Question about Kitchen Ranges
Lights have stopped working on my whirlpool extractor hood at the same time. Bulbs are ok and fan works. Model AKR 906. Please help.
    Problem Solver:
  • 5 Answers
First check the lamps in another device since it some times shows its ok bur actually it is not.then look for false connections and at last the holders if the lamps went out one by one.if all together then it must be the switch.
Posted on Nov 28, 2012
  • daveokeeffe
    daveokeeffe Nov 28, 2012
    I ca hear the switch clicking but think it must be the transformer for the lights as they are 12v bulbs. Does anyone know where the transformer is located or where I can download a service manual for this model?
SOURCE: Fan and light not working where is fuse box?
Hi - I have a neff extractor fan and have the same problem. The light and fan have both stopped working. Does anybody know where I can find the fuse as I suspect that this may be the problem too?
Posted on Feb 16, 2008
  • 171 Answers
SOURCE: range hood light failure
Hi bentson,
I'm Harvey the Master Plumber.
Your problem is: Fan works but lights will not. switched bulbs and still lights not working.
You are dealing with a bad light switch. If you have the tools and the talent go for it.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
  • 203 Answers
SOURCE: baumatic cooker hood lights not working
take the bulb out and bring it with you to store and see if you can find one the same . DIY stores have tons of types.Joe
Posted on Nov 22, 2008
  • 6 Answers
SOURCE: viking hood light went out . new bulbs . did not fix it
the dimmer switch/thermostat is most likely bad. resistor inside is burned.p/n pe050033  you can change it yourself with a little mechanical aptitude.
Posted on Feb 25, 2009
SOURCE: Broan Allure QS2 Range Hood
Had same problem & fuse fixed it.
Before buying a new control board (approx $160), check the 3 amp fuse located on the inside of the vent on the control board. You have to take the light/bottom housing & black plastic air chute off to see control board/fuse.
Posted on Mar 11, 2010
Hi I have an Ikea cooker hood/ extractor fan, fan is working but lights ( 12 V. GU4 ) are not. Just replaced the bulbs but no joy.....
Without the MODEL Number... and the 12v GU4 lamp... I am going to HAZARD A GUESS that your lighting has an internal TRANSFORMER... (most likely)...
But there are less expensive things to check first
Since this is now a GLOBAL SITE you will have to disclose your Line power... (USA: average household range hood = 120V 60 cycle AC current)...
ERGO:
transformer is a 120v to 12volt output (live measurement)
For walk up TROUBLE SHOOTING
"Multi-meters" are a must...
Opening assumption
THAT YOUR NEW BULBS are good... is understandable... but possibly wrong (I'm just saying).
Power OFF
- Verify bulb continuity
- Verify switch operability
Happy hunting
Carnac the Magnificent
Feb 07, 2017 | Kitchen Ranges
I've replaced both lights in my Faber (Classic) cooker hood but though the extractor fan works the lights dont and they're powered by the same source. The light switch is on and the flap close switch is...
Probably the transformer is blown on the hood, please write info@faberspa.com if no in North America or go to : http://faberonline.com/service.html
Jan 27, 2011 | Faber (272607) Kitchen Hood
Hi my Kuppersbusch fan is not working. Is this common, any suggestion?
My extractor hoods lights have stopped working(2X 20W). I've replaced the bulbs with new ones but no joy!
Any suggestions?
Carl Dally
Oct 23, 2009 | Kuppersbusch K IKD12250.0E Island Range...
Elica oven hood fan not working
fan & light on elica extractor fan not working over cooker
Feb 25, 2009 | Kitchen Ranges
Kitchen extractor fan
hi! most of the time this will be sticky switch normally located on the inside edge of the extactor unit behind the filter mesh!.hope his helps
Dec 20, 2008 | Imperial C2036PS1-TW Kitchen Hood
Kitchen extractor fan just started making a screeching sound and slows down and stops as if something is holding it back Not sure whats happening
the motor is going bad. soon wont work. only 2 things to do either 1 replace motor. 2 replace hood. motora are usually cheap. $10-50 ...
Nov 23, 2008 | Fat extraction holder Kitchen Hood
Neff extractor fan not working
Hi rags116,
Your problem is: You have a neff extractor fan which hasstopped working. The light and fan have both stopped working. Do I know where you can find the fuse as you suspect that this may be the problem. If I don't think it is the fuse would I be able to suggest anything else.
The type is D-AY25-8 If there is another number that is more helpful please let you know. thanks Again your Neff Series 2 extractor has stopped working and you want to save yourself buying a new one!! Any suggestions greatly appreciated!
Since both light and fan require low voltage it sounds like a bad transformer. It will be mounted next to the motor. Make sure you turn off the power first.
Thank you,
Sep 24, 2008 | Kitchen Ranges
The extractor on my Baumatic fan stopped working. Thsi was shortly after the light bulbs blew which I replaced and they work OK. Any suggestions as to how i can resolve this?
Sounds like it was the main fan motor - that caused the lights to blow in the first place.
Isolate from supply, and get the fan motor checked out. If it is burnt out (inside) you will need a replacement.
Hope this helps.
Jun 05, 2008 | Baumatic F60 Stainless Steel Kitchen Hood
I have a similar problem with a Whirlpool oven hood. In my case the kitchen fiitters used a (UK) standard 3-pin plug to power the hood. The plug is fitted into a socket that is placed on top of the cupboards that house the hood.
I have replaced the 3 amp fuse in the plug and now the fan is working.
HOwever, the light isn't working and so I'm assuming that the bulb has blown and that this has caused the fuse to blow as well.
Now my problem is accessing the bulb so that I can replace it.
Mar 20, 2008 | Whirlpool GZ7730XGS Stainless Steel...
Dec 07, 2007 | Whirlpool GZ7730XGS Stainless Steel...
Kitchen Ranges Logo
198 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
