Question about Pool & Spa
Need to find out how i change the timer on my solor controler for my swimming pool
Turned it off over winter and now comes on at 8pm instead of 1pm
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 22 Answers
Is it mechanical or digital
Posted on Dec 01, 2012
5 Suggested Answers
  • 22 Answers
SOURCE: swimming pool
check the spider gasket under the valve top to see if it in broken.if it is not the filter has a bad lateral in the bottom of the tank.
Posted on Jul 10, 2009
  • 366 Answers
SOURCE: jacuzzi at higher elevation to swimming pool,
you probably have a check valve (back flow preventer) on the line that supplies water to the spa when the pool is filtering as normal. Your check valve may have some debris in it or the seal inside may have failed allowing the water to drain into the pool when the system is off. You should see a valve on the return line that splits off from the pool return line on your system. There are several different check valves on the market, some have a clear lid that you can inspect without taking it apart. Some of them cannot be taken apart. Your challenge will be to find the check valve, then try to check to see it debris may be holding it partly open or it the rubber seal inside is damaged or missing. I hope this helps.
Posted on Sep 24, 2009
SOURCE: Hi, I have let my
You need to get liquid chlorine and add about 2 liters and let your pool filter run for a couple of days and in the mean time clean your filter twice daily. If the pool at this stage is still a little green add more chlorine and broom the bottom to stir it up. After this as once your pool is back to almost normal, clean the the filter again and add clarifya. To keep your pool in good condion over summer buy 2 pool floaters, put 2 chlorine tablets in one and blue block pool sparkle in the other and each week add 1 liter of chlorine. Hope this helps you as i have the same pool and i do this and don't have any problems. You can also add salt to your pool if you like but dissolve it in water before you add it to the pool.
Posted on Nov 08, 2010
  • 31 Answers
SOURCE: HOW TO WINTERIZE AQUAMATE ABOVE GROUND SWIMMING
It depends if you are leaving the pump outside, if you are the you need to run RV or pool antifreeze through it, however the best thing to do is bring it inside.
Posted on Nov 26, 2010
How do I turn off the timer on my pool pump so it won't come on
if you are using a hayward control panel, either change the timer or push the 'service' button once. if it is a seperate timer, turn off the breaker to the timer
Jun 13, 2014 | Hayward Pool & Spa
Hooked up pump after the winter primed it but will not suck up water?
check top seal and intake union see if loose air leak will cause not to prime
May 21, 2014 | Hayward 1 Hp Max - Flo Swimming Pool Pump
Is timer the problem
I would think whatever is hooked up to the timer is bad. Not the timer itself. Disconnect/unplug the pool pump from the timer and see if the timer trips the breaker.
Dec 04, 2013 | Intermatic 220v T104p Swimming Pool Pump...
Timer cuts on , but will not turn off
assuming that this is a mechanical timer with set points for off and on red points turn on and black points turn off. set the red point for your on time and then be sure to set black point for off. Best to tighten 1/8 turn (slightly) with pliers so it does not slip
Nov 11, 2013 | NSI Tork Timer Switches | Tork 1104-FM...
The white wire has come off of the timer. There are two possible spots open on the timer. Which one do I use?
1) Copy following links to help identify timer:
http://waterheatertimer.org/Boxtype.html
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
http://waterheatertimer.org/Woods-timers-and-manuals.html
2) Add a comment and at least give us a hint about your timer.
Is this a box timer, or in-wall timer, sprinkler timer, spa timer, pool timer, low voltage power pack, plug-in timer, delay timer, cycle timer, digital timer, analog timer... etc.
Describe timer in detail.
What voltage are you using? 120, 208, 230, 240, 277, 480, 600 etc.
What does timer control?
Is this for a nuclear power plant, or kitchen light bulb, or 3-phase motor, refrigerator defrost, freezer defrost, swimming pool heater, etc.
Feb 19, 2013 | Hardware & Accessories
Where can you go winter swimming in australia?
the bondi iceberg! it is located at 1 Notts Ave, Bondi NSW 2026, Australia. the home of winter swimming!
Feb 13, 2013 | Pool & Spa
I need to know how to set this timer for a large swimming pool, and how long I need it to run, to keep it clean. I believe it is about 35,000 gals., in-ground pool.
You have Intermatic mechanical timer connected to swimming pool pump/filter.
Open following link to read about setting timer:
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Lift and rotate dial until current time is lined up with stationary pointer.
Put on-off trippers on outer edge of dial.
Timer comes with 2 sets of trippers, and you can order replaceable trippers. Up to 12 sets of trippers can be added to dial for a total of 12 ON and 12 OFF events each 24-hour period.
For 35000 gallon, pump should run at least 6 hours each 24-hour period. During freezing weather, if pipes are above ground, you can remove trippers from dial, set override lever to ON position, and run pump 24-hours to prevent frozen pipes.
Jul 12, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
HOW TO WINTERIZE AQUAMATE ABOVE GROUND SWIMMING POOL PUMP
Open the plugs on the bottom front of the pump pot and on the pump housing itself. These two plugs will do the pump and just the pump. You should have simmilar plugs on the filter, heater, chlorinator and any other equiptment on the system.
Oct 13, 2010 | Hayward Sp1580x15 Power Flo Lx 1.5hp...
Turned the timer switch on, the pump starts and one second later
reset breaker overide timer by tuning on if this works it is a timer issue
Jun 07, 2009 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
Pool & Spa Logo
19 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
