How to remove the side panel from a Fujitsu-Siemens Scaleo Home PC?
I can't manage to remove the second plastic "tong" that keeps the panel locked to the tower (I removed the first introducing a flat screwdriver from the back, but I can't manage to introduce the screewdriver further in order to reach the second tong). Thanx everybody for helping
  • Computers & ... Master
  • 5,660 Answers
Need the model number Chiara. Look on the back near the Windows product key, or up on the side of the computer tower. There are MANY versions of the Scaleo model series, and also case designs. Post back in a Comment. (Clarification and Comment options not available, at the moment. So I'll use a Solution box for that, and a Comment box for a Solution, lol!)
Posted on Nov 28, 2012
  • 3 Answers
SOURCE: My Fujitsu Siemens Scaleo P
I also have a Fujitsu-Scaleo P, yesterday I had the same problem exactly as described here. The issue is that the CPU fan does not work anymore. It is easy to replace, only four Phillips screws to be removed. I simply don't know if the new fan replacement can be bought alone, or if the air duct will be in the replacement kit, along with the aluminum block. It is a Cooler Master Model made by Protechnic Electric model MGT 9212ZR-W25. If it wasn't that the problem, when the computer is still cold, try to boot it, press DEL which will bring up the BIOS Setup Menu, and you can see if the Fan still works: in one of its menus shows the Fan RPMs and CPU Core Temperature. Good luck.
Posted on May 04, 2008
  • 55 Answers
SOURCE: Finding the videocard in a Fujitsu Siemens Scaleo 600 PC
firstly check the pci slot where your moniter you plug in it. and change the card.
ramesh
Posted on Nov 29, 2008
start it up with the side of and watch the fan if it starts up and then stop or it sops the sarts again slowy and see if you can feal fan draft quite alot and put a house fan in front of side of pc as im 100%sure your fan is not cooling it and if you dont change it it will bur out completly a house fan needs to be on a few seconds as it need to stay cool a while for it to work letme know or ring me on 07519084655 i av a friends and it does swich of after 30 mins but i can not get it to do it just fan stops or goes round slowly cannot feel fan at all but does come to screen u can aso disconect hard drive and start it up if it switches of still then u know its not hardrive you will still be able to get writing on black screen saying hardrive fail but if it stays o then u need hardrive good luck let me know the out come
Posted on Jul 03, 2009
joecoolvette
  • 5660 Answers
SOURCE: fujitsu siemens scaleo 600 desktop just keeps
1) Bad Power Supply. Power Supply has a weak voltage power rail.
Electrolytic Capacitors are breaking down inside the Power Supply.
http://en.wikipedia.org/wiki/Switched-mode_power_supply
The capacitors build up a charge long enough to work briefly, then break down.
2) Electrolytic Capacitors on the motherboard are breaking down. Specifically the one's used in the motherboard Voltage Regulator Circuit.
A) http://www.hardwaresecrets.com/article/616
B) Visually identifying bad capacitors,
http://www.capacitorlab.com/visible-failures/index.htm
C) Video showing what happens with bad capacitors (Electrolytic) in the motherboard Voltage Regulator Circuit (Starts at 0:04)
http://www.youtube.com/watch?v=KN6_-8fYHo0
Await your further diagnoses.
Posted on May 23, 2010
  • 1027 Answers
SOURCE: i can't find a driver for my grafique cart of
on this page
http://ts.fujitsu.com/support/downloads.html
type scaleo 600 for searh
you will be redirected to drivers download page
Posted on Feb 22, 2011
Scaleo P drivers utilities cd wanted
Get onlineand got to www.google.com In the google search box type: "FujitsuSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the drivers.
Apr 23, 2012 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
I can't find a driver for my grafique cart of siemens fujitsu scaleo 600 thank's for help :)
on this page
Feb 22, 2011 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
I want to download sound drivers for my fujitsu siemens scaleo 600
on this page
type sclaleo 600 for searh
you will
be redirected
Jan 09, 2011 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
Uninstall network driver for fujitsu siemens scaleo c
go to device manager by typing in start search device manager. under network adaptors right click on the network device you want to uninstall. click uninstall.
Apr 08, 2010 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
Ich habe keinen Audiotreiber mehr auf meinem Computer Fujitsu Siemens Scaleo 600
The German download page is found here
Fill in the field: Bitte geben Sie die Serien-/Identnummer des Gerätes oder den Produktnamen ein: "Scaleo 600"
Then open Audio, look up in the manual of your Scaleo 600 wich audio
chipset your motherboard has onboard to download the the correct drivers.
Note: Use the Fiujitsu Siemens site with Internet Explorer because it does not work very well with Firefox and next time putt your question here in English, you'll get more help in this way.
Succes.
Jan 08, 2010 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
Need driver for scaleo 600 network adapter,don't recognize,or find any adapter for network,i use windows 7.please help me,is very important
you can download it from here http://www.bioticaindia.com/scaleo-600.html instal it and check in device manager if is properly instaled(working).
Dec 14, 2009 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
ramesh
Nov 29, 2008 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
Onboard Sound Drivers and Video Controllers
Hi EsteG, found all your drivers for your SCALEO 800, these are also used for the SCALEO 800Si 2410 Silent+. They call it the 800 series, for XP. Click the link below.
http://support.fujitsu-siemens.com/com/support/downloads.html
Because it's the whole 800 series you'll need your manual to pick the correct Audio driver as noted in your manual. To narrow down the ammount of drivers in each area. There should be a sticker on the PC that has the serial No# . Enter that number on this link below. (Siemens Fujitsu) does not make this easy.
If I can be of more service, just ask.
Good Luck & Kind Regards.
Mike
Mar 25, 2008 | Siemens Fujitsu SCALEO 800Si 2410 Silent+...
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
