Question about Fujitsu Siemens LifeBook T5010 Tablet PC
Fujitsu Siemens T5010 penabled upgrading to dual touch
I bought the second digitizer CP444584 and it seems that I need a new lcd cable to work with it . Is that true ? Aren't wacom digitizer all using the same 14 pin connector ? Or the CP444584 uses other configuration ? My old penabled digitizer has only 9 pins out of 14 connected .
    New Friend:
Help, is this how you upgrage a pen only to a multitouch? I need the part numbers to do this..
Posted on Apr 23, 2013
2 Suggested Answers
SOURCE: changing keyboard on Fujitsu T5010
Remove the square screw covers above the keyboard on either side of the swiveling screen hinge. Unscrew the 2 screws and use a small flat head screw driver to remove the plastic cover above the keyboard. Do this by inserting the screw driver underneath the plastic cover near to the f keys on the keyboard and gently pop the cover off. Carefully remove the ribbon from the motherboard, use a small screw driver to release the clip that holds the ribbon in place (ribbon located above f3,f4 keys). Slide the keyboard up and it should release if it doesn't then there may be some sticky tape holding the keyboard down, this is located behind the f2,f3,f4,f5 keys, carefully pull the keyboard away but hold the keyboard by the f keys so that you do not damage the keyboard by bending it. Reverse the procedure to fit new keyboard
Posted on Dec 05, 2010
Can i buy a new screen for my icraig tablet cmp759
Replacement Touch Screen for iCraig Craig CMP756 Dual Core 9 ...
www.actablet.com/replacement-touch-screen-for-icraig-craig-cmp756-dual-core-9-in...
  1. Cached
  2. Similar
Digitizer Glass Capacitive Touch Screen Panel Replacement for iCraig Craig CMP756 Dual Core 9 Inch Android Tablet PC Features: Brand new, original touch ... Missing: cmp759
Amazon.com: Touch Screen/Panel Digitizer Glass Replacement Parts ...
https://www.amazon.com/Screen-Digitizer-Replacement...Tablet/dp/B00J09P2SM
  1. Cached
Buy Touch Screen/Panel Digitizer Glass Replacement Parts for CRAIG CMP738b 7" Tablet PC: Screens - Amazon.com ? FREE DELIVERY possible on eligible ... Missing: cmp759
LCD Display Screen Replacement for Craig CMP745e iCraig ...
https://www.amazon.com/Display-Screen-Replacement-Craig.../dp/B00LTB655S
  1. Cached
There are two layers of screen for a tablet. The one on the top is a touch screen, which works for the function of touch. The other below is the LCD screen, which ... Missing: cmp759
craig tablet cmp759 replacement screen - Buy Wholesale Phone ...
m.totobay.com/wholesaletags/craig-tablet-cmp759-replacement-screen/
  1. Cached
Items 1 - 20 of 5498 - craig tablet cmp759 replacement screen - Wholesale craig tablet ... Craig tablet 746e screen replacement icraig CMP759 screen panel ...
Craig Electronics Inc.
https://craigelectronics.net/
  1. Cached
Whether you are looking for audio products like our Bluetooth/WiFi Speakers, or portable products like our Action Cameras, and Tablets, we bring you the ... icraig tablet cmp759 Google Search
Feb 01, 2017 | Tablets & eReaders
I have windows xp,sp3 on a Siemens Fujitsu Lifebook T4010D. First of all, the tablet and the pen didn't work after installing the OS, also with all drivers installed. A few days ago, when xp was...
All of these drivers must be loaded;
LifeBook T4010D Driver Name Version Size (bytes) Audio V 6.14.1.3916 1,926,959 ACPI Device Driver V.1.21 9,437ACPI_Ext Device Driver (For model with Integrated Bluetooth) V.1.0 8,365 Bluetooth Device Driver (For model with Integrated Bluetooth) V.3.01.03F 15,615,696 Chipset V.4.30.1006 2,374,963 Fujitsu HotKey Utility V.2.30 1,119,189 Fujitsu Button Driver V.1.1.0126.2004 273,237 Fujitsu Button Utility V.1.0.0825.2004 976,478 Intellisonic V.2.0.1 4,077,455 LAN V.7.84.0.0 154,167 Modem V.2.1.41 883,675 MultiMedia Bay V.1.0.7.4 4,964,535 Radio Control (For model with Integrated Bluetooth) V.1.0 853,561 Smart Card Slot V.2.7.3.2 3,110,839 Security Panel Application V.1.2 3,653,534 TouchPad Mouse V.5.4.402.9 1,928,173 Touch Panel Driver V.1.03 22,505 TPM (For Model with Integrated Trusted Platform Module) V.1.7 17,542,125 Video V.6.14.10.3741 7,234,518 Wireless LAN Atheros (For 802.11a/b/g) V.3.1.2.21 3,980,525 Wireless LAN Atheros (For 802.11b) V.3.1.2.13
Jun 13, 2017 | Fujitsu Siemens LIFEBOOK T4010D Tablet PC
Changing keyboard on Fujitsu T5010
May 28, 2010 | Fujitsu Siemens LifeBook T5010 Tablet PC
Fujitsu Siemens Black Screen problem
Hold the power button in for a few seconds, until it powers off. When it reboots, change your power settings. Don't shut the monitor off after any time span, it isn't necessary.
Aug 08, 2009 | Fujitsu Siemens LifeBook T1010 Tablet PC
Toshiba screen
Make sure the cable that connects the screen to the tablet is firmly in place.
Upgrade or reinstall your video card drivers.
See if those help. If not just comment back.
Aug 16, 2008 | Fujitsu Siemens LifeBook T3010 Tablet PC
DISPLAY PROBLEM
the backlight is broken, call the store you bought it to have it replaced (if it's still in warranty)
Dec 15, 2007 | Fujitsu Siemens LifeBook T3010 Tablet PC
Do I need a battery to run the PC Tablet?
THe manual for your specific model can be found here: http://support.fujitsu-siemens.com/Manuals/ShowDescription_KMT.asp?DokuID=202607 Documents for othe models and languages can be found here: http://support.fujitsu-siemens.com/com/support/manuals.html
Sep 24, 2006 | Fujitsu Siemens Stylistic ST5022D Tablet...
Fujitsu Siemens LifeBook T5010  Tablet PC Logo
380 people viewed this question
Top Fujitsu Siemens Tablets & eReaders Experts
Martin Murray
Lakshman P
fyigen
Are you a Fujitsu Siemens Tablet and eReader Expert? Answer questions, earn points and help others
