What caues the line at the very bottom of my 55 inch floor model toshiba tv
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
In very old sets a vertical circuit problem--what model?
Posted on Dec 22, 2012
  • 1694 Answers
SOURCE: 55 inch projection tv
BUSTY35,
Here is your screen info = protector...PS5501....$155.00
Lenticular = 23430819....NLA Fresnel..23430635...$135.00
...........................................T.
Posted on Dec 17, 2007
  • 185 Answers
SOURCE: toshiba 55 inch hdtv lamp
this is a crt type tv- no lamps just crt's if it was moved recently then a seal could have been damaged on the crt cuasing coolant to leak down the neck getting into the socket. this will cause trouble for sure also could have a crack in the crt. look for a sticky liquid in the bottom of the unit.
sometime the crt's can ark and rip out a video output chip on the crt socket check it out.
not common but not unheard of.cheers
Posted on Oct 08, 2008
  • 6 Answers
SOURCE: I want to download tv manuel for toshiba 55 inch
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000001850.pdf
You need Adobe Reader to read, but just load and click save = )
Posted on Feb 20, 2009
techman007
  • 1112 Answers
SOURCE: 55 inch mitsubishi rear projection tv red lamp out of adjustment
Have convergence IC's replaced. I believe this unit uses STK-392-570 convergence IC's Only one has gone bad but replace them both, because if one has failed then the other is not far behind, for Blue and Green. One handles Red, One handles BLUE and Grn. There are only two of them in the set, They are the two largest IC's in the entire set.
Posted on Oct 01, 2009
  • 4 Answers
SOURCE: Blue Line acroos bottom - 55' Wega rear projection TV
turn down the picture level the blue line goes away
Posted on Dec 03, 2009
My led samsung tv has a horizontal line and the upper right corner shows a white vertical lines
Not good. You may have a tab failure. A repair shop may be able to diagnose and repair this, but most likely the lcd panel is broken. The panel is the most expensive part of flat tv's. A new panel will cost more than a used tv.
Feb 02, 2015 | Samsung Televison & Video
TOSHIBA 55" INCH .. COLORFUL LINES ON THE SIDE
looks like a problem with the cable or screen. i would call an electrition or get a new tv.
Jul 14, 2013 | Televison & Video
Black line running vertical from top to bottom toshibia tv 42
Model listed here is 46 inch---what is correct model of your TV?
Jun 15, 2012 | Toshiba 46H84 46" Rear Projection...
My rca toshiba 50 inch projection tv is showing a 3d color curve
Need the model number to help as I am not sure of you have a RCA or a Toshiba
Dec 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
2005 sony 55'' sony wega. a very thin blue line is
Are you using a cable or sat box. If so then you are selecting channel using the tuner in the box and sending a constant signal to the TV eithir on one channel of the tv tuner or one of the other input of the tv. If this is the case I would suspect the box and not the tv because you say it is only on some channels.. If you are using the tuner in the tv with cable or antenna directly in I would say the main board that has the tuner on it needs replaced. Without a specific model number thats the best I can do. Hope this helps.
Nov 25, 2009 | Televison & Video
Feb 20, 2009 | Toshiba 55H70 55" Rear Projection...
Toshiba 55 inch hdtv lamp
Sep 26, 2008 | Toshiba 55H70 55" Rear Projection...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
