Question about Hitachi Televison & Video
Who want to buy quality integrated circuits (IC) for electronic online ?
Quality integrated circuits (IC) for electronic online
I HAVE SOME EXPERENICE ONLINE..
I SUGGEST YOU THAT YOU CAN VISIT THE ' 17ic' AND ' HQEW.NET '.
http://www.hqew.net/
Posted on Nov 28, 2012
Where do i find the Ic
IC or Integrated Circuits are common in all electronics devices. The Sherwood Receiver mentioned will have lots of them. Each one will do a specific task. IC's look like black boxes with at least 8 pins coming out of them. I will post an image of a typical ones.
Otherwise you will have to be more specific.
Apr 27, 2014 | Sherwood RD-6108 Receiver
No Sound on AM or SW
Hello
If the set receives FM signals without any problem, and only fails to receive AM signals, the IC [integrated circuit] used in it is faulty. The number of the IC used with your radio is CXA 1376AS. It is a replacable type IC, and can be bought from most of the electronic spare part shops at your town. If you want further details about its service manual, get me by Fixya. OK.
Nov 11, 2011 | Sony ICFSW7600GR FM Stereo World Band...
Dynex 40" lcd tv screen
There's an IC (integrated circuit) that handles pictures on the t.v. and can cause lines and/or discoloration on the screen. At most, having an electronics service provider changing this IC (integrated circuit) will bring back the original quality of the picture.
Mar 18, 2011 | Televison & Video
I have an 04 Nissan Maxima. My front windows roll down by themselves and the doors will unlock. Any idea why this is happening?
Sounds like your main window/door switch is malfunctioning.
The switch has an electronic circuit with integrated circuit chip(IC), it might have been damage, due to rain or vibration.
You have to bring your car to the nearest Nissan dealer to check on that main switch.
You could try to check it by yourself, there might e something short circuiting the IC, that makes all the switches works without pushing any of them.
Hope that helps out!
Dec 07, 2010 | 2004 Nissan Maxima
I would lke to know the reference code on the audio out put ic, used in the VHF MARINE IC-M302.
Quick description as per ICOM Manuals:
Quote
The AF amplifier circuit amplifies the detected signals to drive a speaker. The AF circuit includes an AF mute circuit for the squelch. AF signals from IC1 (pin 9) are applied to the de-emphasis circuit (R61, C89). The de-emphasis circuit is an integrated circuit with frequency characteristic of –6 dB/octave. The integrated signals pass through the high-pass filter (Q5, R62–R67, C90, C91) to suppress unwanted lower noise signals. The filtered signals are applied to the AF mute circuit (IC7B), and then passes through the [VOLUME] control (VR board; R1) via the “VOL1” signal. The signals are applied to the AF power amplifier (IC6, pin 1). The output signal from IC6 (pin4) drives the internal (external) speaker.
Unquote
I thus assume the IC you are looking for is the IC described as IC 6.
Data sheet availible online: http://www.datasheetcatalog.org/datasheet/sanyo/ds_pdf_e/LA4425A.pdf
The IC is a Sanyo LA4425A. A 5W Power amplifier.
Apr 02, 2010 | Icom IC-M302 VHF Marine Radio
I need ic used in power supply p4 ATX 350 . I need datasheet for integrated circuit ( IC ) the no. of ic is AT2005.
man that going to be amouth impossible to find because is more cheap to buy a new power supply for 25 bocks that going to kill your self trying to repair one sorry but good luck
Jan 30, 2009 | Computers & Internet
Jungle ic
Either Electronix.com or matt electronics. or NEC should have it.
Jan 04, 2008 | Toshiba 43H70 43" Rear Projection...
All functions turn on, but i can listen to music. The output integrated circuit is broken
Hi there OSKY,
I would suggest that you try and obtain the service manual for this system of yours. Usually from the manufacturer or an alternative source.
The model number and the manufacturer are listed on the rear panel of the sound system.
Once you get the service manual it will list the correct part number and the type of IC installed in that particular model..
You havent listed the model or manufacturer for me to search my own service manuals , so I cant provide you with the IC part number...without a good description of it..
Cheers YUBEUT...
Nov 16, 2007 | Panasonic SC-EN7 CD Shelf System
TELEVISION
This may indicate a problem with the signal processor IC (Integrated Circuit)or the color burst signal might have insufficient amplitude which would also lead back to the signal processor IC. You will need a schematic to find the IC and you will need a multimeter and an oscilloscope to view the video waveform. If you do not have a background in electronics do not attempt this repair on your own please take the set to a qualified repair shop. The loss of color points to the loss of the color burst signal or the failure of the video circuitry to respond to the color burst signal.
Sep 20, 2007 | Televison & Video
PT-53WX42 IC replacement
The two convergence IC's are generic part# STK392-110 and Panasonic part# C5AA00000203. Also check for burnt or discolored resistors nearby. Since this is such an easy repair,a schematic is not necessary....The hardest part is identifying the burnt resistors and aligning the green convergence in the service menu.
Sep 18, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
