Question about Acer Aspire 7735z 17.3" Original Laptop Hdd Hard Drive Caddy W Screws Connector
My acer aspire 7735z turns on but won't boot up
It turns on and you can hear the fan running but wont boot up
sandrew
  • 2961 Answers
SOURCE: Acer Aspire 3100 boot up problem
unless it is something more serious, first keep pressing F8 when you turn on the notebook and it should enter safe mode. When in safe mode select the operating system that is highlighted and then a screen will appear with options, one being 'Last Known good Configuration', highlight this and press enter. The system will reboot and start again in windows as normal hopefully. If you are not able to get a screen showing in safe mode there is something more serious wrong and it could be hard drive fault or motherboard, but if you can see the disc drive light flickering the system is loading and you may have a graphical fault.
Posted on Aug 10, 2007
tat4u
  • 520 Answers
SOURCE: acer aspire 5610 wont boot windows XP
turn on pc enter bios setup select default settings save and restart.have os disk in drive wait for screen display any key to start from cd.press any key to load disk.in options select install windows ( not repair) your system will find existing os ,now you can choose repair or install fresh copy.if you choose to install fresh copy delete partition first and create new partition and format.
Posted on Mar 02, 2008
SOURCE: the acer aspire laptop does not boot up
This is one or two things.
HARD DRIVE PROBLEM
This sounds like a bad hard drive. What make of hard drive is in it?
Figure out what brand hard drive it is first. Then go to the website of the manufacturer.
While you are on the site look for software for hard drive repair. It could be listed in many ways. Download the windows version if you have another computer to test this in. If you do not have another computer to test this in you will have to use the Dos version. The instructions will come with the software.
Then you will go through these steps.
Do you have another computer that you can use to check the hard drive? If you have another computer or access to another computer you can download a hard drive utility that can diagnose and possible repair the hard drive. Is it a SATA hard drive? If it is a SATA hard drive you can plug it directly into another computer that has a SATA cable. If it is not SATA you will need to buy a converter so that you can hook it up to the other computer. This will be an external slim hard drive enclosure. A desktop hard drive can be put in another desktop and used as a slave drive. Just make sure that you look at the back of the Hard Drive and make put the jumper on the slave pins. Then you can run the test through the other computer to test the Hard Drive. The test will let you know if the Hard Drive is bad or not. If you can see your files on the drive you might want to back them up before you start the test. If it comes back as good go to the next step.
FIX BOOT
You can boot it up with the recovery CD and run through it as if you were doing a setup and then when the second repair comes up..... hit repair. This should repair any problem with the operating system. If you want to try the simple way... use the first repair that comes up. When the screen comes up with a blinking curser hit the number 1 then Enter........ When it ask you for a password hit enter. There should not be a password unless someone has put one in it. If there is a password it should be your master password.
Then type fixmbr and hit enter. This will fix your master boot record. If that does not work use the second repair. Sounds complicated but it is not.
Posted on Jul 01, 2008
mwalker02
  • 41 Answers
SOURCE: Acer Aspire 3050 will start to turn on, you can
There are a couple of things you can check. First be sure the battery is charged. Second, if you know the battery is good and you have the PC plugged into an outlet and your getting the exact same results, then check the plug in on the computer. Laptops have a common problem with working the plug off the motherboard when it is moved around too much. If you don't have a very good connection then it will not charge your battery and in either case will give the results like your getting now. If the plug is loose take it to a PC repair shop or where you purchased if they offer service. In many cases the plug component can be soldered back to the board and work fine. Hope this helps!
Posted on Jun 07, 2009
ailia
  • 175 Answers
SOURCE: acer aspire one black screen and no boot
Contact with notebook repairing engineer. Might be coz of some short circuit, BIOS corruption or any malfunction of the hardware.
Regards;
Hassan
Posted on Jul 08, 2009
My fan won t stop running at boot. Acer t160.
JIMMY,CHECK ALL ELECTRICAL WIRING.IF IT LOOKS OKEY YOU CAN HAVE A BAD PSU.
Jul 11, 2013 | Acer Computers & Internet
My Acer 5552G won't turn on.
try a system reset see below link
http://www.pctechbytes.com/acer/acer-aspire-system-recovery-partition/
Jan 20, 2013 | Acer Aspire 5552 5552g 5553 5553g 5560...
your hard disk maybe corrupt.
The operating system is in the hard drive, so if it won't boot, your OS might need to be repaired or reinstalled.
You will be needing OS CD to carry out the re installation
Good luck.
Nov 28, 2012 | Acer Aspire 7735z 17.3" Laptop Original...
Acer Aspire 5542 wont startup
Bring it to a repair shop and have them check it out. They should at the very least be able to recover you data.
Jun 29, 2012 | Acer aspire 5542 1615
My acer aspire 7735z laptop says bootmgr is missing press ctrl+alt+del to restart so I did. I also tried the alt f10 to restore it back to factory settings but it keeps saying fail to restore image. Can...
on the laptop then press f2 go to boot option, you can see there the 1st boot device it must be set to hdd drive, the press esc. then select exit then click enter it will boot.
Aug 04, 2011 | Computers & Internet
My Acer Aspire One Nav50 won't boot. I hear there
I have a Acer Aspire One ao532h (NAV50) a with a black out screen new screen and flax cable it came on for 3 mins and the now not a thing what should I do ?
Aug 02, 2011 | Acer Aspire One 10.1" Netbook Computer -...
My acer aspire 6920g will shut down automaticly when i want to log in to my system, after the boot menu the cooler is turning off for 1 second.
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Apr 26, 2011 | Acer Aspire 6920 Notebook PC
Acer Aspire 7735z 17.3" Original Laptop Hdd Hard Drive Caddy W Screws Connector Logo
242 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
