Question about Furuno FCV620 Color Fishfinder
Power on beeb getting but no display
Power on beeb i got another key are operating tone i am getting but no display i am not getting 5.5v and 12v 40 also how can i trouble shoot
What is a 12v acc.
1.Wire name: ACC wire
Color: Red
Describtion of ACC wire:
When you insert key into ignition switch and turn it to the left you are turning on the ACC circuit. It will allow you to operate radio, windows and other accesories, but it does not turn on fuel pump and other engine controls. It saves battery power for when you need to operate vehicle components without engine being on.
The ACC wire offers power/electricity only when you insert car key into ignition switch and turn it to the left
The ACC wire needs to be connected to car igniton
2.Wire name: 12V battery(+)
Color: Yellow
Describtion of 12V battery(+) wire:
The 12V permanent battery wire will always offer power/electricity when the vehicle is turned on or off
The 12v permanent battery wire needs to be connected to car battery.
26291025-azrw0qmg4txhvnd4c3h3ocng-5-0.jpg https://electronicshelponline.blogspot.com/
Sep 25, 2016 | Car Audio & Video
AVAYA Merlin Magix phone system powers on, all phones have blank display but have message light blinking, no dial-tone, key press = no sound, adjust volume rings phone and displays on screen.
if you have it plugged into an outside line and do not have a dial tone call your phone company .but when buying stuff at an auction , well you get what you got even if it's old and none working
Feb 21, 2016 | Lands Phones
The dial tone is going beeb, beeb,beeb,beeb,but the phone is working ok,its like there is messages but it does not have answering machine
You may be subscribed to a voicemail system provided your telephone company. This system records messages when people call while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Jun 15, 2012 | Lands Phones
I have intel845 board when i switch on power without ram i get ram beeb but if ram installed i cant get any beeb & no display & board star power on automatically
If the board is starting properly with RAM installed but you are getting no display then the problem is with the video card or onboard video. If it is onboard video then you should be able to fix this by purchasing a compatible video card and installing in your pci-x slot. Make sure you disable onboard video once you are able to get into your bios. Hope this helps.
Sep 13, 2009 | Computers & Internet
02 chevy trailblazer 4.2l car wont start installed new starter still wont crank or start test fuses all are good lights and horn operate but no start could it be the ignition switch not giving power to the...
You need to establish that you have 12v in the battery and that all connections are clean and secure. Lights horn etc do not give you voltage verification...your starter uses more amperage than anything else in the car. Once you are certain that everything is OK, check for 12v at the small wire on the starter with the key turned to start. If no volts, check the neutral safety switch or clutch switch Then check ignition switch for power in/out.
Jun 09, 2009 | 2002 Chevrolet TrailBlazer
Motorola T5100 Radio
Setting and Transmitting Call Tones
Your radio can transmit different call tones to other radios in your group so you can alert them that you want to talk.
To set a call tone:
1. With the radio on, press MENU 3 times. The current call tone setting flashes and displays.
2. Press + or - to change and hear the call tone.
3. Press MENU or PTT to set the new call tone or turn feature off.
http://www.motorola.com/mdirect/manuals/T50-T55_UserGuide.pdf
Sep 11, 2008 | Motorola Talkabout T5100 (14 Channels)...
When my daughter turns her car audio off, we loose preset stations.
Two questions to narrow this down - one, is it an aftermarket stereo, or a factory one? Two, with the key out of the car, can the stereo be turned on?
If it's aftermarket and it powers on when the key is off, then it's likely two wires are reversed in the harness behind the deck - the constant 12v wire and the switched 12v wire. The constant one is the yellow one, which always supplies power to the deck, keeping power there for the preset memory and the tone settings. The ignition-switched one is so that when the key is turned off, the stereo shuts off (this is the red wire on the harness). If these were reversed, the stereo would always be able to be turned on, and power to the memory settings would be lost when the key is turned off.
Sep 10, 2008 | Car Audio & Video
Problem withPanasonic phone
Unplug the power supply to the phone, wait 1 minute and plug it in again
Mar 05, 2008 | Lands Phones
PLease help me with my Nokia 6288... Thanks!
UR MOBILE'S CPU IS DRY HEAT IT OR CHANGE IT. HAVE A NICE TIME.
Mar 03, 2008 | Nokia 6288 Cellular Phone
VTech 5.8 mhz won't work
I found a solution that fixed this problem (at least for me). On the vtech site they said to unplug the base unit for at least 5 minutes. Previously, I had only unplugged the base unit for a few seconds. This time, I left it unplugged for about 10 minutes or so and when I plugged it back in, everything was working fine. Apparently there is some sort of capacitor that must discharge long enough to completely remove power from the circuitry.
Good luck and I hope this works for you!
Jan 18, 2008 | Vtech 9009111 Cordless Phone
Furuno FCV620 Color Fishfinder Logo
22 people viewed this question
Top Furuno Boating Experts
Daniel Dollive
Daniel Dollive
Colin Stickland
Colin Stickland
Shehu Pro
Shehu Pro
Are you a Furuno Boating Expert? Answer questions, earn points and help others
