Plugged in but not charging... acer nplify 802.11
I plugged the adapter and yet it is not charging... but the indicator indicates that the adapter is plugged.. its very annoying..
  • 7,627 Answers
Is the battery good? A replacement battery? Remove battery and re insert. What indication gives you the idea that it's not charging? No charge light on? In software, the icon in tray notification area?
Posted on Nov 28, 2012
knotbeerdan
  • 413 Answers
SOURCE: Laptop won't power up dies in the middle of movie-won't power up
You would probably be better off buying a new notebook. Not sure how tecnologically advanced you are but it seems you already did the troubleshooting yourself. But i am very interested in the a/c adaptor output. If the led on the adaptor is green that just means that it is getting power from the wall.
What did you mean by fluid leaking out?
It could be the mobo (motherboard) or it could be the connections from the power to the machine. If you want to put a new mobo in I have to warn you that taking apart a laptop is VERY difficult and I do not recommend this unless you are a PRO. This is just about the only link i can find to buy a new board. If you google your laptop model you will find out you definately are not alone with this problem
http://www.notebooksolutions.ca/zc/index.php?main_page=product_info&products_id=1183
Please don't forget to rate my response and let me know if there is anything else I can help you with.
Posted on Jan 08, 2009
leecom72
  • 4806 Answers
SOURCE: Acer aspire laptop won't charge
First of all you have to determine whether it's the battery, charger or the laptop itself.
Remove the battery and boot the laptop on AC power only, if the laptop boots up you can rule out the charger and the laptop, you may need a new battery if that is the case.
Regards.
Posted on Sep 08, 2009
SOURCE: plugged in not charging
I had the same problem in my laptop and it got solved by taking out the battery and placing back again...
Posted on Jan 19, 2010
SOURCE: Acer aspire 4520 does not power up despite fully
Remove ur battery & clean it with water and put it in to ur laptop then press 5 minutes ur power button Then ur laptop get started .
Note : Wash ur battery with clean water .
Posted on Mar 26, 2010
ic0729
  • 212 Answers
SOURCE: my toshiba satellite L300 has no power
Please follow these steps VERY CAREFULLY:
1) Unplug the notebook from the ac adapter (charger power cord)
2) Take off the battery pack on the notebook
3) Once the ac adapter and battery is off the notebook, hold down the power button for 15 seconds
4) After 15 seconds, let go of the power button
5) Now plug in the AC ADAPTER (OR CHARGER POWER CORD) ONLY (DO NOT PUT BACK THE BATTERY PACK)
6) Now press the power button once.
7) If the unit boots, the unit suffered a slight surge
8) If the unit does not boot and remains dead, the unit suffered a severe surge and may be burned out and needs replacing
I hope this helps and let me know how it goes afterwards
Posted on May 03, 2010
Battery indicator on my acer aspire 5517 laptop is blue what does it mean
Acer Aspire 5517 shows BLUE light when fully charged.
Start it and check battery indicator (tray item) will probably say
plugged in fully charged (with adapter plugged in)
Dec 07, 2013 | Acer Aspire 5517 Laptop
No power
Try to remove your battery and plug in your AC adapter
If its working:
You need to replace your battery
If its not working:
Try to check if the LED indicator is lit
If the LED indicator is not lighted. Replace your AC adapter
Thanks. Cheers!
Apr 20, 2010 | Acer Aspire One AOD150-1920 Netbook
Won't start - battery critically low
You should have a light on the notebook indicating that the power supply is plugged in (this should come on with or without the laptop being turned on). My acer has a green light for power, and the battery indicator shows amber for charging and green for full. If you are not seeing the power or charging indicators, you either have a damaged power jack, or a damaged power supply. Power supplies can be purchased usually for fairly cheap online, but if your power jack is damaged, the laptop will have to be serviced by a service center, or by someone who is skilled with a soldering iron and the disassembly and reassembly of laptops.
Feb 28, 2010 | Acer TravelMate 2413LCi Notebook
My Acer Aspire 5100 just went blank. There is a
Generally, an indication that the battery is critically low. It appears that the AC adapter is not powering the system and not charging the battery.
Jan 09, 2010 | Acer Aspire 5100 Notebook
I have a laptop running 802,11 g/b and vista and I Cant connect to linksys wag160n wireless router(802,11 n). laptop sometimes recognises network but when I try to connect it wont. could you help ?
Hi, You cannot connect across wireless protocols. In other words to connect to 802.11 n you need an "n" adapter.
Now, the router should be backward compatible & provide wireless g/b but you may find that when you search for networks it will be listed as a seperate network name (from the same router)
Try searching for this other network. Your router documentation should advise you of its default name & any set up process
Dec 23, 2009 | Acer Computers & Internet
Travelmate only powers up with battery inserted. But AC still charges battery. Orange light goes on and of
Sorry to tell you this but you may have a problem with the charging system. That will require you to return it to Acer or an Acer service center. You can also try this. I got this from Acers' travelmate support website:
If the notebook does not power on:
Make sure the ac adapter is correctly plugged into the notebook and into the power cord.
If everything is plugged in correctly and it still will not power on, follow these steps to complete a ‘power reset' of the notebook.
  1. Unplug the ac adapter. Keep ac adapter unplugged.
  2. Remove the battery and keep the battery unplugged.
  3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
  4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
  5. Normally power on the notebook.
  6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
  7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
    If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
You can aslo google your specific model of Travelmate to see if others are having this issue.
Les
Jun 27, 2009 | Acer Computers & Internet
I HAVE A ASPIRE 5520 IT WONT START THE FAN STARTS AND THE DVD BUT IT JUST KEEPS ON LOPPING
I had the same problem but what you can do is...
  8. If its not the batery or AC adapter you might have to send it to Texas, just go to www.Acer.com
Jun 14, 2009 | Acer Aspire One PC Notebook
No response
First follow procedure to try to reset the power.
May 23, 2009 | Acer Computers & Internet
Acer laptop shut of during power outage .
From the Acer website:
Product
Notebook
Issue
Power Issues or Will not Boot
Solution
Also, depending on whether your power went down "clean" (quick and stayed off), or went down and quickly came back on and off many times. Or when it came back on "clean" (came back on quick and stayed on), or it came on then off many times, your power supply may have been damaged from the power surges Are you having any problems with any other appliances?
Feb 07, 2009 | Acer Aspire L100 PC Desktop
Travelmate 2300 won't power on
The problem could be your bezel.  Remove the 3 screws from the hinges from the rear and you will be able to remove the black strip above the keyboard (after removing the screws, make sure laptop is layed wide open)  once removed, press the button on the motherboard under where the power button is.  If the unit still does not power up, then your motherboard is bad and needs to be replaced.  If it does power up, you need to replace the bezel.
Oct 18, 2007 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
115 people viewed this question
David Payne
David Payne
