Question about Symbol Motorola MC3090 Handheld Computer
Motorola MC3090 bricked
I have a couple of MC3090 which i flashed to a newer firmware without a problem (flash via SD-Card). one device get stuck while flashing PBL, after a while it "burped" (really sounded like this) and switched off. it is not restarting. charging led is flashing / solid (battery charges) on craddle, it responds to the cold-boot keypress with flashing the led once. display backlight is lit for a quarter of a second but LCD seems not powered on. thats it, nothing other. it does NOT boot into IPL. is there a way to reflash the device? JTAG?
5 Suggested Answers
  • 63 Answers
SOURCE: Motorola MC3090 do not read barcode starting with zero
look online there are learning barcodes out there you can scan, look for one with zero in front, if you are making the barcodes yourself than put a * at the beginning and end and then make barcode, it will capture everything in between,
Posted on Aug 26, 2009
  • 65 Answers
SOURCE: IPL Flashing screen will not come up. Flashing now impossible?
Unit is stuck in IPL mode, you need to completely reload this unit, I can help You can always contact me by phone or email 630-622-2024 akowalski@legacyglobal.com Please visit our website www.legacyglobal.com
Posted on Oct 19, 2009
  • 72 Answers
SOURCE: battery problem, MC3090
It sounds like it is. Fully charge the device to 100% and allow it to drain fully until it completely powers off, then recharge to 100% again while the device is powered off (usually takes 2 hours +) if that doesn't alleviate the 'memory effect' then the battery has reached the end of it's useful life and should be replaced. Good luck!
Posted on Nov 10, 2009
  • 38 Answers
SOURCE: How do i replace the memory backup battery on a Symbol mc3090?
Hi Ken. Replacing the memory backup battery (flash/BIOS battery) on any unit is tricky to say the least. I would implore you to check and see if your scanner is still under factory warranty with Motorola/Symbol then send it in for the repair. If it's not, I would have a chat with the vendor you bought it from; a lot of times they will do little repairs like that for a reduced price since you are a customer (I know I do). If both of those fail: the BIOS battery is on the main board of the unit. To get to it you will need to remove the outer shell and then start removing components until you get to the board and the battery. Again, unless you are very experienced with electronics like this (maybe even PCs) and really confident in your abilities, I really would recommend having a professional do this. I would offer to, but our repair facilities won't be up until February of this year. If you need some suggestions on where to go or need to troubleshoot more, please feel free to send me a message or email me at joel@shiftintoblue.com. I hope this helps. Good luck!
Posted on Jan 05, 2010
Can I install firmware on a vivicam 3765?
Firmware only can be installed on a fully functional device. It is wrong to think you could put some firmware into a device, without the special programs the manufactures uses. When a firmware is made available for a camera, it is most of the time put on a memory card. It has a certain name and size. The camera must function for 100%, because the software has not only to recognise the file where the firmware is in, it also must place the software in the flash memory, without an error. For that it only has one chance, of always make sure there is enough power available to transfer and to install the firmware. When things go wrong, you bricked the camera and the only thing you can do is bring it to a certified service centre. Camera's in warranty, will be flashed for free, but out of warranty, it could be they charge you for the job.
Dec 29, 2014 | Vivitar ViviCam 3765 Digital Camera
Camera is not recognized by pc
any card over 4gb will not be read by older computers. If you don't have a newer computer the SD card reader, avliable at walmrt under $10.00 will work.
Jan 24, 2014 | Nikon COOLPIX L810
Boot sd card
Hi Scott,
Unfortunately, you can't export the firmware from a Motorola/Symbol device to SD Card or a computer via USB (I would love to be able to do that but you cant as far as I know...)
You will have to re-install the required OS on the new PDA and install the applications you need via windows mobile center.
Thanks
Jay
Aug 20, 2013 | Symbol MC70
How to extract the firmware onto sd card?
Hi Scott,
Thanks
Jay
My 2 GB micro sandisk i put it on my phone and it says media error how can i fix that ?
A couple of things to look for. some newer SD cards are SD-HC and not compatable with older equipment. The second thing that could be causing the problem is the card hasn't been formated for the phone/mp3 player/touchpad. Your device should have a way to format the card in the settings and options section. After formating with the device the card should work fine.
Apr 29, 2011 | SanDisk 2GB microSD Memory Card
SanDisk 2GB microSD Memory Card not working
SaveMyUsb.com can recover data from most flash memory devices including memory cards and usb flash drives for just £39 - give them a try it worked for me!
Dec 18, 2010 | SanDisk 2GB microSD Memory Card
SanDisk ULTRA II 8GB won't read when installed in a laptop. Works fine in the Digital camcorder. Trying to import the footage on to a Fujitsu tablet laptop (12 months old). Reads the standard 2Gb memory...
No, it's a hardware issue. Your 8GB card is an SDHC card (the HC stands for High Capacity), but the card reader in your machine is clearly only compatible with the older type SD cards. SDHC devices will accept SD cards, but devices designed solely for SD cards cannot read or format SDHC cards.
There is no firmware update for this, your only fix is to buy an external reader compatible with SDHC cards for connection via a USB socket. Most new readers are fully SDHC compliant, but check the specs for shelling out your hard-earned...
May 14, 2010 | SanDisk ULTRA II 4GB Compact Flash Card...
Motorola Phone Tools can not access to A1200 (System Memory is full)
It sounds like a bad flash or firmware to me. I would reflash to a different firmware. You can only flash to the same or a higher track with these phones, so be careful not to flash to a lower track. You could brick your phone.
Apr 22, 2008 | Motorola Mobility A1200
Wat is toshiba flash card
"FLASH" generally denotes a compact storage device called
Compact Flash Card. I have an old digital camera that takes compact flash cards.
Newer Toshiba Laptops and Towers have multi card readers installed, my laptop has a SD card reader under my PCMCIA card slot. I also had a (Made for Toshiba) compact flash adapter. That device was nice because it wasn't "Card Bus" it used 8-16 bit technology making it easy to transfer data from a laptop running windows 3.1 to a laptop running Vista
Apr 13, 2008 | Computers & Internet
MOTOROLA V220 BOOTLOADER PROBLEM
this is the programing mode where the software was originally loaded. Try to remove the battery while the phone is turned on. Sometimes this will reload and allow the phone to work normally. If not contact motorola for warranty info.
Feb 02, 2008 | Motorola Mobility V220
Symbol Motorola MC3090 Handheld Computer Logo
184 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
