Samsung TV Version CZ04 volume reduces itself and whenever goes back to normal
And sometimes when the volumes goes down by itself and I increase the volume with the remote to hear something....for awhile it the volume can go up but not to normal...and then for awhile to normal.
    Master:
  • 537 Answers
Your volume goes down or up depending on the demand (number of viewers} viewing the channel at any given moment. That is mormal.
Posted on Nov 28, 2012
SOURCE: TV volume increases by itself and doesn't decrease or respond to the remote control
Apparently this seems to be a known issue for this model. I called Phillips and they did not even bother asking me to try things like switch off and on again etc...They just said they are going to send someone to pick it up and fix it. I would suggest to everyone to do the same since it has to be free of charge because the problem appears in pretty much every tv set of this model.
Posted on Apr 28, 2008
ohms
  • 1879 Answers
Connect all A / V sources to the Home Theater Receiver then Video-Out from the receiver and totally mute) the TV.
Posted on Sep 30, 2008
SOURCE: The volume is turning itself down all by itself. The volume on the remote won't work, but the remote is fine with the other TV controls.
It sounds like the button is stuck. Take the remote apart if you can and see if the key is stuck somewhere. This happened to me once with a rubber key type of remote. It drove me crazy.
Posted on May 10, 2009
CAYPIANAN
  • 227 Answers
SOURCE: Volume turns up or down on its own
yes direct into the buttons the WD40 is the best thing i've ever seen, that will not damage anything you can spray it without fear and then try to activate the buttons a few times, of course with the tv off.
Posted on May 20, 2009
circuitworld
  • 335 Answers
SOURCE: TV volume goes down with out being touched
may have a sticky button or a shorted transistor switch.
Posted on Jul 01, 2009
Volume keeps going down on samsung t260hd
The digital main board has the fault. This is not a user repairable one. Contact any technician.
Dec 05, 2012 | Televison & Video
Sep 30, 2008 | Soyo DYLT032D 32 in. LCD Television
Samsung le40r74bd problem
I just had this problem with my 3 year old 32" Samsung LCD. The volume would go up and down by itself, normally just constantly going up even when it reached 100%.
I thought it might have something to do with the volume buttons on the TV itself so seeing as it was out of warranty anyway I decided to unplug it and open it up.
I gave it a good clean and I disconnected the cable for the panel of buttons on the LCD itself (volume, menu, channel etc) seeing as I never use them anyway. I then put everything else back together and tested.
It seems to be working fine now. Previously (for the past 3 hours) ever time I turned it on the volume level would come on instantly and stay on until I turned the TV off. So I’m quietly confident the problem has been fixed. But I must admit it’s only been 10 minutes, so who knows, it might come back.
Dec 18, 2009 | Samsung LE40R74BDX 40 in. LCD Television
Samsung LCD LA26R7 sound/volume problem. (please read details)
definately sounds like a control board has overheat issue and will need replacing
Aug 21, 2009 | Televison & Video
Volume decreases by itself
maybe defective speaker or audio output ic or shorted capacitor within audio circuit
Nov 09, 2008 | RCA F32648 32" TV
How do I unlock the volume control?
Zenith Electronics Corporation is a long-time leader in electronic enterainment products.
Aug 24, 2008 | Zenith C27A24T 27" TV
Hi, I have a samsung le32r74bdx lcd tv and the volume has just gone to 100 and i can't turn it down?
First, start by unplugging set to try to reset. Then make sure that all settings in audio menu are correct. Also look for stuck volume up button on set and on remote. Sometimes buttons get lodged under surrounding frame. Also try to push volume down button on tv and watch for display on tv to see any change. If when you release button volume increases by itself, remove batteries from remote to eliminate it as cause. If nothing you try works expect to replace main pcb. You can probably price it online with model number. Good luck, Russmann.
Jun 09, 2008 | Samsung Televison & Video
Tv volume goes down of its own accord
Some dust in the button to lower the volume on your TV or on your remote control might be causing it to think it's being pressed. Try playing around with it, pressing it hard so as to relieve it of any pressure on the inside.
Jan 09, 2008 | Televison & Video
I have a new Philips tv that did the same thing on me I left it off for a couple of minutes and that seems to work
Dec 27, 2007 | Philips 42FD9954 42 in. Plasma HDTV
Televison & Video Logo
278 people viewed this question
Top Televison & Video Experts
Electro Med Services...
