Question about Asrock G41MVS3 Motherboard
No VGA output
I'm upgrading my old pc into new one. My old pc is Pentium D 2.8GHz (915) Socket 775 with 1GB DDR2 RAM. I bought Asrock G41MVS3 as it says it support Socket 775 and supports DDR3 1333(OC)/1066/800 non-ECC, un-buffered memory. After installing the motherboard with new 4GB DDR3-1333 and new 500GB hardisk, no display (vga) output at my monitor. I dont even get the BIOS screen at start-up. Please help me solve this problem. Any solution would be appreciated. Thank you.
  • 1 more comment
  • skynet_azs
    skynet_azs Nov 30, 2012
    Hi Hans.. For your information, the motherboard is new, only the processor is old one. I have cheked power supply, its a 24pin connector and fits well. I have tested with Asus GT210-1GBDDR3 on the PCIE slot, also nothing happened. The problem still there ~ no vga outout.
  • skynet_azs
    skynet_azs Dec 04, 2012
  • Hans Pedersen
    Hans Pedersen Dec 04, 2012
    Try to let a computer repair shop look at the mainboard. The mainboard maybe has a production fault and the waranty should cover this.
  • Asrock Master
  • 3,606 Answers
Hello the drivers site is here:
http://www.asrock.com/mb/overview.asp?cat=Download&Model=G41M-VS3
The manual:
http://www.asrock.com/mb/overview.asp?cat=Manual&Model=G41M-VS3
I think you should drop the onboard graphic and install a better graphic card in the 1 x PCI Express x16 slot on the mainboard.
Check the power supply for any fault.Is it new ???
You can not use the old Power supply because it might have a 20 pin connector this asrock has a 24 pin connector.
Check also you not have used the extenal graphic power connector in the 4 pin 12 + volt on the mainboard.
Check also all your power connections.
Reply me again if you can`t find the fault.
Good luck
Posted on Nov 28, 2012
Testimonial: "Hi Hans.. For your information, the motherboard is new, only the processor is old one. I have cheked power supply, its a 24pin connector and fits well. I have tested with Asus GT210-1GBDDR3 on the PCIE slot, also nothing happened. The problem still there ~ no vga output."
5 Suggested Answers
marked
  • 6487 Answers
SOURCE: Asrock K7VM2 Motherboard Memory Upgrade
Some MOBO support different type of memory modules like ddr 400, 333,533 and other, if your computer is working fine with that PC400 it only means that your MOBO is compatible with it. Since you're planning to upgrade the memory just get another PC400 because the memory should be the same to work fine.
Posted on Jun 06, 2008
map9966
  • 2351 Answers
SOURCE: ASrock P4i45GV Motherboard
Hi sandesh8, did you know you can increase the memory size of the onboard AGP card above the 64MB? Page 26 in you're manual. If you install another AGP card into the opened AGP slot, please go to this site & only use the recomended AGP cards in the Asrock list. Click on this link: http://www.asrock.com/mb/vga.asp?Model=P4i45GV%20R5.0&s=478&c=VGA
This is one of very few video cards found on the list with 256MB of video memory.
http://www.amazon.com/nVidia-GeForce-FX-5700-5187-6725/dp/B000RPKI28
Good Luck!
Mike
Posted on Jun 08, 2008
preachw996
  • 1179 Answers
SOURCE: Asrock Motherboard problems with SATA HDD
It is possible that you are trying to use a SATA II HDD in a system that supports SATA. SATA II devices are not backwards compatible usually,
Posted on Dec 20, 2008
ghost2233
  • 3606 Answers
SOURCE: Got an AsRock P4i65G mobo
Hi, you can download a manual here:
http://www.asrock.com/mb/overview.asp?model=p4i65g
Your mainboard DOES NOT SUPPORT ECC RAM.
This ram type is ONLY intended for servers
or mainboards that are compatible for that ram type.
This is what your mainboard supports:
Dual Channel DDR memory technology
- 2 x DDR DIMM slots
- Supports DDR400/333/266 non-ECC, un-buffered memory
- Max. capacity of system memory: 2GB
Use only the asrock site when upgrading the bios.
And a bios upgrade does not supports the ecc ram anyway.
Hope this will help you.
Posted on Aug 21, 2011
Problems with new ram
This = NO
The Foxconn P4M800P7MB-RS2H motherboard supports ram memory that is either 400MegaHertz, or 533MHz.
You have installed 667MHz ram memory.
http://www.play.com/PC/PCs/4-/3274794/-/Product.html
You also need to watch the Front Side Bus (FSB) of the processor you are using.
Ram memory typically operates at HALF of the FSB of the Processor.
Processor FSB support is 800MHz maximum.
Half of that is 400MHz.
You CAN use 533MHz ram memory, however.
(This is DDR2 Sdram ram memory.
PC2-3200 is DDR2 at 400MHz.
PC2-4200 is DDR2 at 533MHz. (Also known as PC2-4300. Depends on the ram memory manufacturer.
PC2-3200 actually operates at 200MHz. { Max} It is 'Dual Pumped'
PC2-4200 actually operates at 266MHz )
What to do?
Hopefully you saved the carton/s the ram memory came in.
Ship them back, get the ram memory you need.
ALSO;
What is the FSB of the Processor you have installed?
Don't know?
Post back in a Comment as to the model name, and model number.
(Example; Intel Pentium D model 805,
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_D_microprocessors#.22Smithfield.22_.2890_nm.29
FSB support is 533MHz
No, you cannot use 533MHz ram memory. { PC2-4200 }
PC2-3200 is the max.
Pentium D model 820 for example, you can )
Nov 18, 2011 | E-Machines Computers & Internet
How do i upgrade my built in vga without buying video card? n68-s ucc
the highest the video can go is 256meg and is adjusted in the Bios an depends on how much ram memory you have installed but yo can upgrade to a PCI-E video card.Here is the manual for the board.
ftp://174.142.97.10/manual/N68-S.pdf
Feb 15, 2011 | Asrock N68S Ucc Socket AM2+ GeForce 7025...
Mother board 533 prescoot how the accpet ram and processer
This motherboard supports DDR2-800/667/533 Memory and any socket LGA775 CPU such as Intel Core 2 Quad, Core 2 Extreme, Core 2 Duo, Pentium XE, Pentium D, Pentium 4, and Celeron LGA-775 CPUs
Feb 01, 2011 | Asrock Pentium 4 (LGA 775-pin) -...
Solve Your Asrock Pentium 4 (LGA 775-pin) - 4Core1333-Viiv M/board - P965, 1333MHz FSB, Dual DDR2-800, PCI-Expr... Motherboard Problem Now!
Remove the CMOS battery from mother board and hold down the power switch for 5 minutes ,install the battery again.You also check the ram, to your another pc .If the RAM is defected, change it, as a new if you have a spare.
http://www.youtube.com/watch?v=3B9ff9ei7hk
If you face the same problem please install a another well SMPS power full.
http://en.kioskea.net/faq/7125-flash-getplus-r-operating-system-error
Hope this helps.
Jan 11, 2011 | Asrock Pentium 4 (LGA 775-pin) -...
Upgrade from pentium 915 D to dual core
The pentium d 915 is a dual core processor, albeit a bad one. You should check google for info on your motherboard to see if it supports Core 2 duo's/ Core 2 quads. I have an E6600 overclocked to 3.0ghz and it still plays games perfectly paired with my 8800gt 512mb and 4gb's ram. I definately recommend upgrading to a core 2 duo. I used to have a pentium d 915 and it was bad for gaming and the e6600 blows it out of the water. You most likely wont find the e6600 anywhere as it is nearly 3 years old. Look at sites such as toms hardware to find a good core 2 duo.
Good luck- an t-adh leat!
Mar 10, 2009 | Intel Pentium D 915, 2.8 GHz (BX80553915)...
Old computer ram upgrade without manual
564 mhz means it is a Pentium 3 or equivalent. This also means that the motherboard does not support DDR2 RAM which is exclusively for Socket 775 and Pentium 4 chipsets. Pentium 3 usually support SD-RAM, also but very rarely DDR1 RAM. Sorry but DDR2 will not work in your PC.
Mar 02, 2009 | Intel Motherboard
ECS 915-A(1.1) Ram Reading Issues
Is it a single ram module or dual ie. 2x 1gig ddr2 533?
What motherboard are you running?
Is it possible that you've given a static charge out while handling the ram?
Feb 27, 2009 | EliteGroup ECS 915-A Intel 915GV Chipset...
Dec 20, 2008 | Asrock P4V88 (P4V88 RAID) Motherboard
Upgrading
To upgrade from pentium 3 to P4 you have to change alot of the hardware.
You need a NEW P4 Socket mPGA 475 Motherboard.
New DDR RAM
New 478 PIN Processor.
You can use the old CD rom and Hard drive and any other PCI card but You Need the Mentioned Hardware to Upgarde.
Jan 08, 2008 | Intel (P42000400512SK478) Pentium 4, 2 GHz...
Asrock G41MVS3 Motherboard Logo
323 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
