GBC Shredmaster 550S
I want to clean the cutter rolls, because the cutter seems to suffer from an obstruction. How to open the Cover? Is there a maintenance guide availlable?
3 Suggested Answers
SOURCE: Seeking online owners manual for GBC Shredmaster 2260x
http://www.gbcconnect.com/assets/docs/2260X.pdf
Posted on Jun 03, 2010
  • 8404 Answers
SOURCE: gbc shredmaster 5550x: this machine
For an answer to this question, you will have to inquire through the manufacturer, or perhaps, there will be a advertiser who does this type of work whose name will come to you along with this answer. Look around on this page right now.
FixYa.com is not a parts or repair depot.
Thanks for your question today at FixYa.com
Posted on Jan 27, 2011
On, Fwd, Rev button on my Shredmaster Model 75X stopped working. How do I fix this?
Check the mains supply is still on, and the fuse in the cable is ok.
Most problems are caused by james, and solved by removing the cover and unjamming the cutters. Can be tricky!
Apr 02, 2014 | Quartet gbc 75X Shredder
Gbc shredmaster 5550x: this machine has badly worn plastic gears & one has teeth missing. Is a rebuilt drive unit available?
Jan 27, 2011 | Quartet gbc Shredmaster 5550X Confetti-Cut...
My 5550 shredder is completely dead. Is there a manual/guide to removing the covers. How do I get to the power circuit?
Open the door and look up towards the bottom of the shredder head and find 4 Phillips screws to lift the cover off.
Oct 16, 2009 | Quartet gbc Shredmaster 5550X Confetti-Cut...
A dept in our company has a 5570M and sake if we
First check that the resettable fuse has not tripped. If so push the red pin back in and try the unit again. If this is OK then check the main fuse. If this is OK then look into the top aperture where the paper feeds and see if you can see the opto sensor. Clean the lens with isopropyl alcohol and try again. If this does not work then look at the cutters to make sure they are not jammed with paper, staples, paper clips etc. If these are Ok then you can remove the cover to check out the power supply and the operating switch. Then try the continuity of the motor. Check the motor brushes. There is nothing else to it.
Oct 06, 2009 | Quartet gbc Shredmaster 5570M...
Taking the top off a Shredmaster cc55
They hide some screws pretty good. Also, try with a putty knife to gently pry arouond the cover seam. Their is always a puzzel to keep end users from DIY.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Jun 19, 2009 | Quartet gbc CC55 (Cross-Cut) Shredder
DISCONNECTED WIRE
I clipped all the zip ties to free up the harness and physically inspected every connector till I found a connector that seemed rather loose and came off with minimal force. I then gathered the 3 wires and install a #18 wiring nut. the shredder is fully functional again.
Jun 03, 2009 | Quartet gbc GBC 10-Sheet Cross-Cut...
How to fix a stuck shredder
get a pair of needle nose pliers and pull the jammed paper out. (you may need to figure out how to pop off the top cover to get better access to the blades)
May 27, 2009 | Quartet gbc ShredMaster 950S Strip-Cut...
111 people viewed this question
k24674
jasbo
jasbo
