Question about Whirlpool LSR5132PQ Top Load Washer
Whirlpool topload washer model #LSR9434PQ4 won't spin
Washer drains but does not spin
  • 640 Answers
Check you lid switch
Posted on Jan 10, 2009
My Whirlpool Toploader washer model LSR8233JO1 stops at rinse cycle after draining. I have to manually advance it to the spin cycle and sometimes it won't spin.
Dawntm,
It is possible that you have a timer issue since you say you are having to manually advance the timer. There is a small motor mounted on the timer that normally advances the timer and for some reason, possibly a burned contact, it is not advancing from that point. You might need to call in a repair tech. Hope this helps!
Jun 30, 2015 | Whirlpool Washing Machines
What should i look for on my whirlpool washer if it hums but won't spin, agitate, or drain?
The motor may be shot if it is getting current and won't operate the washer.
Nov 04, 2011 | Washing Machines
Whirlpool washer model LSR5232LQ0 won't drain. just stops. is there way to cause drain?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 22, 2011 | Whirlpool Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Ultimate Care II toploading washer doesn't empty or spin after ag
Hello, I can help.
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
Jun 21, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool LSR5132PQ Top Load Washer Logo
173 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
