Question about Refrigerators
Fridgefreezer only works on full - Refrigerators
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
Could you please describe the problem you are having a little better?
Posted on Nov 28, 2012
Hotpoint quadrio fridgefreezer
Sounds like the switch that controls the light is disconnected.
Gently pry the switch out(power off) and see that both wires are connected to the switch.
Feb 11, 2014 | Kitchen Ranges
Tip
Samsung fridgefreezer troubleshooting
hello and thanks for checking out my samsung fridgefreezer trouble shooting section ..<br /> <br /> most of the appliance,s i deal with are made for europe but they seem to be sold worldwide under a different model - so hopefully the info i can give out will apply to most models ? ..<br /> <br /> probally the best way for you to find out about common problems on samsung fridge freezers is to have a look at some of these videos on youtube ..<br /> <br /> samsung fridgefreezer channel /...<br /> <br /><utube src="RP9XLji-gdw"><br /><br />rsh1 model video below<br /> <br /><utube src="wLFcmJEGJMs">(do not delete) </i></b><img src="utube.png" /> <br /> rs21 model video below <br /> <br /><utube src="7xEBoJRBD5Y">(do not delete) </i></b><img src="utube.png" /> <br /> rs21 ice maker fault video below <br /> <br /><utube src="R-va_Siu3zw"><br /> feedback for customer who have received help <br /> <br /><utube src="TGIrwv3xkWg"><br /> hope these videos are able to shed some light on whats causing your samsung fridgefreezer problem..
on Dec 02, 2010 | Refrigerators
How long should a logik fridgefreezer last
try listing in major appliance area--this is tv area.
Aug 24, 2012 | Televison & Video
Why does my fridge not work on my fridgefreezer and my freezer does
HI Dean,
All the cold air is generated in the freezer and pushed to the refer side by a fan. With that being said, with an obstructed air channel the refer suffers. So you will need to determine how the air flow is obstructed. Do you have ice on the back wall of the freezer? If so, defrost could be the problem, if not, has the units door been left open? If so, you will need to remove the air flow restriction. To further help you, I need a model number, and answers to the questions above to understand what you see so I can direct you in the right direction and repair.Good Luck
Dec 02, 2011 | Refrigerators
I have water coming from under my fridgefreezer on the right hand side i have checked that the inside drain is clear and that the f/f is stood level the bottle at the back is really hot
the bottle at the back is the compressor, which is normally quite warm. The water from the drain should be emptying into a evaporation tray,heat will then evaporate the water. If this tray is full then the water is not being evaporated. This indicates that the fridge freezer has a refrigerant leak. This leak will need to be repaired and the refrigerator regassed to solve the problem
Mar 31, 2011 | Refrigerators
Wate light onfront of rangemaster sxs fridgefreezer turned red
After you have changed the filter, select water then hold the select button down and it will go blue again.
Jul 08, 2010 | GE PDS22LBN Bottom Freezer French Door...
Since defrosting my freezer my fridge does not appear to be working correctly. The thermostat is turned up full however the fridge is not cooling. The seal round the door is fine and there is no blockage...
So you manually defrosted your refrigerator and now the fresh food section is warmer than normal. Can you please send me the model number and your location in the world. Some models are totally impossible. I found related models but no parts listings yet. Could you have someone feel the compressor top to see if warm, cool or too hot to keep hand there. Sea Breeze
Mar 18, 2010 | Refrigerators
The fridgefreezer has power but no cooling or freezing
Most likely there is low voltage to the unit or the compressor is bad. Is the condenser coil very dirty and if this unit has a condenser fan does it run?
Nov 10, 2009 | Hotpoint FFA90 Bottom Freezer Refrigerator
Samsung american fridgefreezer
2 years is much too short for starting problems with a refridgerator contact your dealer for a condition because of warranty on the repair you eventual will spend on it. Hidden defects are factory falts are there some holes for melting water are clogged inside the fridge somewhere
An ordinary refrigerator is made for a 17-year life span. like brands as Bosch Siemens Kuppersbusch easely have that lifetime but your dealer is the right point to get your service .
Aug 18, 2017 | Samsung RS2630SH Side by Side Refrigerator
Servis fridgefreezer light
IT COULD BE A BAD LIGHT SWITCH, SOCKET OR BULB.
IF THE CONTROL IS ELECTRONIC, SOME REFRIGERATORS WILL SHUT DOWN THE LIGHTS IF THE DOOR IS LEFT OPEN TOO LONG.
BE SURE THE BULB IS SCREWED IN ALL THE WAY. SOMETIMES, THEY WILL WORK LOOSE.
Apr 02, 2008 | Freezers
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
