Question about TP-LINK TL-WR541G Wireless Router
TL-WR541G : i can't log to router and also do reset for it
I can't log to router and also do reset for it , when i turn it on power and wan led and ports 1,2,3 are always lighting without plunging any cables
  • 7,627 Answers
Push and hold the reset button for 30 seconds or so, it's usually in the back of the device near the power AC jack. http://www.tp-link.com/en/support/download/?model=TL-WR541G&version=V7
Posted on Nov 28, 2012
TP-LINK TL-WR541G Router how to change the language Chinese to english
  1. Make sure you know your hardware version!
  2. Download firmware update in English from TP Link website and unzip.
  3. Connect computer to router with Ethernet cable as per manual and in your web browser window enter http://tplinklogin.net then enter user name and password (admin,admin) to access the router Configuration Utility.
  4. From the English manual note the location in the configuration utility menus of the firmware upgrade utility. I.E. Go "system tools" (last entry in menu) then "firmware upgrade" (3rd item down). I know it's written in Chinese but you can count right?
  5. Select your unzipped file location in the window and press the button beneath.
May 10, 2014 | TP-LINK TL-WR541G Router
Error while upgrading firmware
You can try to find the old version of firmware and see if you can load it. If that fails the router is garbage.
Mar 30, 2014 | TP-LINK TL-WR541G Wireless Router
Undo computer router security password
Assuming you mean for the Router itself
1) Make sure you have your LOG IN details for your internet account at your ISP. Make sure you have an Ethernet cable that you can run to your PC
2) Turn off the Router and look for the little 'factory reset' hole on the back (some have buttens rather than holes).
3) Push a paperclip into the hole (or hold down the button) & turn on the Router
This sets the Router back to 'factory standard. MOST Routers have the Factory password printed on a label (most of those without, you log in as 'admin' with password 'admin').
You have to use Ethernet cable because, after a Factory reset, the WiFi will be 'off'. You will have to re-enter the WiFI password (and anything else you changed form 'factory standard' such as the SSID)
Nov 12, 2012 | Computers & Internet
How to connect TP LINK TL-WA901ND with Dlink DIR 615
Have you set the TP Link TL-WA901ND IP to have 192.168.1.1 as the default gateway ?
Also DHCP server is where ?
IN the TP LINK TL-WA901ND or in DLINK DIR 615
Only have one Router running DHCP and set the default gateway in the leases as 192.168.1.1.
What subnet mask are you using is it the same through out all devices ?
Oct 30, 2017 | TP-LINK TP link TL-WA901ND 300 / 11n...
I want to add a password to my wireless router
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
May 29, 2012 | TP-LINK 54M Wireless G Router eXtended...
Trouble alarm every 12 hours
Here is a link to instructions to access web based control of alarm unit.
http://www.smarthome-products.com/productspecs/DSC/TL-150-Manual.pdf
Hopefully you can log into it and find where to set time server, or at least set time/date.
Aug 14, 2017 | DSC Tl-150 Ip Communicator Lan Wan Network...
How to reset
There is a reset button located on the back of the router. You may need a paperclip unfolded or a pen to push the button in. With the power on push the button in for a few seconds, the lights on the front if the router should reset. This will put the router back to the factory out of box defaults.
Jan 30, 2012 | TP-LINK 54M Wireless G Router eXtended...
How do I connect this router?
You will need at least two ethernet cables like the one that is currently connecting yur PC to your Comcast Modem. Use one cable to connect between your pc and any of the ports labled 1, 2, 3, or 4 on the router. Another ethernet cable should be connected between the modem and the port labeled WAN on the router. Then (if you havent already), turn off the power to all three, the modem, the router, and the pc. then, turn on the power to just the modem and wait until the lights on the front of it stablize (usually about 60 to 120 seconds). Then turn on the router and wait another 60 seconds. Finally, boot up the computer. You should be able to connect to the internet. the next step will be to set up the wireless part of the router.
Feb 14, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
TP-LINK TL-WR541G/TL-WR542G cannot get started
make sure the wifi switch in the laptop is on or not
Jan 05, 2009 | NetGear WGR614 Wireless Router
Cisco VPN Client won't connect
You'll want to enable the VPN transparency. In the router's administrative web interface, click the Security Tab, then the VPN Passthrough sub-tab. Cisco VPN's usually use IPSEC, so enable the IPSEC Pass-through and click "Save Settings". If this doesn't work enable the PPTP Pass-through as well and give that a shot.
Dec 31, 2007 | D-Link AirPlus Xtreme G DI-624 Wireless...
TP-LINK TL-WR541G Wireless Router Logo
263 people viewed this question
Top TP-LINK Computers & Internet Experts
Martin Murray
John Anderson
John Anderson
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
