Question about Hitachi C10FL 10" Stationary Table Saw 3.0HP
I have a problem with the blade height adjustment. It is stuck at the max height and will not lower. Have I stripped out the adjustment gear?
  • alvin Nov 30, 2012
    Is there a Shear pin in the adjustment gear? Has this been a problem on the Hitachi saw?
My blade adjustment lever is stuck in the highest position
Hi Cindy:
Blade height is achieved by raising or lowering the deck so it sounds like you really only may have one problem.
If the height adjustment lever is stuck and will not move, it should be fairly straightforward to look at the various components to see where it is binding, and then make corrections as necessary.
Safety First. Have the engine OFF and the key removed before you start exploring the bits.
Cheerfuls.
Sep 24, 2015 | Garden
How do you higher or lower the blades of qualcast hover mower
There are not any levers or anything to adjust blade height.
You change blade height by placing spacers above and/or below the blade. You have to remove the blade and relocate the spacers on the blade bolt to move the blade up or down.
Jul 01, 2014 | Garden
I purchashed a used 26 54 husqvarna 2007 model rider and it will not cut low enough.My murray will scalp ground if i lower deck to ground.It looks like the blades are designed to be set higher off...
Low under the steering wheel there may be an adjusting knob. If it is there are you turn it, it should adjust the height of the deck. If you lower the deck and try to turn the knob it will be difficult to turn and you will know that is what it is for, the deck lower stop. Then pull up the deck and adjust a bit and lower the deck and see where it is, repeat until satisfied with the deck height when lowered.
Sep 20, 2011 | Husqvarna Lawn Tractor - 54in. Deck, 26...
How to raise and lower saw blade
You raise and lower the table plate, NOT the blade. There is a knob to lossen and tighen the tension on the table plate and you can adjust the blade height by lowering the plate and vice versa.
Jun 20, 2011 | Dewalt DW364 7 - 1/4'' Heavy Duty circular...
How do you set the mower blade height on a riding mower. The mower deck is set by the height adjuster but how about the blade
The blade height is not adjustable on any of the tractors I have worked on or owned. The blade seats against a shoulder on a spindle and held in place by a nut. Sometimes replacement blades are not shaped the same as the original and changes the blade cuttnig height but other than in those circustances there is no adjustment.
Jun 18, 2010 | Garden
MAKITA #2703 table saw 10'' to rise and lower blade it
i would say the table is twisted then, strip it down first and if you need to "bend!" it back so it works
Mar 27, 2010 | Makita 2703 10" Table Saw, Electric Brake
My Bosch 4000 blade will not go down any farther than an inch above the top of the table.I have checked and cleaned all the gear area and can see nothing that is causing it .
First of all, love the saw. As good as portables can be, the 4000 is really great.
Now, just remedied the blade height adjustment problem, here is how:
Unplug saw.
Removed blade....not easy when you cannot raise the blade, flip the saw upside down and remove the plastic shield, turn saw upright and remove blade.
Used my compressor with blower attachment and blasted all of the dust out of the gears and screw rods with saw upright and upside down, bevel saw to 45 degrees to gain more access..
Sprayed quite liberally with silicone spray lube and gently worked blade height adjustment, adding more lube, cranking wheel, more lube....blade adjustment now works like the day I bought the saw.
DO NOT USE WD40 or the like. This will just attract more dirt in a very short amount of time.
We'll see how the silicone spray holds up.
Good luck,
RjW
Jan 24, 2010 | Bosch Electric Table Saws
Ryobi AP12 Thickness Planer---rubber feed rollers do not rotate
It is fixable if you are technically competent. All parts are still available online. It could be one of two problems:
1 - The rollers are driven by two gear & chain mechanisms on the height adjuster side of the unit. I did have a drive chain break once.
2 - If it isn't that than the gearbox has cracked / gear stripped under the torque load. This is also fixable, each individual gear and the gearbox housing are still available (10-09), but it requires substaintial teardown.
As you disassemble the unit just be careful once you remove the crossover height adjuster shaft - you don't want to turn one lifter by itself and have the planer higher on one side. It really is a simple teardown, just lots of parts. If you like the planer it is worth it; parts are cheap. If you are like me, you enjoy tearing stuff down to see how it's made and you hate throwing out $200 tools because only one little part broke!
Aug 06, 2009 | Tools & Hardware - Others
Heli max hicro helicopter just keeps spinning in circles
Spinning is caused by one of the main propellers rotating faster than the other. If both propellers are secured tightly to their drive shafts, the spin control knob on the remote control can be used to stop the spin. However, if one prop is slipping with respect to the other, the spin control knob will not fix the problem.
I've found that the set screws holding the propellers to the drive shafts tend to loosen after a while. If one prop is a bit loose and the other is tight, the relative slippage will cause the helicopter to spin.
To check, turn off helicopter power and manually rotate each propeller separately, watching the nylon gears in the body. If the propeller is moving and its drive shaft gear isn't, the propeller is slipping because its set screws are not applying enough pressure on the propeller's drive shaft.
Carefully tighten the set screw and the problem should be fixed. DON'T OVERTIGHTEN, or the plastic threads for the set screw will be stripped and the propeller assembly will be ruined.
Apr 10, 2009 | Max Heli- Axe CX Micro Electric Rc Mini...
Hitachi C10FL 10" Stationary Table Saw 3.0HP Logo
80 people viewed this question
Top Hitachi Saws Experts
John Trevino
JOHN LAPIER
Are you a Hitachi Saw Expert? Answer questions, earn points and help others
