Question about Canon Pixma MP450 All-In-One InkJet Printer
Error code 6500
After I changed inc cartridges I got the error code 6500
Since the I have not been able to to use my machine at all
  • 4,041 Answers
Hello you can try
You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
Power off printer
Hold down STOP/RESET button then Press and Hold down Power button
Keep Power button down and Release STOP/RESET button
Release power button
Push STOP/RESET button twice
Wait 20-30 seconds - our LED showed Idle
Push STOP/RESET button four times
Push Power button twice
Power off
Next time the printer is started the waste count will have been reset.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 11, 2010
Canon mx347 error 6500 Display error code 6500 and alarm lamp flashing
1) Try to reset the printer to manufacturer defaults and chest.
2) main cause with the logic board itself or with other parts in the printer or cartridge.
May 07, 2016 | Canon MX340 AllInOne InkJet Printer
Why can't I scan, print or do anything? There is no error code.
Patti, you may have to do a hard reset.
1) Disconnect the USB cable from your computer
2) Remove the ink cartridges
3) Unplug the power cord. Wait for a couple minutes. Plug the unit back in,hit power button if needed.
4) Wait for the "Insert Cartridges" message, reinstall the cartridges
5) Close printers doors
6) If you get a recalibration message, allow the printer to complete this task
7) Reconnect printer to USB cable
8) Try your printing again.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Re How to perform Hard Reset
hp officejet 6500 error general printer error
HP Multifunction Printer Resets HP Officejet 6500
General Printer error with no alphanumerical code in Mac Control panel for...
Mar 31, 2016 | General Office Equipment & Supplies
What should i do with error e100-0001 on mf4410. i changed fuser film and when i closed the all the panels the machine falshed this error code e100-0001.
Nov 13, 2013 | Canon I-Sensys Mf4410 All-In-One Laser...
Error code 3501
HI
I HAVE KONICA C6500
ERROR CODE 3501 and 3802 but know the error 3501
I know it rech high temperature I change the sensor 1 UP fuser roller
and I reset the error, the machine start and stop again with error 3501
Oct 01, 2013 | Konica Minolta Bizhub C 6500 Copier
When the unit powers on an error code 6500 appears, tried reseating and cleaning the contacts of the cartridges, but that does not help. it appears that all cartridges have ink.
This unfortunately is a logic board fault and it will have to be replaced. that's the only fix for it. Sorry.
Thank youfor visiting FixYa! We answer yourconcerns promptly for FREE. Please spare a few seconds toclick on YES button and leave ashort comment to let other people know how I help you. Have a good one!
Jul 22, 2011 | Office Equipment & Supplies
How can I change an ink cartridge..My pixma mp500 is given me an error 6500 and I think it will fix it if I change the ink cartridge but it does not me allow it to do it. thanks
To be sure the error 6500 is correct, the orange light should flash 20 times then briefly stop and then flash a further 20 times and this will repeat all the time. if this the case then the logic board pcb will need to be changed as it has an internal bus fault.
Srri.
Jul 07, 2011 | Canon PIXMA iX4000 InkJet Photo Printer
Ink system failure....error code 0xc19a0013....what is this error code and how do i clear it....
What is HP Printer Error 0xc19a0013 & How to Solve the Error ? 0xc19a0013 ink system failure error shows in the control panel of printer.
Reason of occurring this error message is listed below:
  • HP printer setup may not be installed properly.
  • Printer cartridges low message.
  • Printer cartridge is damage or not inserted properly.
How to Solve "0xc19a0013" Error Code for HP Printer
  • Change low or empty cartridges: in case ink alert message is display before this message. Changing the cartridges may solve the issue.
  • Make sure the printer cartridge is installed or inserted correctly
  • Remove the printer cartridge and reinstall that.
  • Use HP Printer Automatic Cleaning Utility to Printheads:In case the error message is occurring ,use automatic cleaning utility of printer for printhead cleanup
  • Update the Printer Drivers :It may happens due to outdated printer drivers. We recommend you this to update your HP printer drivers on regular bases for smooth and flawless printing
In case your HP printer still display the error message best option is to dial HP Printer technical support Phone number-1-800-436-0509 (US), +44-800-078-6054 (UK), +61-1800-769-903 (AUS)
1 800 436 0509 HP Printer Technical Support Phone Number
Jan 04, 2011 | HP Officejet 6500 Wireless All-in-One...
DISPLAYS ERROR CODE 6500
Error 6500 is a hardware error.In most case the logic board assembly is failed.Better think about new printer.
Nov 18, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Error code 6500
That's a strange error for that machine, a network error? I would try removing the printhead and see if the error changes to printhead not installed, could just be a defective printhead which can cause strange errors.
Dec 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP450
I had the same problem and spoke to canon australia technician. Any 4 number code means it is a servicable error. 6500 code specifically says take to a service centre...
bugger....but thats what they told me...
Jun 08, 2008 | Canon Pixma MP450 All-In-One InkJet...
Canon Pixma MP450 All-In-One InkJet Printer Logo
194 people viewed this question
old marine
old marine
