I have a bush 37" model number a637f that has
    Genius:
  • Televison & ... Master
  • 2,432 Answers
Tried to unplug and re plugged the tv to reset any program and the power supply. then re plugged and turn it on again let see if it back to normal working. if still the same issue, check for stuck up button at the remote control.if the remote control is good then still the volume get intermittent in function, at this time you will need to ask for assistance at the supplier since it was covered with the warranty.
Posted on Nov 28, 2012
  • 247 Answers
SOURCE: vizio 37 inch plasma tv changing inputs all by itself
it sounds like you have a glitch in your tv. i would hope that you have the warranrty for it. and i would contact vizio right away and tell them about your problem and they will have to fix the issue. hope this helps you.
happy holidays,
tom
Posted on Dec 17, 2008
SOURCE: The volume is turning itself down all by itself. The volume on the remote won't work, but the remote is fine with the other TV controls.
It sounds like the button is stuck. Take the remote apart if you can and see if the key is stuck somewhere. This happened to me once with a rubber key type of remote. It drove me crazy.
Posted on May 10, 2009
  • 668 Answers
SOURCE: Unit keeps turning itself off.
This Unit is a LCD Rear Projection and most likely the Lamp is causing the problem. I would replace it with a Sony Lamp only. You can order it from Sony at 1800-222-SONY.
I hope this helps,
Skyassoc
Posted on Sep 20, 2009
SOURCE: I cannot find the sky
I have a A637F and the code that works for me is 0253.
Cheers
Posted on Dec 26, 2010
hulk917
  • 247 Answers
SOURCE: The volume will go to
The Samsung brand is the most universal remote compatible tv out there, sounds like either a neighbor or even someone in your own home has a Samsung product that will work on your plasma. for example if someone within range has a Samsung dvd or blue ray player the volume up and down button will work on the Samsung tv also.
Posted on May 30, 2011
I have a 3.5 year old Bush LED24970. Recent;y it has decided to turn down the volume to zero, 3 or 4 minutes after switching on. I've tried all I can think of. What can be done? JP
check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Jun 15, 2016 | Bush Televison & Video
Volume adjusts on it's own on my Bush standard TV Bush LED26916HD 26" HDTV-Ready LCD LED TV FREEVIEW
My bush 50inch .volume kept going up and down.only to discover i had the audio description on.turned it off via the menu options and it was fine then
Jun 22, 2012 | Televison & Video
When i start my acer mini laptop then i get backround voice like mike voice then how i close this voice please give me advice
Try simply turning the volume down or mute the volume.
Maybe you need to reinstall your audio drivers.
Get onlineand got to www.google.com In the google search box type: "AcerSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Audio drivers.
May 12, 2012 | Acer Aspire One PC Notebook
I cannot find the sky remote code for a Bush A637F model, can you help
Cheers
Oct 25, 2010 | Televison & Video
My remote control on my 37 lcd tv will not work
I also had this problem.. Try this
Turn your tv off at the wall without putting it on standby.
Leave 30 seconds then switch back on.
At the side of the tv is a menu button, press and hold it for 15 seconds.
Now press the menu button on your remote control.
You should now be able to use the remote.
Jun 15, 2010 | Televison & Video
Cant get Sky+ Remote to work volume on Bush LCD32TV16HD
I rang Bush help line and got more set-up codes and that worked,we can now work the volume off the sky remote.
Oct 24, 2009 | Televison & Video
POLAROID 37" TV - VOLUME STUCK ON LOUD - CAN'T TURN UP OR DOWN
sound like the volume is locked out you can access this in the main menu to unlock it
May 29, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Bush 22" LCD TV
Hi.
What is the TV model number ?
Nov 29, 2007 | Bush 5693D 24" TV
Volume starts out at full
If you read the owners manual careful it tells you something about setting the volume at start up buy setting the volume to desired level then push in and hold a few seonds the volume knob and that volume should be reached every time you start your vehicle.
Oct 12, 2007 | Dual XDVD8181 Car Video Player
Televison & Video Logo
108 people viewed this question
Top Televison & Video Experts
Electro Med Services...
