How to disassemble a hp p2055 laser printer - Office Equipment & Supplies
  • 826 Answers
Follow this link to take guide about disassemble: http://www.hp.com/hpinfo/globalcitizenship/environment/productdata/disassemblylaserjet-p.html
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Posted on Nov 28, 2012
2 Suggested Answers
Vanguardian
  • 106 Answers
SOURCE: L7157 HP Laser Jet P2055
Unfortunately, this is a common problem. I suspect you're using MS Word to make the labels. Word takes the font and the dimensions of the labels and is supposed to transfer the correct sizes of everything to your printer. All to often it doesn't do this correctly.
One thing to try is a couple different fonts to see what happens. (use plain paper to experiment, it's cheaper.)
The other way is to set up a regular page in MS Word with 3 columns and fill the page with copies of your information. The trick is to adjust the font size on the empty lines between your information.
address line 1
line 2
line 3
[font size adjusted empty line]
address line 1
line 2
line 3
Posted on May 31, 2012
Since upgrading to windows 10 the printer takes ages to print, usually sends out a blank page first and more often than not an error message appears on the laptop to say the printer cannot print
electronics have what is called manufacturers specification upgrading may seem ok but the drive n kind of system may not match the specs this affects the normal working of the upgraded system just buy a windows 10 pc n all will be well
Oct 03, 2015 | HP Laserjet P2055 Printer Laserjet 1200 X...
Envelopes don't feed properly
When printing envelopes, you have to set tray1(the bypass tray) to handle the envelopes in the menu.
Configure trays (HP LaserJet P2050 Series Printers only)
1. Press OK.
2. Press the down arrow to select System setup, and then press OK.
3. Press the down arrow to select Paper setup, and then press OK.
4. Press the down arrow to select the desired tray, and then press OK.
5. Press the down arrow to select Paper type or Paper size, and then press OK.
6. Press the down arrow to select the size or type.
7. Press OK to save the settings.
Feb 26, 2015 | HP Laserjet P2055 Printer Laserjet 1200 X...
HOW TO RESET PAGE COUNT TO ZERO
Hi i am PARTYAB.COM from iran.
It is simple.
1.power off hp 2055dn
2. While pressing and hold Down and Cancel Key power on printer
3.you will see permanent storage init. On the panel
4.after that you can set and change language and location like when buy a new printer .... set it.
5.and now you have got a printer with zero count page printed
6. Ok now you can tell lie to others that this a new printer an sell it more price.
Otherwise What's the reason you want to change count page printed? :)
Aug 08, 2014 | HP Laserjet Printer P2035 P2055 Laser...
The lights keep blinking?
Hello, Usually this is caused from no paper ,a paper jam. Check for paper jam or no paper. Or engine driver failure this is a hardware failure and will have too be service repaired.
May 29, 2014 | HP Laserjet Printer P2035 P2055 Laser...
The printer is failing to print. Instead it is indicating 'error 0605'
Hello try to uninstall the old software and download and install
the new software from here:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3662026&lang=en&cc=us&taskId=135&prodTypeId=18972&prodSeriesId=3662025
Remember to select your windows version.
If i have selected the wrong model download the software here:
http://www8.hp.com/us/en/support-drivers.html
Just enter the full printer name.
Good luck
Nov 12, 2012 | HP Laserjet Printer P2035 P2055 Laser...
Getting black marks and black lines on paper when I print??? Looks very unprofessional.
Check the drum on the toner cartridge.DO NOT EXPOSE IT TO THE DIRECT SUN LIGHT. Check for some oily spots on the drum.I f there it is clean them with a soft cloth. After this put a cartridge in the printer and make 2-3 test pages. If the problem still exist maybe you should try to disassemble the cartridge and clean the blade of the developer roller and drum cleaning blade. DO NOT TOUCH WITH OILY OR WET HANDS. Here is instructions for disassemble and for refilling the cartridge step by step http://www.uninetimaging.com/downloads/technical/hp/english/HP_P_2035_2055_Reman_eng.pdf
I hope this will help to you.
Jul 06, 2012 | HP Laserjet P2055 Printer Laserjet 1200 X...
Error b0605
HP laserjet p2055dn error message B0605
Jul 05, 2012 | HP P2055DN LaserJet Monochrome Printer
address line 1
line 2
line 3
address line 1
line 2
line 3
May 31, 2012 | HP LaserJet P2055d Printer
174 people viewed this question
k24674
jasbo
jasbo
