) basis. just sitting is not good for them.
Posted on Feb 21, 2013
  • 123 Answers
SOURCE: my Hyundai 8 stitch sewing machine didn't have any
http://userguides.50webs.com/
This site carries manuals from every Hyundai model of sewing machine
ever made.
Posted on Aug 23, 2011
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
  • 1116 Answers
SOURCE: instructions manual for the handy stitch sewing machine
http://www.sewwhat.net/millie/Manuals/CEX300k.pdf
Posted on Feb 21, 2010
SOURCE: I have a Necchi 537FA sewing machine. It sill sew
have you checked to see if the needle is bent-lay the needle on a flat surface & roll the needle over,, if the needle does not roll good -replace
blunt needle-if the needle makes a popping sound when the needle penetrates the fabric,,the needle is blunt-replace
sometimes if the thread comes off the thread take-up lever it can jam the thread in the bobbin area
try rethreading the machine
check to make sure the thread isn't wrapping around the spool pin
check the spool of thread to see if the notch on the spool is catching the top thread
check to see if there's a burr on the bobbin case
I hope one of these suggestions helps you
please rate this using the thumbs in upper right hand corner
Posted on Aug 12, 2010
  • 136 Answers
SOURCE: Elna machanical sewing machine
50 year old elnas made stitches by cams. look to see if the machine has a cam in it. you can see this by opening lid on top of machine. cams are black with red or white showing the pattern of the cam. could also have broken cam stack gear. That would require technician with elna experience
Posted on Jul 12, 2009
My Janome hd1000 is not picking up the bobbin thread. Can you help
Be sure to use a brand new needle. If that does not resolve the issue, your machine probably has a needle/hook timing issue. There are many web sites & videos on sewing machine timing. Or take it for service.
sewing machine timing Google Search
Jul 27, 2016 | Janome Hd1000 Sewing Machine
I'm trying to get my mother's Singer Touch & Sew Deluxe 645 to sew a straight stitch. I don't want to buy a manual since the machine rarely gets used and I have limited time to "fix"
Not much information to go on. What do you mean it won't sew a straight stitch. It just won't sew a straight line? It won't form a stitch? What?
Dec 12, 2012 | Singer Sewing Machines
Sewing in reverse cuts top thread, help? Please!
the fabric & thread & needle may not be compatable
try changing the needle- it may be damaged
the horrible grinding noise needs to be check --the machine needs to be serviced
check for burrs on the needle plate & on the bobbin
some sewing machines don't do with strong material
Mar 18, 2012 | Sewing Machines
Janome mini heavy duty sewing machine
when you sew keep a eye on the thread take up lever & see if the thread comes off while your sewing, I've had this happen to me & I've been sewing for over 30 years. if this does happen, take a pair of pliers & very gently close the take up lever just alittle but not enough to damage it.
also check the needle to see if it's damaged--if your not sure change the needle--flat side goes to the back of the machine
always make sure the fabric & needle & thread are compatable--the thread must be able to pull thru the needle with out any problem
also check to make sure there are not any burrs on the needle plate or bobbin or bobbin case
Feb 26, 2012 | Janome SEW MINI Mechanical Sewing Machine
I have a Brother LS-1717 sewing machine and my thread keeps breaking. We've oiled it but it hasn't acted right for years, it hasn't seemed to matter what the settings are on or what...
here are somethings to try,
1. change the needle--flat side goes to the back of the machine
2. check the tension see if it's too tight,,usually 4 to 5 is good
3. rethread the machine top thread & bobbin area
4. check to see if there are any burrs on the needle plate where the feed dogs are (teeth area)
5. you said that you made a comforter for your husband using thick fabric,,some sewing machine are not good at sewing comforters & other heavy fabric,, it's possible that the machine is out of time, which means it will not sew good & mess up,, which means it needs to be serviced by a repair shop technican to see if it is out of time.
Jan 30, 2012 | Brother LS-1717 Mechanical Sewing Machine
Hi just got my wife a singer 4423 used it for the fist time and while sewing some times it gets noisy and vibrate. Checked the needle and all seems fine. It don't seem as smoth as I would like it to...
MSRP on that machine is $269.99.
Smooth machines are probably going to start around $400.
Do yourself a favor. Go to a local sewing machine dealer so you can try out the machine before you buy it. Also, take advantage of classes and knowledge of your dealer. You can spend $600 online and still get a loud, shakey machine. Or, go to a sewing machine dealer, try the machine and probably pay about $400. Check out the Husqvarna Viking Emerald 116, MSRP of $399.
Dec 01, 2011 | Singer Sewing Machines
I needle comes unthreaded whenever we try to sew. We've both tried numerous times and it doesn't make a sitch. The bobbin seems to be done correctly b/c the bottom thread comes up with no problem....
first let's deal with the needle becoming unthreaded, Keeping the needle threaded is easy, always keep thread tails of 3 to 6 inches on the top thread & bobbin at all times, & make sure the thread tail are pulled behind the needle before you start to sew,, this will ensure that the thread will not come out of the needle when you start to sew.
you mention the fabric is thin,, do you have a needle that's right for the fabric your sewing?
thin fabric needs a different needle than blue jeans fabric, check your top tension & see what the setting is on, usually 3 to 5 is good.
when the needle & thread are right for the fabric then the sewing is good.
also clean under the needle plate & bobbin area for loose threads or lint
also it's a possibility that the machine could be out of time & would need to be serviced by a sewing machine repair shop-as they have the tools for the job
Sep 22, 2011 | Brother LS-2125 Mechanical Sewing Machine
Why is the motor of my sears kenmore sewing machine model 385.12714 running really slow? The machine has not been used for at least a year or two. We oiled it. It is sewing, but at a snail's pace.
it could be different things
have you checked to make sure the plug is correctly in the machine
one time I was sewing on my necchi electronic machine & it for some reason was going slow like you mentioned & so I started checking different thing & found the cord to the foot pedal was laying in side the foot pedal & it couldn't go any faster untill I moved the cord out of the way
it could also be the motor
& also the power cord & foot pedal
it's possible it needs to be serviced since it's been sitting up so long & since it's sewing at a snails pace
Sep 11, 2011 | Kenmore Sewing Machines
I have a Necchi 3205 Royal series machine. I was sewing denim and it jambed and bent the needle. I replaced the needle and now it won't pull the bobbin thread up. I have tried several different needles...
Hi, I've got a necchi sewing machine too, not the same model as yours.
you said you were sewing denim & the machine jamed & bent the needle, it's sounds like the machine is out of time, sometime it doesn't take much to get them out of time & would have to be serviced by a repair shop with the tools needed to fix the timing.
Aug 29, 2011 | Necchi Sewing Machines
Sewing Machines Logo
665 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
