Question about Refrigerators
With thermostst set to low it freeze everthing
    New Friend:
    Problem Solver:
  • 16 Answers
Dont set it so low
Posted on Nov 28, 2012
Frig is freezing everthing
A defective thermostat is a strong possibility for the fresh food section freezing. Short of replacing the thermostat ,try setting it to the warmest position for a day ,then check the temp.
Apr 16, 2018 | Refrigerators
Modle 7341 wont cool just freezes everthing at any setting
call a technician and have the thermostat checked / tested /replaced
Dec 18, 2016 | Refrigerators
I have a frigidare fridge FRS26HF6BQ2 that the fridge is freezing. We have replaced the thermostat ourselves and it is still freezing. Does the thermostst need to be clipped back on the the exact place we...
it defenitely has to placed exactly where it was. from the description it is unable to read the correct temp from inside the fridge hence its consequently making the compressor on for too long causing the fridge to freeze.
Jun 30, 2011 | Frigidaire Refrigerators
Everthing in the refrigerator is freezing. The dial is set at 5 for the setting
the thermostat has failed you need to fit a new one
the thermostat switches the compressor on and off when the tem is right,,if its not switching off the freezer just runs none stop
Aug 26, 2010 | Kenmore 51692 / 51694 / 51699 Side by Side...
My rm2652 freeze all the time
this is a possible thermostst control problem, the thermo switch may be stuck in the on mode.
Apr 18, 2010 | Dometic RM2652 Refrigerator
Apartment size refrigerator just started to freeze everything
Check the seal around the door itself this may be worn or detatched. This will cause warm air to get into the appliance and freeze inside thus making you freezer look the the arctic.
Mar 12, 2010 | Whirlpool Refrigerators
Idesit BAAN134 PSUK fridge keeps freezing food . The fridge part of my tower f/f keeps freezing food even though I have turned the dial down to the minimum the temperature regularly drops to below...
If it is an electronic thermostat it could be that the engineer has changed the board but not the sensor which reads the temp. If it is a mechanical thermostat it may be hes fitted the wrong type.It could also be that the system is short of refrigerant and the actual refrigerant charge is not getting all the way to the thermoststs sensor to switch it off, the back wall of the fridge should be frosted at least 3/4 of the way down and not just forming in a small part of the fridge.
Jan 05, 2010 | Refrigerators
Freezing in refrigerator compartment
check thermostat ,adjust, thermostst may be to low, or faulty thermostat, replace,
Aug 02, 2009 | Refrigerators
Motorola v330 freezing
try a factory reset. it should be under settings or you could have it flashed witht eh new firmware.
Jun 09, 2009 | Motorola Mobility V330
Coils behind the freezer continue to "freeze up"
You have a problem in the defrost system There are three components: Defrost timer, defrost thermostst or terminator, and defrost heater. One of them has failed which is causing the evaporator to ice.
Apr 09, 2009 | Refrigerators
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
