Question about MSI EX465 Notebook
My msi ex465 wont start up on battery mode only the power lead on , while on ac it does but i need to unplug for several times before it will do,,, i have done reformatting it for several times...hope you can help me with my problems
    New Friend:
Possible solution for that is to change the motherboard we have the same issue
Posted on Dec 10, 2012
  • MSI Master
  • 32,281 Answers
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Posted on Nov 28, 2012
3 Suggested Answers
  • 223 Answers
SOURCE: MSI u100, 2 years old,
Thank you for using FixYa
Hey I can understand your frustration. I have an MSI PR400 laptop and I had a similiar issue while it was new and in warranty. They put a new motherboard in mine. I read that you tried it with and without battery. Did you remove the battery completely and restart? There is a slight possiblity that it is the power supply not charging the battery. You say there is a green light, but is it green on the adaptor? If so the charger is probably good. If you are handy with electronics you could try to get a reading with a volt meter on the tip of the charger. I don't see an easy solution and you will probably endup taking it in for repair. Did you push the reset button? Some models have one. I wish I could help more but that is about it on a notebook since it is a closed unit. You will need to take it to a qualified service center.
I hope this was useful and please comment if this was helpful to you.
Posted on Mar 24, 2011
Testimonial: "Thanks Denny for the feedback. I think the adapter is working fine as the 'charging' light is on. Planning to take it to the support centre tmr. "
maxcarson
  • 7627 Answers
SOURCE: MSI EX465 PC Notebook Results for
Do you have a question?
Posted on Nov 23, 2012
Automatic shutdown
Check the power supply. Sounds like its bad.
Nov 04, 2013 | MSI EX465 Notebook
Mam/sir my msi ex465 wont start up on battery mode....everytime i used it with a battery it stops before the start up it didnt show anything on a screen but it has a power...but in the plug it starts
try to remove your battery. plug it in and start it up. then shut it down . replace the battery.. plug it in and then start up. this may help
Jan 13, 2013 | MSI EX465 Notebook
Wont boot past toshiba logo
Unplug the AC adaptor, remove the battery, then press and hold the power button down for a minimum of 30 seconds. Now replace the battery and see if it powers up. If not repreat the process but this time leave the battery out and only plug in the AC. If it still doesn't power on repeat the process again and this time replace the battery and plug the AC back in. If it still doesn't power up it's time to start checking the hardware. Remove the ram and try it with only one stick. You might need to try each one individually to see if either works. If that doesn't help remove the hard drive and see if it will post to the Toshiba screen. If that doesn't help you'll probably need to take it to a service center.
Nov 25, 2012 | Toshiba Satellite L775-s7352 Notebook...
My msi netbook wont turn on even though the battery charging indicator is lit.
1. Turn netebook OFF with button, hold 4 seconds.
2. Remove recharge plug
3. Remove battery
4. Leave it like this for about 5 minutes.
5. Put everything back and power the laptop again
Does it appear to charge the battery at all when plugged into AC? Can you hear the charger humming when you put the brick up to your ear? (while it's plugged into AC,You may have a bad motherboard
Dec 04, 2011 | MSI Wind U120-020US Netbook
Beeps 2 times & a warbling noise when trying to boot up - unplugging power lead & pressing ON/Off button & reconnecting power lead starts up OK - but it can be OK for several days & th
By warble, do you mean a high pitch non stop noise? If so... I think I went through that bout 2 months ago, it was a easy fix. Ifr it is the same problem
May 29, 2009 | HP Vectra VL420 Intel Desktop PC - Intel...
Beeps 2 times & a warbling noise when trying to boot up - unplugging power lead & pressing ON/Off button & reconnecting power lead starts up OK - but it can be OK for several days & then repeats the p
The Cause of Problem:
The Power Buttons electrical circle sometimes just braked it by one of sensors and the result is the 2 beeps and Power Supply is in protected mode error.
The whole computer is turn off but the power button is turn on and this is the nub of the matter. Because if you want turn on the computer you can't because already turn on but just the Power button and you can't do anything.
The solution:
You need just change the Power Supply and don't do anything just the power cable put into the Power Supply after turn off computer.
Finaly change back the Power Supply.
Apr 25, 2009 | HP Vectra VL420 Intel Desktop PC - Intel...
Battery Life
your battery needs to be replaced...
Feb 24, 2009 | Acer TravelMate 4200 Notebook
Wont start
My solution (works every time) is to pull out the AC cord from back of computer. Then .. release the battery for several seconds only. Push battery IN again. THEN (presto) Push power-up button. It starts normally, every time. Then when you're ready just push the AC lead back in after it's started. Don't ask me why it works. It just does. It's like it needs the battery power to be isolated briefly and then re-applied. It works. I never bothered with warranty work. It's like an extra security feature. When it's off AC for a period -> that's the reliable starting method. Also, computer may be in hibernation mode. Hold the power down until you see a boot up screen (i f you can get to it)
Sep 01, 2007 | HP Presario M2000 Notebook
MSI EX465 Notebook Logo
241 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
