Question about Canon Pixma iP2702 PrinterCalculatorPaper
Printer won't accept ink cartridge
I removed the black ink cartridge, put it back, but the printer won't recognise it
    Sergeant:
  • 241 Answers
The contacts on the cartridge for this printer are pretty tempremantal. Try giving them a gentle wipe-down with a piece of non fibros tissue. You may want to wipe the corresponding contacts inside the printer too.
If this fails to help it may be that the contacts have been damaged when handling it. In this case replacing the cartridge is the only solution.
Posted on Dec 28, 2012
I use 3rd party ink and why my color ink light up at my printer pixma mp 287
This will either be because your printer is having trouble recognising the cartridges or warning of low ink because the cartridges have been refilled. Connect a computer to the printer and it will hopefully give you more info.
If your printer cannot recognise the cartridges try wiping the contacts on the front of the cartridges and re-installing. If your printer still doesn't recognise the ink cartridges then sadly they will need replacing.
If it is just a low ink warning then carry on printing untill the printer thinks the cartridges are empty and prevents you from printing. You can them get around this message by pressing the stop/reset/resume button for 5 seconds and continue printing. More information on this can be found here: http://www.refreshcartridges.co.uk/igloo/the-infamous-canon-resumestopreset-button/
Hope this helps.
Feb 21, 2013 | Canon PIXMA MP210 Photo All-In-One Printer
Both lights on printer flashing
If you set to black and wite it should also print pictures by the way, it does not accept grayscale because it won't be able to print in grayscale photo quality.
Aug 20, 2008 | Canon PIXMA iP1600 Printer
My hp photosmart 5514 won't print. I put in new ink-black and color- and it goes through the motions, but the page is empty
I just had this exact problem on my HP 5514. Black won't print after running out of black ink. New cartridge no good.
I tried everything-no good. I suspected the pinholes in the printhead were clogged with dried ink because I didn't change cartridge in time.
The fix that worked perfectly was when I hacksaw top off old black cartridge & removed all foam wicks so now I had a funnel(can see clear thru). I installed the cartridge & filled it with alcohol, printed page & did head clean; then printed few more pages. Problem cleared almost immediately. I then soaked up extra alcohol inside cartridge with paper towel. Removed modified cartridge & installed good one. I guess this could be done for colors as well. I don't know if this is a proper procedure, but it sure worked well for me.
Oct 05, 2012 | HP Photosmart 5514 e-All-in-One -...
After printer said ink cartridge was empty I removed it & found it was not-I put it back in printer & now getting error message that the cartridge is used & needs to be replaced. How can I
your only option it to replace it with a new one . printer mfg's have chipped the cartridges and they can not be reused.unless the chip is recoded as new .
Aug 16, 2017 | Ricoh Aficio GX3050N Printer
Epson workforce 520 won't recognise ink cartidges
When replacing ink on the Epson Workforce 520, Ensure the cartridges have the correct/same number of gold contacts. Ive seen them with 7 and 9 gold square contacts and they were otherwise identical, and the ones with 9 contacts threw an "cartridge not recognized" error on the printer's dispay.
Feb 24, 2012 | Epson Workforce 520 Printer
Epson Stylus T21 printer not accepting ink supply system
First of all let cartridge in the printer.... Then press Start.. it will say cartridge not recognised... then remove all cartridge (do not turn off printer).. then wait for 15 minutes...then again put cartridges in head... then press start..start...start..It will recognise on 2 to 3 tries.. Works on Epson TX210,200,410...If u want to be recognised then do not turn off printer...
Jul 11, 2010 | Epson Office Equipment & Supplies
After installing re-filled ink cartridges, both color and back & white, the printer message that shows ink level still shows low level ink? How do we resolve?
Try this procedure:
1. Open printer lid so cartridges move to center of carriage.
2. Lift clamp and remove black or color cartridge from the holder.
3. Place cartridge on table with copper contact strip facing you.
4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
8. Open lid again, remove cartridge, remove tape.
9. Reinstall cartridge and close lid.
Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 22, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
Dell 942 AIO printer won't recognise black cartridge:
I think you purchased a black cartridge with bad electronics. Basically your cartridge can't communicate with your printer and you should exchange it for a new one. There is no way to "fool" your printer into accepting refills with bad electronics. What you can do is when you get the message that you aren't using genuine cartridges and it won't be able to estimate ink levels is to check the box indicating to ignore the ink levels.
Nov 13, 2009 | Dell 942 All-In-One InkJet Printer
My epson r285 wont recognise compatable inks
My Epson R285 will not recognise compatible cartridges,mainly the black.I ran out of black ink and installed a compatible cartridge but it did not recognise it.To get the printer running I had to buy a genuine one which worked.I then ran out of all the other colours soon after and installed compatible ones which were accepted.I have now ran out of the black again but the printer will not accept the compatible cartridge.How can I solve this problem as the printer has accepted black compatibles before.
Thanks Padgy
Oct 09, 2008 | Office Equipment & Supplies
Canon Pixma iP2702 PrinterCalculatorPaper Logo
120 people viewed this question
old marine
old marine
