Worcester 35cdi 11 pilot light goes off - Heating & Cooling
2 Suggested Answers
SOURCE: lighting the pilot light on a Worcester 24CDi combi boiler.
Most of these boilers don"t have a permenant pilot light they have electronic ignition that lights the burner when you are calling for heat or hot water, is there enough water pressure in the boiler ( there is a small gauge on the bottom r/h side of the boiler the needle should be sitting at between 1 - 2 if not enough pressure the boiler won"t light )
Posted on Apr 23, 2010
Pilot light wont stay lit once button is released unit is about 11 years old
call your plumber and have it serviced possibly just needs the thermocouple replaced .
Dec 28, 2015 | Bosch & Tankless LP Hot Water Heater
How do you work the heating on a Worcester bosch 35cdi boiler
search for worcester bosch 35 cdi manual choose Greenstar CDI & download the pdf instructions
Dec 31, 2014 | Bosch Water Heaters
Worcester 35cdi overflow problem
if by overflow pipe you mean pressure relief valve either your expansion tank is full and needs to be drained if that type or replaced if bladder type. but if 1.5 bar is normal pres reading then the pressure relief valve is bad (it is a wear item )
Nov 12, 2013 | Heating & Cooling
Worcester 35cdi water and heating luke warm
First thing is to know when it was installed? Check the top of the unit and see if it has in and out marks on it. If it does are they correctly hooked up? Installing them backwards causes this.
Jun 04, 2013 | Water Heaters
Pilot light ok when release finger pilot goes out
Your thermo couple is bad. Thats the copper tube that goes from the gas valve to the pilot. It senses thats the pilot is lit. Thats not working thats why it goes out. You can get a new one at lowes or home depot for about ten bucks its pretty easy to change just dont kink it when you put it in. It will just plug in at the pilot and screw in at at gas valve.
Jan 11, 2013 | Bosch Worcester Spark Electrode...
Lighting the pilot light on a Worcester 24CDi combi boiler.
Apr 23, 2010 | Heating & Cooling
Worcester heatslave 9.24 pilot light wont stay lit, pressure is o.k. what is the part and where do I get it (thermal coupling?)
thermocouple any plumbing or heating shop juast ask for a universal thermocouple ie honeywell the heating shop willl know what you will need
Apr 13, 2010 | Heating & Cooling
Worcester Bosch 35CDi II banging & wild pressure (CH only)
Hi try bleeding the pump it sounds like air in the pump , but worcester do have a free tech help line look for there wed page on line hope this helps
Feb 16, 2010 | Heating & Cooling
Bosch boiler System
it means that the boiler wants to be serviced, the boiler will still work fine. Once the boiler has been servcied, there are a succession of buttons, that need to be pressed, to tell the boiler that it nhas been serviced. then 365days after it will do it again. Its there to prompt you, to get the boiler serviced
Dec 11, 2008 | Water Heaters
My Worcester Bosch 35cdi boiler is flashing temp then backwards t forwards t, whats wrong with it.?
35 cdi worcester combi about 3 years old,heating not working,hot water works fine.It's been serviced not long ago.Room stat turned up and trv's ,but boiler want fire up,there's power to the boiler and the room stat the built in time clock is switched to on, but still nothing. do you think it could be the diverter valve, when i got there it was flashing SE which mean's it needs a service,cleaned the heat exchanger and burner with the proper worceter brush etc then re set boiler with technical, they also said it could be the built in clock and told me to disconect it, and just use the heating stat to control it.It still want fire.
Sep 03, 2008 | Heating & Cooling
Heating & Cooling Logo
208 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
