Question about LG WM-2277HW Front Load Washer
My LG Wd1238c front loader machine wont turn on, plugged in but nothing even turns on..
The power point works but still nothing
    Top Expert:
  • LG Master
  • 9,472 Answers
You have a dead control board that will need to be replaced. Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Posted on Nov 28, 2012
3 Suggested Answers
SOURCE: LG wash machine # wm 2277 hb front loader display flashes LE wont
We had the OE message come up and did the above procedures...that didn't fix it. I removed the dual pump modules (they come off in one piece...one is the recirculating pump, the other is the drain pump). Turns out, the drain pump impeller design sucks. Even though it turned when I put power to the pump, that doesn't mean your pump isn't bad. Once it is under load pumping water, the impeller can slip where the pin connects to it from the motor. We replaced the motor for $60 and that fixed the problem. Our unit is at least three years old and we have a family of four, so it does get used quite often. Nobody told us about the filter at the bottom of the unit and I figure if we knew this ahead of time, we probably could have avoided the impeller issue...but it is still a sub-par designed motor/impeller. The new one I ordered looks like an updated design so I don't see this happening again. It is quite easy to remove and replace the pump, btw.
Posted on Feb 21, 2010
rickead1
  • 1998 Answers
SOURCE: LG WD1238C front loader water is leaking out of
The cause of this is almost always something blocking between the outlet of the dispenser housing
usually it is the large hose that goes from the dispenser to the top of the tub itself if you remove the 2-3 screws along the back of the machine and slide the top cover towards the rear of the machine and then remove the top cover completly this will give you access to this area Usually you will find a large soap deposit or debris stuck in this hose or near the outlet of the soap dispenser housing itself . You have to remove the top cover in order to physicly clean and check these areas if you have any further questions message me back and please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation Thanks Rick
Posted on Jun 21, 2011
Whirlpool front loader keeps tripping fuse when turned on
Either a dead short or you you are using a ground fault circuit breaker.
gfic Google Search
Sep 28, 2014 | Washing Machines
Gfwn1100lww ge front loader washer wont fill with
check your water lines could be clogged or not even turned on at the valve behind it, also might be not enough pressure in line to make it work
Sep 25, 2013 | GE GFWN1100LWW Washer
Lg wd-1438rd wont turn on
It sounds like when you moved the machine it pulled a plug off inside the machine, the only way to find out is to disconnect the power and remove the top of the machine, You will be able to see if anything is not connected as it should be.
May 14, 2017 | LG WM2077CW Laundry XL Front Load...
LG FRONT LOAD WASHER MODEL. WD1238C. DOOR WONT OPEN, THE MACHINE CAN PERFORM NORMAL WASHING FUNCTIONS AND FINISHES ASPER NORMAL, THE DOOR JUST WONT OPEN. CHILD LOCK NOT ON...
(It COULD be that there is water still inside which is why the machine keeps the door locked. It therefore could be a problem with the drain filter or the drain motor. I'm having to guess!)
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Mar 07, 2011 | Washing Machines
LG Front Loader WD-8074FHB
sometimes you just have to force the door but first try hitting the machine near the door lock sometimes this helps the door interlock may be stuck in the closed position
Mar 02, 2008 | LG WM1812C Front Load Washer
LG WM-2277HW Front Load Washer Logo
630 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
