Question about Toshiba 50H13 50" Rear Projection Television
Toshiba 50h13 wont turn on
House got hit by lighting a year or so ago. It was plugged into a surge protecter. But wouldn't turn on afterwards. Is there a possible DIY fix. I have some electronic knowledge.
  • Matthew H Nov 28, 2012
    The fuse is good. I checked it. The entire tv won't power on. The red power light wont turn on or anything.
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
Follow the voltage into the set, this kind of damage can be hard to find in any other way.
Posted on Dec 22, 2012
2 Suggested Answers
Bappa170873
  • 505 Answers
SOURCE: Won't turn on. No click, no power light, nothing.
1. Try a different wall outlet
2. Open the back panel of the TV. Replace the fuse and will resolve the issue.
As you have mentioned that a lighning has struck so there is a possibility that the picture tube may get damaged. If that is the case in that case it will be repaired by your vendor or you can contact Bestbuy for the same. They have the option of sending a technician at your place.
Thanks.
Posted on Oct 12, 2008
Panasonic Home Theater System ....No power
Likely a power surge hit your house while away. This happens when power turns back on or lightning hits close to your house. If insured, call insurance company about it. You may be covered for replacement or have deductible applied. Small appliances like this are most susceptible to power surge. There is not enough protection designed in.. The best protection is surge module on main breaker panel or buy a protected power strip to protect high value electronics.
Apr 16, 2014 | Panasonic Audio Players & Recorders
MALIBU 200 WATT IRON CORE TRANSFORMER MODEL NO 8100-0200-01 LIGHTS WONT TURN OFF
Plug power pack into cheap wall timer, and that will operate lights until warranty is resolved with Malibu or product-seller.
Simple power outage, or nearby lightning strike, can cause surge that will knock out digital timers. And knock out analog series power packs too.
You probably need receipt for warranty claim.
This timer is not shown on Intermatic site, and not subject to Intermatic 5-year warranty, but certainly Malibu must have a warranty of unknown length, and a corresponding claim procedure.
Double-check your installation, and additional resources:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Whole-house surge protection is hot item among folks these days since so many household items are now electronic, including appliances, washer-dryer, water heaters, timers, etc.
This will protect both 120Volt and 240Volt circuits, although it is unknown if your timer failed because of surge..
http://waterheatertimer.org/How-to-wire-Whole-house-surge-protector.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 29, 2012 | Hardware & Accessories
Our garage door opener has been hit by lightening 3 times. It is a Liftmaster 2220 - screw drive. The repairman says it hits the eyes and travels to the logicboard and ruins it. We have replaced it 3...
Is your house being hit by lightning? If so, there is nothing you can do.
If not, it could be a spike in the electrical service as well, I think. Try installing a high rated surge protector on the plug end. Some even have a guarantee that if the equipment protected gets damaged, they will pay for repair.
Let me know,
Gary
Sep 05, 2011 | liftmaster Chamberlain Garage Door Opener...
I have a problem .. I have a mrv t757 amp and it isnt bumping like I used too .. If i keep the volume low all 3 lights are green but once I turn it up it blinks red n yellow n green back andn for in the...
check all your connections to make sure you don't have a short, but most likely it's your amp. If it was the battery it would turn on and off, including radio, then your car wouldn't start(dead battery), but if it does this and your car turns on no problem then it sounds like the amp gave out.
Aug 23, 2011 | Car Audio & Video
I have a D52GW12 tv. During a storm a couple days ago there must have been a power surge. I have managed to get the TV's power light to blink but it won't turn on. How do I reset the Tv or fix the...
Unplug from the wall and hit the power button on the tv. The light may come on dim then fade out or you hear a click. This means it has built in surge protection. Plug it back into the wall and you should be good to go if nothing burnt up.
Jun 21, 2011 | Televison & Video
My xbo was working last night and we had a power outage , then this morning when i check if any electronics r working , everything was fine but when i went turn on my xbox it is stuck on standby mode and...
It sounds like it may have had a power surge. Was it plugged into a power strip, or straight into the outlet? If it was in the outlet, or if the power strip is old, it may not have been protected and you could have fried some of the internal components. Also, did you have an ethernet cable plugged into it? My Xbox got fried a few years ago because of a power surge through my router. If the internal components are broken, the only reliable place to send it, in my opinion at least, is Microsoft's own repair site.
May 14, 2011 | Microsoft Xbox 360 Console
My panasonic plasma wont turn on after lighting hit what could have fried
The first circuit to be hit is the power supply but depending on the protection built into the unit, it could very well have passed high voltage on to the more delicate (and expensive) small signal circuitry.
The only way to establish the extent of damage on your own is, to replace the power supply assembly and hope that the set then turns on. If it doesn't, then you have gambled and lost.
Supplies are normally a separate board that is fitted with plugs making it possible for a DIY replacement. Supply boards can cost anywhere from ~$90 to $175 US.
If you live in a lightning prone area (as we do), I would highly recommend the installation of a 'whole house' surge arrester. With installation, the cost will be under $300 US and units from Intermatic such as ours come with a 5 year warranty and $10,000 in insurance in case the arrester fails to protect your gear.
Jun 13, 2010 | Panasonic TC-P50G10 Plasma TV
Blinking standby light, dead dvd player
Hello illeanaceres,
I'm sorry to hear about the bad news, I had something similar happen to me around a month ago.
Honestly there is not much you can do if it is damaged due to a power surge. Resetting it would be the normal procedure.
Surge protectors only protect equipment up to a certain amount of joules. Basically if the lightning is powerful enough it can damage electronics with that initial surge. You should replace your surge protectors every few years if it is 2-3 years old then it may not be as effective.
Post back if you have anymore questions or comments. Thank you for choosing Fixya!
Jul 13, 2009 | GPX D1816 DVD Player
My sylvania wont turn on.
What is the make and model for your unit? Which state are you located in?
Mar 16, 2008 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Toshiba 50H13 50" Rear Projection Television Logo
27 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
