E5 error in onida split ac - Heating & Cooling
  • 44 Answers
SOURCE: water leakage in onida split AC
clogged drain. dirty coils, or froze up. clear the drain with a shop vac. call a tech to clean coils or check charge on unit
Posted on Jul 12, 2009
  • 25 Answers
SOURCE: how to clean the filters in split airconditioners
Check on top of the indoor unit. On some models, the filter will slide out from there without having to open the cabinet. On others you will need to pull on the top front and the panel will swing down (it will be hinged) and the filter will be behind that panel.
Posted on Mar 24, 2010
  • 29 Answers
SOURCE: My onida split ac leaks water down the wall.how to
check to see if the drain to outside or your condensate pump is blocked with dirt, lift the unit off the wall and make sure the drain hose is correctly attached in the back of the drip tray. also ensure the unit is level using a spirit level.
cheers
Posted on Jul 05, 2010
  • 13 Answers
SOURCE: Onida split Ac displays F5/F6 error and trips
F6 error is related with the indoor blower motor check the return signal wire of motor with the small connector and fix it properly.
Posted on Jul 29, 2010
ondia split a/c showing f6 error
Posted on Apr 06, 2011
Onida splite a.c
http://onida.com/downloads/ac/User%20manual%20Central%20Controller%20OZJ7011.pdf
E1 Compressor high pressure protection
I suggest that a qualified service technician look at the unit, since it is pretty complex. I would start by calling a company which servies your type of unit and tell them you have an Error code E1, Compressor high pressure protection.
May 01, 2014 | Heating & Cooling
Error problem e9 in onida 5star split ac
what means of e9 error code in onida split ac ?
Mar 13, 2013 | Heating & Cooling
Onida wash machine error code e5
what is E5 error code in onida sparkle fuzzy logic
Jan 04, 2013 | Washing Machines
My onida split ac shows F6 . What can I do?
onida 1 ton split ac F6 earror how problem retified
Mar 10, 2012 | Heating & Cooling
IDEC aircon E5 error what does it mean?
i am air con tech and i face all ready this problem may be it will help u . e5 error is ur air con not have gas becoze of that the low presser switch give error on disply thanks best regard for all. pls let now if its help full
May 27, 2010 | LG LSC183VMA Split System Air Conditioner
Heating & Cooling Logo
461 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
